Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet GU2300XTLS2
Not cleaning properly dishes are dirty, soap dispenser not completely empty after cyle. Please help.
  • 413 Answers
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Posted on Jun 13, 2008
Dishwasher is not cleaning. The soap tablet is dispensing yet at the end of the cyle it is on the bottom of the dishwasher and the dishes are dirty. It sounds like it's running properly from the outside....
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
czt32
Aug 22, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishes in top rack not getting clean
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101
May 28, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
The dishes coming out dirty on my Whirlpool Gold Quiet Partner IV. Cycle seems to complete. The soap is being used. Not sure how old it is ... it came with a house I just bought. Any suggestions?
Clean the jets on the unit. Jets are the small openings the water comes out of. Contact Whirlpool, follow their recomondations, or add some CLR or Lime Away to the washer without a load of dishes. Both products remove Calcium Lime and Rust deposits which impede the flow of water, causing your dishes to come out dirty
May 16, 2010 | Dishwashers
Dishwasher is not getting dishes clean. Water is
follow this link:
http://www.fixya.com/support/t2390397-dishwasher_acts_up
that guy gave me some good advice!
Jun 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher does not rinse clean
run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Apr 22, 2009 | Dishwashers
Our dish soap is not dispensing from the flip container.
sounds like you have a water circulaton issue, make sure your getting enough water in machine, and nothing is blocking the dispensor eform getting hit with the waster stream
Jan 11, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Whirlpool Gold Quiet Partner IV issue with soap dispenser
This happened to me as well. I think I solved the problem. It started when I first lowered the top rack. In doing so, the door doesn't open all the way. It also won't open all the way if your cutlery rack is in the front and you've put large utensils like a spatula. Consequently, detergent dried under the latch and it wouldn't firmly catch. For months I put up with it never emptying completely. The other day I took a tooth brush and very hot water and cleaned under the latch. After, I could feel a difference in the way the latch operated (with greater pop on opening). So far its been doing fine. Hope this helps.
Denise
Dec 05, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it: http://01tutorials.com/video/1686251/how-to-clean-the-filter-on-a-whirlpool-gold-quiet-partner-iv-dishwasher/4107
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Apr 07, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
375 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
