Question about Car Audio & Video
Pioneer DEH-2000MP Radio In 2001 Chrysler T & C
I've removed the OEM radio from my 2001 Chrysler Town & Country and have installed a Pioneer DEH-2000MP radio. I've connected all of the wiring, but there is no sound. The radio powers up and the display is on. Same results with a CD. Don't know where to go from here. Any suggestions?
  • Don Elsass
    Don Elsass Jun 14, 2008
    I'm using 2 adapter cables, but there is a single wire labled "amp" that was plugged into the original radio, but no place for it on the Pioneer.
  • Diego Diaz Apr 28, 2012
    did you fix the problem?
    Genius:
  • 1,036 Answers
Hi there!
It is possible that the original connectors are wired differently to the new radio.
Find the speaker cable colour on your vehicle, and match the pins to the connectors on the radio. This may be given in the manual.
You may need a conversion cable for fitting. These are readily available.
Hope this helps you.
Posted on Jun 14, 2008
    President:
  • 2,712 Answers
Make sure that the speaker wiring is correctly connected. Please see the instruction manual that would have come with the Pioneer deck for correct wiring instructions first. Check that first and let me know..
  • Swilin Sampson
    Swilin Sampson Jun 14, 2008
    Well, if the AMP is not wired, then obviously you wouldn't have any sound. What you need is an adapter harness. I would recommend this one:
    http://www.logjamelectronics.com/pacc2rc...
    that should resolve your problem. If you found my answer helpful in any way, kindly take a moment to "Accept" my solution. Thanks.
2 Suggested Answers
SOURCE: No Sound After Installation
How do i set the clock on the radio?
Posted on Jul 02, 2008
It was working fine I shut the power off and just had the radio playing then turned it off for a few minutes and the car wouldnt start so I had to get a jump now my radio wont work its a pioneer...
Check the fuse panel under your dash, & there may be a fuseable link in the ignition wire behind the stereo also, somtimes when you get a jump it can pop a fuse or 2.
Feb 26, 2011 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Remove a 2004 focus stereo and replaced it with a new stereo
purchase the following: ford radio removal tools installation kit wiring harness the included instructions will make it a simple process.
May 19, 2010 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
After reconnecting the car battery, the radio would not turn on
The pioneer has a small protection fuse in the back of the radio, alot of time when it catches a power spike, it will blow to protect the head unit. It should be plugged in the back of the radio under the main plug. Hope this helps.
Aug 20, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Power to pioneer deh-2000mp will not turn on
MOST OF THE TIME THE CONSTANT CAN NOT BE HOOKED UP TO THE SAME WIRE AS THE POWER WIRE, U SHOULD HAVE A WIRE IN UR HARNESS THAT IS YELLOW USE THAT WIRE, IF U DONT FIND A FUSE INSIDE UR CAB USE THE FUSE AS A CONSTANT POWER LEAD BUT PUT IT ON ONE THAT CUTS ON WITH THE KEY.
Jun 17, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
New Radio too powerful for 15 Watt speakers?
Hello mike_mccuske,
The OEM speakers will still work OK with your new Pioneer. Just don't turn it up too loud. Of course you'll get improved sound if you replace the speakers. Your Pioneer's RMS power is 14 watts, and the peak (maximum) power is 50 watts. The door speakers in a 2000 Honda Civic are 6.5" and you can get a set of Pioneer speakers, the TS-G1642R's, from Crutchfield for less than $50. Their RMS power range is 2-30 watts and they can handle a peak power of up to 180 watts.
Hope this helps.
May 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Radio stop working after battery change
If your radio is the pioneer model stated, it definately has a fuse!
The little black box on the yellow wire contains a fuse.
If there is no black box on the conctant power, you may have damaged the radio with a voltage spike(s) when connecting the battery posts.
Jan 09, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Try taking a wire from one of your speakers and tapping it to any ground/
Jun 14, 2008 | Car Audio & Video
Having trouble settimg clock on cd car stereo
how to set clock for a pioneer deh-27mp
Mar 24, 2008 | Car Audio & Video
Car Audio & Video Logo
303 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
