Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Bottom element not working - Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
  • 3,037 Answers
Well, to ensure the element is bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, the element is bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the element wiring and touch the probes from the meter to the contacts on the element. You can order a new element locally or from repairclinic.com. Let me know what you find.
Benjamin
Posted on Nov 04, 2010
Why isn't my oven working? After changing bake element and thermostat
Either the bottom element is defective or the wiring to it is not hooked up properly so it gets power and does its job ala the top element.
OR the control that is responsible for having power delivered to both elements is only sending power to the top element. Make sure you are not using the broil setting since that only activates the top burner.
Feb 03, 2016 | Ovens
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Kenmore electric oven bottom element not working
check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
GKM
Jan 07, 2014 | Ovens
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
Bottom element quit working. changed element still not working
if your oven has an electronic control board then it needs to be replaced.make sure all your power to the unit is good and there are no loose wires on the main terminal block.If it does not have electronic control then replace the oven control switch.
Feb 24, 2010 | Ovens
Bottom oven element not working
Only 2 things left. A bad wire or bad control board.
Remove the rear panel. Set the range to bake,check power at the element terminals with a voltmeter. Ifyou do not have 220 volts at the element replace the ERC.(clock).
May 23, 2009 | GE Ovens
Bottom Element Open Circuit & Fan Element not working
No resistance in a bake element is a bad element. Replace it.
Most fan come on with a rise in heat. No heat/no fan.
Apr 08, 2009 | DeLonghi Ovens
Bottom /bake element will not come on
Check the connections to the element. If power is going to the element, and it is not working, the element needs to be replaced
Jul 21, 2008 | GE JKP15 Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
74 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
