No picture on 215tw monitor. appears briefly on start-up then goes
    Sergeant:
  • 243 Answers
When you say appears briefly is it shutting off cause its not getting a signal. have you tested the video card with another monitor to ensure there is a signal. also make sure all the pins are on the connector and none are broke off. also check the settings in the menu on the monitor if you can if you cant and it still goes out. then unit may have a bad pcb or ic board. and youd have to test them to figure out which board was bad.
Posted on Jun 13, 2008
My Samsung SyncMaster 215tw stays in power saving mode with the blue power button flashing and won't turn on.
I'd verify all the cable connections first.
You could be dealing with two different problems, bad monitor, or a bad videocard/pc.
I'd swap the monitor out to verify that the computer is working as it should first. Once you determine that the PC is in fact fine, my suggestion would be to change the resolution on the PC to a lower setting then normal. Once that is done Plug the Samsung SyncMaster 215tw back into the pc and see if it powers on.
If it does not, i'd check the cables and swap them with something else to make sure thats not the problem. If you have another PC available, i'd test the monitor on that PC to make sure that it is not the issue.
After all that you'll come to the determination on what the problem is. Sadly, if the LCD is bad you'll have to replace it as they are extremely expensive to repair and generally not worth it.
However, i'd verify if it is under warranty or not, you never know! you might be able to get it fixed for free :D
Mar 01, 2011 | Samsung SyncMaster 215TW 21" LCD Monitor
When I play some games on my syncmaster 215tw, the screen goes black after 5 minutes. I have to reboot everytime to get the screen back on. The blue light flashes but i cant do nothing until i reboot....
that means your VGA is not big enough to run the game.This problem is not from the monitor but your system.I suggest an upgrade in your system to enhance better performance.
Aug 02, 2010 | Samsung SyncMaster 215TW 21" LCD Monitor
How do I get sound from my new Samsung monitor. Everything works fine.
Here is the user manual: http://www.retrevo.com/support/Samsung-215TW-Monitors-manual/id/278ag702/t/2/
Just get an audio cable with mini stereo phone plugs at both ends, attach one end to the PC audio line out jack (Green), the other end just goes to monitor audio line in jack (green).
Apr 01, 2010 | Samsung 215TW SyncMaster 21" LCD Monitor
Flickers then goes black
Check cable plug, conent it properly
Jul 06, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Samsung SyncMaster 215tw screen goes black after about 1 sec.
I have the same problem its defenitly a problem with the lcd monitor not with the graphics card nor the pc. I hooked up the digital and afterwards the vga connection both had the same result. 1 s perfect screen all visible but than black. pushing the on/off or standby button again shortly 1s the display works than it blanks. Did the same test while connected to a dvd player via the composite video... same problem . Since the previous posts are that old and without a solution I guess there is no hope in getting it fixed.
Jan 20, 2009 | Samsung 215TW SyncMaster 21" LCD Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
