Question about Canon Office Equipment & Supplies
How do I change the toner in my iR2200 - can't get the old cartridge out
Dirty printing
heater unit roller. If roller became old or stitch toner on it, something small scratches. Check it for replacement.
Dec 07, 2013 | Office Equipment & Supplies
Have just replaced Black Toner on Epson aculaser c2800 and now repeated regular pattern of smudges on every page (8 columns and 10 smudges per page)
This is caused by the toner cartridges. The manufacturer change an internal component to save a few coppers and this is the result. Usually only happens when the toner cartridge is old and the 'foam roller' in the toner cartridge starts to get a bit 'sticky' - as happens with some types of foam when it ages.
Two cures for the problem
1. Change the cartridge - make sure it is 'fresh'
2 Find an old cartridge with the old type of foam roller (plain full width) and swap this and its support into the cartridge to replace the new (spiral foam) roller
Nov 02, 2013 | Office Equipment & Supplies
Changed toner---back side now prints dirty with band on the top. Did the cleaning procedure - no luck
If you changed toner because old was empty and now you have this defect with the new cartrige, it is most likley a defective cartridge. Try the old cartridge again, if it prints clean, then you know for sure it is the cartridge. If you purchased a new HP cartridge, get it replaced by HP, they warranty their toners against defects. If you bought a 3rd party toner, return it to where you bought it and get them to replace it. If you had your old toner refilled by someone, get your money back, they don't know what they are doing. This type of defect is often caused by a filled waste toner bin then then runs back out when you print. Some refillers just throw toner in and don't empty the waste toner bin.
Jun 07, 2011 | Office Equipment & Supplies
How to change toner
hi friend,
How to Change a Toner Cartridge You may need to change a toner cartridge when:
  • Your printer tells you toner is out (low toner usually means you can print a few hundred more pages without a problem)
  • The pages coming out of the printer look faded or washed out
  • The pages have a repeating defect of some kind
Users are able to and expected to be able to change toner in black and white printers. (Color printers are more difficult so if you are unsure of how to change color toner call the helpdesk and we will assist you.)
  1. First thing you will need to know is what model of printer you have.
    This will be written on the printer somewhere, there are 2 names that you will likely find on the printer, one is our name for the printer (i.e. ucrit01) the other is the model name (i.e. HP LaserJet 5m). You will need the model name.
  2. Take the model name to the central stores.
    They will be able to tell you which replacement toner cartridge to use. (If there is a problem identifying which replacement to use call the helpdesk.)
  3. Give them your cost center number and they will let you have the replacement toner cartridge that you need.
  4. Take the new cartridge back to the printer and remove the new toner cartridge from the box.
  5. Power the printer off.
  6. Open the top cover on the printer.
  7. Remove the old toner by pulling up and away from the printer. (It should come out with only a small amount of force)
  8. Remove the new toner from its bag, remove the rip strip from the cartridge. This is a small tab on the side of the cartridge that is attached to a plastic film strip. If you do not remove this strip the printer will only print blank sheets. Take care to avoid getting the toner on you when you rip off the strip. Spilled toner is best cleaned up with a dry cloth. If you spill any toner on yourself you can wash it off with COLD water (no hot water as it can cause the toner to set).
  9. Place the new cartridge into the printer the same way the old unit came out (there may be arrows or other cues to help you align the cartridge correctly.)
    It should slide in with minimal force. If it does not slide in easily, make sure you have the cartridge aligned correctly and that you are using the correct cartridge (i.e. 4000 series cartridge is not compatible with the 4100 series printer, you must use 4100 series cartridge).
  10. Once you have the cartridge seated all they way in place, close the top cover.
  11. Power the printer back on.
  12. Print a few test pages
    • If the printouts look good:
      You are just about done, package the old toner cartridge in the box the new toner came in and give it to the mailroom. We get a credit for the old cartridges. Now you are finished.
    • If there is a problem with the test pages:
      Our cartridges are refurbished and sometimes the cartridges can be defective. If you see streaks, repeated defects, faded out pages or other defects that did not exist before you changed, toner it may be because of a problem with the toner cartridge.
      Try getting another new cartridge, installing that cartridge, and printing some test pages. If the printouts are clean, then the first cartridge is a defect, return it to the mailroom for credit.
      If both new toner cartridges seem to have problems call the computer helpdesk. There is likely something wrong with the printer.
Please Note: Toner cartridges are light sensitive if you are going to leave them out of the box or printer for more than a few minutes please cover them to prevent damage
hope this helps u
please rate me........................
thank u for using fixya
regards
sivaranjini
Nov 24, 2009 | Samsung ML 1610 Laser Printer
What does the display read when toner is out, or toner cartridge is out
If this message appears and you can not make any copy, replace the toner
Original Toner CANON C-EXV3 Black Canon iR2200, iR2800, iR3300, iR3320i.
Oct 30, 2009 | Canon imageRUNNER 2200
Black Prints
The toner might be bad, because the old cartridge is working fine.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Jul 31, 2009 | Xerox DocuPrint P12 Laser Printer
How to change a toshiba bd-4560 toner cartridge
Look and see if part of the old toner cartridge is still in the machine.Compare the new and old cartridge and see if the shutter has come off the old cartridge.
Feb 28, 2009 | Toshiba 2060 Copier
Problem with changing the Toner Copier Cartridge
F2 has to do with a toner sensor not working. It could be the replacement cartridge is missing something. Make sure you use a genuine Sharp toner cartridge and that should take care of the problem.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
How to reset Black Toner Empty Message on 2430Dl
There are many problems like that and its not recommended to change toner from one printer to another.
but you should try: put the old toner (emty) in again, then turn off the printer, change toner and turn on printer again.
if thats not helping, then maybe you have a old FW so you can try to update the firmware.
Jan 13, 2008 | Konica Minolta magicolor 2430 DL Laser...
124 people viewed this question
Clive
Clive
old marine
old marine
