Question about Canonical Ltd. Ubuntu
I installed Ubuntu on a 160 gb external hd and it runs fine but now if I unplug the external drive I can not boot into windows. I get a err message " grub" no such file and a lot of numbers. I need to restore or repair the bootloader for windows . As long as I leave the ext.drive plugged in the bootloader comes up and I can select windows and if I dont select windows Ubuntu will load on a few seconds. I want to make windows the default program and load first if I dont pick Ububnu.
    Sergeant:
  • 186 Answers
Https://help.ubuntu.com/community/WindowsDualBoot Check out this link in the section where it talks about maser boot record. Explains grub.
http://helpdeskgeek.com/how-to/fix-mbr-xp-vista/ This link should help you repair the mbr.
Posted on Nov 04, 2010
How to mount volume as Root in Ubuntu 12.04
Re set to XP NTFS then install 12.04 as a second OS.
Aug 05, 2014 | Buffalo Technology Buffalo MiniStation...
External hard drive won't show files
If it behaves like this for multiple computers with multiple operating systems, I would think that the problem is with the hard drive or with how the files were stored. I would recommend trying a free recovery utility:
http://www.piriform.com/recuva
If this does not work, there are professionals who can do this service for you however it is generally expensive.
As a last ditch effort, boot your computer from a free Ubuntu CD (http://www.ubuntu.com/download/ubuntu/download) and see if it recognizes your files.
Dec 13, 2011 | Buffalo Technology Buffalo DriveStation...
I just upgraded my Windows Vista 64-bit computer to Windows 7 64-bit. Backed up all my documents onto a ST3200823A-RK Seagate external hard drive. I have used this HD for 3 years, and it has always...
if you external hdd does not work on any other computer other than yours . try opening it with a linux OS. u can Ubuntu live cd .. boot from it and run it live...connect your HDD .. i hope you can see you files then >>> good luck
Jun 20, 2011 | Seagate 160GB 3.5" External USB Drive 160...
First of all...I'm a new userof Ubunto...I'm trying to install my seagate external network harddrive on a computer with obunto but I can't use the installation CD. How do I do?
Hello Andreas,
Connect to the Internet. You will need access to the Internet to download the install files.
Open your Terminal in Ubuntu. This is the screen with the prompt where you can type commands.
Type "sudo apt-get install Gparted." Type in your root password and answer "Yes" to any prompts.
Type "sudo GParted." This will open GParted.Click the GParted menu and select "Devices." Select your external hard drive from the list. It is important that you choose your external hard drive and not the drive that has your system installed on it. One way to ensure this is to check the capacity on this drive; for example, if your internal disk is 80 GB and your external disk is 40 GB, choose the disk that is 40 GB.Click the "Devices" menu and click "Create Partition Table." Click "Advanced." From the New Partition Table menu, choose an option, depending on your system. For example, if you are dual booting Windows and Ubuntu, you may want to choose MS-DOS. If you are only running Ubuntu, choose GPT.Create a partition. Select a section of unused space and click "New."Set up your partition. For partition size, set the size of your partition--for most purposes, you can make the partition the entire capacity of the disk. Next, choose a partition type; primary is suitable for most purposes. Next, choose a file system. For sharing across a Windows system, use Fat32. For sharing with an Apple system, use HFS or HFS+. For use with an Ubuntu system only, use EXT2, EXT3 or EXT4.Click "Apply." The operations will run and your hard disk will be ready to use.
Apr 10, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
Intel SE7501BR2 cant get it to boot any os except ubuntu, curious that it boots and installs ubuntu have the drivers disk for the board but it wont boot tring to install winxp also it keeps giving me...
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Sep 04, 2010 | Intel Server Board SE7501BR2 Motherboard
I have a Toshiaba laptop which had a hard drive failure , so I installed a new Western Digital Scorpio WD1600BEVS 160 GB hard-drive. When I tried to install Windows OS, the installation failed to detect...
You can install the windows to follow this step.
Make sure that the CD drive is on first boot. When you turn on your laptop you need to press the delete key fast, to access the BIOS. Once you have change the BIOS settings you need to save it. After you save once the laptop detecting the windows CD press the enter key fast also to boot from CD.
Jul 27, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
Windows Vista is not recognizing my drive. It doesn't show up in my compter, and whenever I plug it in and try to access explorer, it doesn't respond, and I have to unplug it to use the window. It works on...
In Ubuntu you use a different File System (ext3). This is very different in relation to FAT32 or NTFS and Windows doesn't have a built-in driver that would enable you to access the disk. That is why it isn't recognized in Windows.
Apr 05, 2010 | Maxtor OneTouch III Mini Edition 120GB...
HD booting in one PC but not in another
Ubuntu works with RAM and CPU Memory instead of a pc like xp that uses Virtual RAM. If the pc that could not load ubuntu doesn't have enough ram to support the reading of the Hard drive and the Operating System then it won't work and Xp will only run on the computer that xp was installed onto the hard drive.
Dec 19, 2009 | Computers & Internet
I was trying to load ubuntu onto a spare hard drive i had lying around. i used my everex stepnote 1500 note book to load the system on to the spare hard drive. now when i turn on my note book without the...
You should install Ubuntu from inside Windows with the wubi program. When you boot you will have Windows as the default boot option and Ubuntu as a second option. Choose the Ubuntu installation to reside on the external drive. You will connect the drive if you use Ubuntu.
If you do not do that, reinstall ubuntu on the external drive and choose to write the boot sector for GRUB or LILO on the external drive, not on the MBR of the primary drive.
Hope it helps.
Sep 12, 2009 | Everex StepNote NC1500 Notebook
Canonical Ltd. Ubuntu Logo
61 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
none
k24674
Jaipal Reddy
Jaipal Reddy
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
