Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Dish washer install
I have a wdb11nrdb1 dishwasher that has two hoses coming out the bottom and i can't figure out where to connect them i have pictures if that would help
    Sniper:
  • 114 Answers
One hose should be smaller and the other hose should be considerably larger.
the smaller hose is the water in (attach to the hot water side of your faucet, and the other hose is waste out (hooks to the drain or sink disposal).
Posted on Jun 13, 2008
Dish washer wont empty out leaves about 2 or 3 in in it
Drain hose clogged or Not ran in the proper draining position, under the sink where the hose ties into the drain system or garbage disposal, the hose should be higher than the connection point, I have fixed this by tie strapping hose to the bottom of the counter or sink, hope that helps ?
Feb 27, 2015 | Kenmore Dishwashers
After the last wash I noticed the bottom of my dishwasher (Whirlpool quiet partner 2) was filled with water. After unloading the dishes I closed the dishwasher and pushed the Cancel/Drain button but the...
1.Check the drain filter for clogging.
2. Check the drain hose. Remove carefully to avoid water spill.
3. Check whether flows freely from the hose.
4. Check the drain valve if possible for you.
Sep 15, 2010 | Dishwashers
My ge potscrubber 650 is leaking onto the floor in front of the dishwasher. What is the likely problem?
Check you filter and screen .Check whether you need an replacement for them.
If you dishwasher has foam coming out from under the door, then the problem is that dish soap somehow ended up in the dishwasher or excessive rinse aid . It is not recommended to prewash the dishes before loading them into the dishwasher as only a small amount of dish soap can cause the sudsing that you experienced. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used. Spilling rinse aid while filling the dispenser will cause sudsing also.
To clear the suds from the dishwasher sprinkle several tablespoons of non-dairy coffee creamer over the suds. The fat in the creamer will help break down the bubbles. Wait five minutes for the suds to lessen.
Many pump leaks happen around the seal on the pulley. Some pumps have a weep hole that lets water drip out when this seal begins to go bad. The solution is to rebuild or replace the pump.
You'll want to confirm that the fill hoses are connected and properly tightened. Always use new rubber washers when re-installing the hoses. Take care not to over-tighten the connection. Other leaks may be caused by the drain hose being cracked, or by a leaky connection at the water-inlet valve. Too many suds may cause the appearance of a leak when actually it's just a sudsy overflow. Sometimes a drain hose leak occurs at the end of the hose where it attaches to the washer. If the hose is long enough you can cut the leaky end off and re-clamp the hose back on. Usually though, when a hose begins to leak, it is best to just replace the hose.
Sep 10, 2010 | Dishwashers
New dishwasher installed and heating element is not heating and get no hot water. Hose and electrical are connected.
on the bottom of your dish washer you can check if the heating element is getting power, if not you have few thermostat next to it (they might be disconnected from the instalation) or they might burn. check them when the power is off for continuity...
hop it help ...let me know
Jan 11, 2010 | Dishwashers
Kenmore Elite Not cleaning dishes
You might want to check where the hose from the air gap connects to the disposal there is a plug that has to be removed to allow for the washer to drain.
Mar 15, 2009 | Kenmore 24 in. 17303 Built-in Dishwasher
Dishwasher Not Draining
In many cases the connection were the dishwasher connects to the disposal or sink trap will become stopped up with a build-up from materials from the dishwasher. With the dishwasher turned off disconnect the drain hose from the washer and sink connection. run an object through the connection going to the trap or disposal ( after shutting off power to disposal and clean out build-up. Shouldn't take over 30 min.
Froggman
Jul 22, 2008 | Frigidaire Dishwashers
No water is coming out of the spout in the dishwasher
I am experiencing the same problem on my kenmore dishwasher (model: 665.1702). there appears to not be enough water spraying out of the washers as the soap is still in the dispenser at the end of the wash and the dishes are dirty. I've tried removing the bottom washer but can't figure out how to remove it. Did either of you find a resolution?
Dec 02, 2007 | Kenmore 24 in. 17669 Free-standing...
LG Dishwasher - drain hose replacement
Hello, I have just installed a similar model, and took the side panel off to see how it was put together ;)
The drain hose goes in the back of the dishwasher, then loops up the right side (as you are looking at the front)(this is to act as a "trap" to keep sewer gases from coming back into your washer, I assume), and then connects to the drain pump under the washer.
In order the change the hose, you will need to remove the left side panel, and the bottom panel, and this will give you access to the entire hose....
Hope this helps!
Nov 26, 2007 | LG LDF8812 Stainless Steel Built-in...
Water draining is premature
In my case, I had the same problem until I realized the drain hose was not looped high enough. Once I looped the drain hose higher than the dishwasher, the problem went away and it washes dishes perfectly.
When the drain hose is installed too low, the water in the machine will only stay as high as the hose is installed because of the laws of physics.
The same applies to laundry machines - that is why the drain hose is set to drain from a higher point than the drum of the washer.
Good luck and Blessings!
Apr 26, 2017 | Kenmore 17252 Free-standing Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
85 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
