I was watchin a movie ,turn off , i tried turn back on green light blink 3 times then goes the red one, six times pause again six times .
Oh ho try a hard reset mostly u will solve.
if donot get that right try this .this will definitely solve your problem
Dead 6 Blinks. B+ error. Relay (RY1901) on F Board is chattering. The relay would click three times then power LED flashed six times. Standby 7 v OK.
CAUSE: Found problem was with the Q Box. Ordered new Q Box (70 model) T99861249. Q Box (60 model) T99861248.
rate this solution as fixya as it will definatly help you. thanks for using fixya.
what is the word u did not understand kindly clarify.
It looks like your power module is on the blink. Do you get any picture?
Red blink error codes for Sony televisions can be found here.
Six blinks:
Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes:
+5 line is overloaded. (A, B boards), +5 line is shorted. (A, B
boards). Symptoms of the problem: No picture.
You need to replace the power module in this unit. Is it still under warranty?
would you please be more explicit , i did not understan what you wrote .
no , tv don't turn on , green light 3 times then red keep blinking six times
