Question about LG Refrigerators
Handle outside door to open refrigerator has broken need replacement handle (model #lrsc26911tt serial #312kr00157)
Techsim
  • 59 Answers
SOURCE: GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Posted on Nov 07, 2008
SOURCE: Broken refrigerator drawer support pin
I have a Kenmore 2 door,freezer on bottom, mod# 795.77309600,the shelf that holds the crisper draws cracks,front & back corners, also the back,middle. this is the 2nd time for me. Is there a solution??
Posted on Nov 24, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Need owners manual for LG Refrigerator
Your manual can be found and downloaded in PDF format. Hope this helps, Thanks, Sea Breeze
Click link below.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Feb 26, 2009
alex_salve
  • 78 Answers
SOURCE: 2000 Kenmore Refrigerator 10659502993 I am looking for used door handles in white.
please buy new one! please
Posted on May 25, 2009
  • 63 Answers
SOURCE: is there a kenmore refrigerator recall?
The 800 number is available at:
www.techimo.com/forum/imo-community/145834-lg-electronics-sears-roebuck-recall-refrigerators.html
Posted on May 30, 2009
Fix loose door handle on a LG LRSC26911TT
if yours doesn't have the allen screw on the handle, you have to push the handle down(pushing it from the top) you might need a helper because it's really tight. I had a hard time removing those handles
Nov 22, 2017 | LG Refrigerators
Door handle broken off. How do i open the door?
You don't say if it's in or outside handle, either way:
  1. go around the car and open the good door
  2. then you can unlock the broken door
  3. use the inside handle, if gone, use outside to open door,
  4. go buy a new handle and replace it
MDS
Mar 28, 2016 | Cars & Trucks
How do i replace offside rear door handle
You would need to take the pannel off to get to the internal part of the mechanism. Something has broken or come apart in the opening mechanism. I'd let it go if considering replacing.
Mar 05, 2015 | Citroen Berlingo Cars & Trucks
Broken side door handle.
Get a replacement handle REmove door trim to get to the retaining bolts holding the old door handle in place. Replace and reassemble in reverse
Jan 29, 2013 | 2001 Toyota Sienna
Driver side door handle not working. Can open door from inside but not outside...outside door handle must be broken. Remote works to lock and unlock door. Need to be able to get into my car from the driver...
your linkage rod to the outside door handle has disconnected , if you open up the door panel to access the lock linkage rods you will find the rod that is disconnected . There is a plastic bushing the rod is secured with if it is broken you must replace it , if the rod will not stay in place replace the bushing , hope this helps you out
Jul 31, 2011 | 1999 Oldsmobile Aurora
Door handle outside passenger wont open door . but it does open from the inside.
The outside door handle may be broken or may have become disconnected from the rod that allows the door to open. Sometimes the ther is a plastic clip that connects the rod to the door handle and could be broken any parts store will have replacement clips. Whatever the problem is, the door panel will have to be removed to be able to inspect the condition of the door handle and parts attaching to it.
Jan 21, 2011 | 1996 Ford Explorer
I have a 1999 Mercedes CLK 320. The right door (driver's side) does not open from the outside. It only opens from the inside
it's possibly faulty door lock, some time can be broken door handle first check door handle and if it's not broken faulty door lock, need to replace door lock, is this information helped you?
Nov 02, 2010 | 1999 Mercedes-Benz CLK
Need to replace the water filter in someones Kenmore Coldspot (model # starts with 160) but can't see the filter when opening the door. Where is it hidden??
Mine is on the outside of the refrigerator below the door on the right side. It is round with a middle handle to unscrew it. Best of Luck
Mar 10, 2010 | Refrigerators
I have a 2-rear door 2002 Astro. The door handle has broken and I cannot open the doors. Can I remove the handle assembly from the outside, and what parts do I need to make the replacement?
You need to open the door to remove the handle, ask a locksmith to open it with a 'slim jim' then once it is open you can remove the broken handle assembly. Once removed you can see what you need to replace.
Apr 07, 2009 | 2002 Chevrolet Astro
1992 Chevrolet Lumina Euro car door door hard to open
the rod from door handle to latch is out of adjustment
Sep 29, 2008 | 1992 Chevrolet Lumina
Refrigerators Logo
42 people viewed this question
Top LG Refrigerators Experts
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
