Question about Bosch Classixx WFC 2465 Front Load Washer
Does not wash clothes
When the drum is loaded and machine switched on - only the drum turns and no furthr action takes place. The soap powder and freshner are still in their compaertments.
  • Anonymous Mar 31, 2014
    soap powder not dispersed from plastic ball, drum not turning and clothes smelly. Belt looks okay and water is emptying
  • 1,294 Answers
Your inlet valve at behind top of machine is defective; or the pressure from your faucet is insufficient.
Close your faucet valve on wall & unscrew your hoses to check screens on hoses & machine. Clean out well. See that the water pressure is good. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done.
Sites for spares: (which is good)
Posted on Jun 14, 2008
My washing machine does not clean clothes properly and washing powder residue is left after wash on clothes I have Daewoo Dwd F1243
start a wash with a load and after he machine fills with water check to see if the drum rotates this is usually the problem if you get powder residue on wash with no drum action the powder does not disperse also check to see if the machine spins if it does check belt tension if not check belt tension and motor brushes
Mar 04, 2014 | Washing Machines
Zanussi aquacycle 400
all washers have water level sensors and most of them are fitted with water level via filling a tube with water the switch is activated telling the machine to turn off the water
most of the time the tube gets clogged up with soaps etc.,
clean the tube and check the operational of the switch .
Nov 24, 2017 | Washing Machines
The whashing comes out with white powder like stuff. Can I clean the drum and if so how ? is it flint that gathers some where?
Hello Sir Tommis,
I understand that you are having a problem with your washing machine. When you wash clothes they come out with a white powder like substance on them. This white powder substance is the powder laundry soap that you are using.
This is generally caused by adding to much soap and clothes to the washing machine. The soap is not getting dissolved and the clothes do not have enough room to agitate in the machine. Try to put 3/4 of the amount of clothes in the washer with the same amount of soap and see if the clothes come out with the same powder like substance on them.
The clothes that currently have the soap on them will have to be hand washed with a scrub brush in oder to get the material off of them as running them though the washer will not remove the soaked in soap.
Thank you for choosing
Mar 26, 2011 | Whirlpool 3.2 cu. ft. Washer
I bought the Samsung 8 kg Top Loader (Model: WA80V3WIP) a few weeks ago. I only use cold water and bought the yellow packet of Sunlight washing powder, which specifically says on the packet that it works...
As with any top-loader, the soap drawer will deposit the entire soap load on one spot within the first few seconds of water fill. When the water starts running through the soap drawer, the brakes on the drum are released, so you can manually rotate the drum to disperse the soap over the load surface, thus eliminating the concentrated spots. Also, you may save the duvet, as the white marks are most probably dried soap powder which can be removed with a damp cloth wiped over the area.
Oct 19, 2010 | Samsung SW62ASP Top Load Washer
Smelly washing machine and washed clothes
This is usually because of a bacteria build up on the machine. Suggested actions: Remove and thoroughly clean the soap tray. Remove the waste pipe from the drain pipe you have it poked into and ensure that all is clean and emptied. If your machine has a filter (Usually behind a 4 inch square door on the front towards the bottom of the machine if one is fitted - this depends on the machine and I'm sorry, I'm not familiar with your madel). Finally, take 2 or 3 DISHWASHER TABLETS put them in the machine's drum and wash at the highest temperature that your machine will allow. Modern biological washing powder uses bacteria to break down and "eat" stains. Bacteria creates unpleasant odours. Dish Washer tablets and powder is designed to kill bacteria. Hope this helps
May 12, 2010 | Washing Machines
Smelly front loader washing machine. Clothes come out smelly too. How did I fix the problem???
You may have to do this 2 times and you will never find this in any manual. Use 1/4 cup "Powdered" Dishwashing soap and 1 cup of bleach in an empty tub cycle. Run a load of older dark clothes or non flammable rags FIRST after doing this the first time. If they come out with streaks run the cycle of 1/4 cup Powdered dishwashing soap and 1 cup bleach again. Same routine after 2nd cleaning cycle... dark clothes check for anything out of the ordinary. You should not have to do it a 3rd time unless your machine is really gunked up. Hopefully your using HE type soaps in your front loader. Non HE laundry soaps will cause the smelly machine also.
Thanks for using FixYa.
Mar 29, 2010 | Washing Machines
take out powder compartment its more likely its gone all black....also in side of the machine... get white vinager clean all inside and powder capartment .... put 2 ltrs of white vinager in drum place powder unit back were it should be..... turn machine on with no cloths in on full heat wash (boil wash)....wash through again with powder when finished ....twis before putting any cloths in ..there you have it ...oh check pump filter befor all this :)
Dec 30, 2009 | Bosch WFL 2063 Front Load Washer
Clothes do not smell fresh and have a distinct smelly odor after washing. I think it may be the water filter or something to do with the water coming into the washing machine. Need help.
put your weasher on with white viniger on its own. also take your soap draw out and make sure that is free from powder as some times there is a back up of powder going in to the drum
Jun 26, 2009 | LG WM2277H Stainless Steel Front Load...
Soap in LG
Hello, to answer your question, it depends. Are you using liquid detergent or powder? How dirty are your clothes? How bulky are your clothes?
For average size clothes and normal dirt I use about a cup of powder. If the clothes are dirty and/or bulky I just hit the "water plus" button. These machines are so efficient you don't want too much soap, just add water.
If your using liquid make sure it's approved for front load washers and use it sparingly. The most I have put in is about half up on the dispensing cup in the washer. Remember to remove this if your using powder. Any more questions just ask. Good luck.
Jan 23, 2009 | LG WM-2277HW Front Load Washer
Clothes smell after wash cleaned filter still clothes smell
set the machine off on a 95c wash with no clothes or soap in, the most likely cause is a build up of soap scum on the inside of the drum, also try to alternate between washing powders and liquid tablets.
hope this helps
Jul 25, 2008 | Indesit Washing Machines
Bosch Classixx WFC 2465 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
