Question about Goodman CLQ36AR49 Air Conditioner
Blower motor not running
I checked the voltage going out to the blower on the 7 wires exposed from the connectors. This is on an AE30-10. they are 7,7,7,7,7,7,32 vac. does this point to the control board or the electronic cap on the motor?
  • joseph3333 Jun 15, 2008
    well, the source voltage goes down to the blower from a different route. Ofcourse, it is saturday, and cant get the part. The 120 goes directly to the cap "hub" on the motor. the control voltages are what I stated. I dont know what they are supposed to be, and so have this dilema. Yet, the simple trouble shooting steps from the "helpful" tech manual said to ck the voltages on o,c,w,r etc. but the above is the same. I dont know what they are supposed to be at "normal". There are 2 relays on the "hub" that i would think have gotten damaged. otherwise, the control board just looks like simple "connection" points.
    Champion:
  • 254 Answers
This would point to the control power board. Even if the cap was bad your source voltage should still be line which I assume is 120vac in this case.
Posted on Jun 13, 2008
The blower motor in my 2006 mercury montego will not turn down or shut off. It got stuck once it was turned past 60 degrees. I've replaced the dash control panel and it done the same as the old one.
Check blower motor wire connector for voltage and ground. As you can see there is blower motor relay. The relay has a load side and a control side, two sides. They both have to function properly, The load side of relay is that line with arrowhead, voltage to load side, hot all the time. The control side of relay, right side in the picture needs voltage and ground to energize relay. The voltage goes hot with key on. The hvac module should control ground, the brown wire with white tracer is ground. With key on, if that wire is shorted to ground or wiring connector has a problem, the blower motor may run all the time, with key on. Shouldn't run with key off. It's been my experience that relays are usually dependable, but, you never know? At the blower motor top wire is voltage, bottom is ground, in my opinion. You can see speed controller in diagram.
Dec 11, 2017 | Mercury Cars & Trucks
2005 Chevy Colorado LS 5.3L Blower motor iOS not working. Replaced the resistor because that was burnt out but it didn’t fix the issue. Figured out the connector only gets power at the brown wire and...
The top wire at blower motor is voltage, the bottom wire is ground. So brown wire is voltage, orange wire is ground. So, the resistors, havc control, on and off and speeds are controlled on the ground circuit. Generally if ground is good, no voltage or very little on the ground circuit, because the component is using the voltage. The wire connector for your blower motor is it any good? You could remove blower motor, use jumper wires off battery for voltage and ground, the blower motor should run up a storm. It wouldn't hurt to use inline fuse, just incase.
I looked at info for 3.5L, my info didn't show 5.3L?
Oct 28, 2017 | Cars & Trucks
2003 trailblazer blower not working
Are you saying the blower motor would run intermittently and then just stopped working? My first thought is faulty blower motor, I've seen faulty blower motors that would run intermittently. Any motor that uses brushes, you can tap on the motor to see if it will start working, that is a sign of bad motor brushes, replace the blower motor. There could be other issues?
Did you check the blower fuse, not only check the fuse, check the fuse circuit for voltage, use a test light. Check for applicable hvac trouble codes. With hvac on, check for voltage and ground at blower motor wiring connector, if both are good and no blower action, suspect the blower motor.
May 13, 2017 | Cars & Trucks
How do you get the heater to work on a 2003 Chevy venture mini van
When you change the mode from floor to vent to defrost do you hear switching taking place behind the dash or inside ?
Air Delivery Improper
Test Description
The numbers below refer to the step numbers on the diagnostic table.
The measured voltage should be near the specified values for each mode position.
The HVAC control module is supplied by two ignition 3 voltage circuits. Test the ignition 3 voltage circuit that does not supply the blower motor switch.
Step
Action
Value
Yes
No
Schematic Reference: HVAC Schematics
Connector End View Reference: HVAC Connector End Views
DEFINITION: Air does not flow correctly from the air distribution outlets.
Did you perform the HVAC Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - HVAC Systems - Manual
Turn ON the ignition, with the engine OFF.
Place the blower motor switch in the OFF position.
Is the blower motor OFF?
YES - Go to Step 3
NO - Go to Blower Motor Always On
Place the blower motor switch in each speed position.
Does the blower motor operate at all?
YES - Go to Step 4
NO - Go to Blower Motor Inoperative
Does the blower motor operate in each speed position?
YES - Go to Step 5
NO - Go to Blower Motor Malfunction
5
Except for the blower motor speed, are all of the functions of the HVAC control module inoperative?
YES - Go to Step 14
NO - Go to Step 6
6
Place the blower motor switch in the maximum speed position.
Place the mode switch in the vent position.
Place the recirculation switches in the recirculation position and in the outside air position.
Does the recirculation door move to the correct position for each selection?
YES - Go to Step 7
NO - Go to Air Recirculation Malfunction
7
Place the mode switch in each position.
Is the air flow sufficient from the correct outlets in each mode?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 8
8
Inspect the air distribution system for the following conditions:
• A dirty HVAC air filter, if applicable
• An obstruction to the air flow
• Air leaks
• Misaligned air ducts
Did you find and correct the condition?
YES - Go to Step 23
NO - Go to Step 9
9
Inspect the mode door and the mode actuator for the following conditions:
• A misaligned mode actuator
Refer to Mode Actuator Replacement .
• Broken or binding linkages or mode door
• An obstruction that prevents the mode actuator from operating within its full range of motion
• Missing seals to the mode door
• Misaligned seals to the mode door
YES - Go to Step 23
NO - Go to Step 10
10
Turn OFF the ignition.
Disconnect the mode actuator.
Probe the ignition 3 voltage circuit of the mode actuator with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
YES - Go to Step 11
NO - Go to Step 20
11
Test the ground circuit of the mode actuator for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 12
12
Measure the voltage from the mode door control circuit of the mode actuator to a good ground.
Place the mode switch in each mode position while observing the voltage.
Does the voltage measure near the specified values for each mode position?
Vent 0.2V, Bi-Level 3.0V, Floor 6.0V, Mix-Blend 9.0V, Defrost 12.0V
YES - Go to Step 18
NO - Go to Step 13
13
Test the mode door control circuit of the mode actuator for an open, high resistance, short to ground, or short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 19
14
Test the ignition 3 voltage circuit of the HVAC control module for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 15
15
Test the battery positive voltage circuit of the HVAC control module for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 16
16
Test the ground circuit of the HVAC control module for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 17
17
Test the off blower motor control circuit of the HVAC control module for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 19
18
Inspect for poor connections at the harness connector of the mode actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 21
19
Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 22
20
Repair the ignition 3 voltage circuit of the mode actuator. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 23
21
Replace the mode actuator. Refer to Mode Actuator Replacement .
Did you complete the replacement?
Go to Step 23
22
Replace the HVAC Control module. Refer to HVAC Control Module Replacement .
Go to Step 23
23
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 8
Mar 14, 2017 | Mini Cars & Trucks
The ventilation fan for heat/ac is not working. The fuses all seem the be ok. Any thing else to look for
Did you check the proper fuses for voltage? Some fuses are hot all the time, some go hot with the key on. Even if fuses are good, if no voltage the circuit is still dead. I guess your talking about the blower motor? Can you hear it running? I don't know if you auto hvac or manual hvac? I don't know if your talking about front or rear blower motor?
Get at the blower motor, if two wire connector, that should be voltage and ground. Turn on the hvac controls, check for voltage and ground at the blower motor connector. If good voltage and ground with no blower action, suspect the blower motor.
It is possible to use jumper wires from the battery for voltage and ground to blower motor connector, just for testing to see if blower motor will run, use an inline fuse, just in case.
If you want wiring diagram, I need more info.
Oct 02, 2016 | 2007 Honda Odyssey
A/c blower motor works if I pull power and plug back in until I cut engine off. Then I have to repeat process
Daryl, You may want to check the blower relay/ just switch with one of same type and try and if OK, problem could be the blower motor, wires/plug loose,damaged,burnt or a faulty blower motor resistor. Second link has some trouble shooting of a overheating wire problem, that is to be common in these trucks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY 2003 Silverado Blower Motor Resistor
Sparkys Answers Chevrolet Silverado Blower Does Not Work On Any Speed
03 Silverado heater fan problem ChevyTalk FREE Restoration and Repair Help...
Jul 19, 2016 | 2003 Chevrolet Silverado 1500
Can anyone tell me where the fuse and/or relay is located for the blower motor on a 2005 Buick LaCrosse
First off , does it work on any speed ? After looking at a wiring diagram I find out your vehicle has a Blower motor control processor , a module ! That is your problem ,more then likely !
DEFINITION: The blower motor is inoperative in all speed positions.
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle
  1. Turn ON the ignition, with the engine OFF.
  2. Place the blower switch in each speed position.
Does the blower motor operate in any of the speed positions?
Go to Step 3
  1. Turn OFF the ignition.
  2. Disconnect the blower motor connector.
  3. Turn ON the ignition, with the engine OFF.
  4. Connect a test lamp between the blower motor supply voltage circuit and the blower motor control circuit.
  5. Place the blower motor switch in the minimum speed position.
Go to Step 9
Go to Step 4
Test the battery positive voltage circuit of the blower motor control processor for the following:
An open
A high resistance
A short to ground
Refer to Circuit Testing and Wiring Repairs .
Go to Step 15
Go to Step 5
5
Test the ground circuit of the blower motor control processor for an open or a high resistance. Refer to Circuit Testing and Wiring Repairs .
Go to Step 15
Go to Step 6
6
Important: Ensure that the blower motor control processor connector and the HVAC control module connectors are connected during this step in order to avoid misdiagnosis.
  1. Measure the voltage from the blower motor speed control circuit at the HVAC control module to a good ground.
  2. With the ignition ON, turn the blower motor to high then to OFF.
Does the voltage measure near the specified values?
5 V OFF
1 V ON
Go to Step 10
Go to Step 7
7
  2. Disconnect the HVAC control module.
  4. Measure the voltage from the blower motor speed control circuit of the HVAC control module to a good ground.
Does the voltage measure near the specified value?
5 V
Go to Step 11
Go to Step 8
8
Test the blower motor speed control circuit of the HVAC control module for the following:
An open
A short to ground
A short to voltage
Go to Step 15
Go to Step 10
If your not familiar with trouble shooting automotive electrical circuits I suggest you take it to a ASE certified repair shop !
Jan 07, 2016 | Buick Cars & Trucks
Why does blower on A/C sometimes work and sometimes don't on my Saturn 2007 aura
Blower motor control processor would be a good guess but I'm not in the guessing business , you need to test power an grounds for lose connections or corrosion , check for DTC'S in the HVAC control panel an if none , there are three different diagnostic flow charts from Saturn service info .
Blower Motor Always On Blower Motor Inoperative Blower Motor Malfunction
Myself I'd say Blower motor malfunction flow chart !
Go to Step 2
Does the blower motor operate at the desired speeds?
yes / no
Go to Step 3
  1. Disconnect the harness connector of the blower motor control processor.
  2. Measure the voltage between the battery positive voltage circuit and the ground circuit of the blower motor control processor.
Does the voltage measure within the specified range?
10-14 V yes / no
Go to Step 4
Go to Step 6
  1. Connect the blower motor control processor.
  2. Disconnect the harness connector of the HVAC control module.
  3. Measure the voltage on the blower motor speed control circuit.
4.5-5.5 V
Go to Step 7
Go to Step 5
5
Test the control circuit of the blower motor control processor for a high resistance. Refer to Circuit Testing and Wiring Repairs .
Go to Step 12
Go to Step 7
6
Test the battery positive voltage circuit of the blower motor control processor for a high resistance. Refer to Circuit Testing and Wiring Repairs .
Go to Step 12
Go to Step 9
7
Inspect for poor connections at the harness connector of the blower motor control processor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 12
Go to Step 10
8
Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 12
Go to Step 11
9
Repair a high resistance in the ground circuit of the blower motor control processor. Refer to Circuit Testing .
Go to Step 12
10
Replace the blower motor control processor. Refer to Blower Motor Control Processor Replacement .
Go to Step 12
11
Replace the HVAC control module. Refer to Control Module References for replacement, setup, and programming.
Go to Step 12
12
System OK
Go to Step 2
Good luck , hope this helps !
Jul 11, 2015 | 2007 Saturn Aura XR Sedan
The heater fan just stopped...
Check fuse #14(10amp) located in fuse box under driver steering wheel behind the lower dash cover.
Check fuse#12(40amp) located in fuse box under hood.
Replace fuse(s) if any are blow.
If fuse are good.Check blower and transisto next.
Do steps 1-3 with turn key on
1. Unplug connector and check for 12v at the blue/white wire at the blower motor(2-NAT)
-if there's no voltage you might have a bad relay or open in the wire
-if there's about 12v, go to step 2
2.Plug connector for blower motor and unplug connector for blower transistor(4-NAT). Take a jumper wire and jump the blue/black wire to body ground.
-if blower does not run, replace blower motor
-if blower motor runs, go to step 3
3.check the black wire at(4-NAT) for good ground.
-if you have good ground, then replace blower motor transistor.
good luck
Jan 18, 2011 | 2004 Honda Element
Heater fan will not come on when it switched on.
locate your blower motor.probably under dash rh side, possibly under hood fire wall area pass. side. unplug connector to blower motor.if older style with one wire check for source voltage present at wire, source voltage meaning voltage present at connector should equal batt. voltage.if connector has 2 wires place multimeter on DC volts across both terminals and reading should equal source with fan switch on high.
Dec 22, 2008 | 2002 Suzuki XL-7
Goodman CLQ36AR49 Air Conditioner Logo
41 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
