Question about Maytag Washing Machines
My son put in a full load, water started to fill up and then everything stopped. I then removed his load, manually scooped out all the water, opened the top panel, located the fuse which vaguely showed 1A 250V (not clear at all), removed and replaced it with a new one, but when I plugged in the power cord, nothing happened. Checked the new fuse and found out that it's blown off again. it seems like something shorted, but what can it be???? (motor??, switches???) Any suggestion? Thanks in advance for your kind help.
    Genius:
  • 2,035 Answers
There could be short in the motor or the control as the  water may have short  it please get it check ........Please mention the model number and make....
Posted on Jul 08, 2008
    Master:
  • 848 Answers
There is some short circuit inside the board which might have caused to blow the fuse ..... better check the entire board with proper technican
    Master:
  • 788 Answers
See here: http://www.applianceaid.com/mayfuse-switch.html
There seems to be a common problem with Maytag washers where the lid switch becomes faulty and continues to blow fuses. You should get the lid switch kit for your washer and replace it. If you provide the model number of your machine I can help you find a source for the part.
  • Maytag Master
  • 19,396 Answers
If the control panel fuse keeps blowing then you need to replace the panel.
    Master:
  • 638 Answers
The power supply is not perfect 100% definitely
Posted on Jun 13, 2008
  • hemant somaiya
    hemant somaiya Jun 13, 2008
    rate the solution as fixya.
  • hemant somaiya
    if the wet board is not perfectly dried every thing will get short.call the proper technician and get it repaired now .the problem is simple. it will hardly cost u any dollars. good luck.
    Master:
  • 555 Answers
Bad fuse? Ensure that the right fuse was replaced.
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
Won't fill
Try putting the clothes in and filling it with a bucket via the top opening (Cold water will do)
If it starts and washes then it is the fill valve which has gone faulty , if you put in the normal fill level and then exceed by say another bucket full, that indicates it is the pressure switch.
Ps
You might try taking the fill hose off the back of the amchine and clean out the small filter which is just inside the opening
Jan 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
My washer fills the tub, but when it goes to next cycle just hums
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Thanks
:D
Jul 20, 2009 | KitchenAid KAWS850L Top Load Washer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Washer fills till flooded
change the fill valve located where the hoses hook up
Dec 29, 2007 | Washing Machines
Washing Machines Logo
156 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
