Question about Fellowes PS70-2CD Shredder
Fellowes PS-70 Shredder jam
I fed in too many sheets at one time jamming the unit. Now the light comes on but it does not go forward or backwards so that I can remove the paper. I have taken the screws out to attempt to manually move the shredder rollers but they will not budge. So...I wondering if the unit isn't making any sounds whether it is dead? Any ideas?
  • Anonymous Aug 22, 2008
    I am currently going at it with an awl and a pocket knife. I've used these tools before, but this time it is taking over an hour. I am in the market for something with a release mechanism. Suggestions?
I used needle-nose pliers and regular pliers to pull out all of the jammed paper -- it took an hour but I finally got it. I never did find a release mechanism even after I took the top apart. Thanks anyway!
Posted on Jun 14, 2008
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Shredder stopped working lights come on shredder doersn't not jammed
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Apr 21, 2014 | Fellowes Powershred PS-60 Shredder
Fellowes C220 Shredder Jam
First unplug shredder. You can remove the top and start removing paper. It can be quite time consuming. I can't remember if this model uses plastic paper strippers or not. If it does, they may have broken when the shredder jammed. They strip the paper from the cutters.
Jul 07, 2009 | Fellowes PS70-2CD Shredder
Fellowes PS60 CC shredder jamming
You have guides or cutter assembly out of alignment. Take it apart and double check before reassembling.
Jun 09, 2009 | Office Equipment & Supplies
Red Light on, but no jam
Your problem is probally with the safety interlock switch on your machine. On the PS-65c It is located on the right hand side of the unit. There will be a tab of plastic on the inside lip of the basket that goes into a slot on shredder head. If plastic piece is bent or broken machine will not operate. If it does not appear broken make sure when you put shredder head on that it fits flush all the way around on the basket. If none of this helps contact Fellowes Customer Service at 1-800-945-4545 and we will be glad to assist you further.
Jan 28, 2008 | Fellowes Powershred PS-65C Medium-Duty...
PS-70-2 not working
Make sure the pull-out wastebasket is all the way in. Also, make sure the basket is less than half full. A paper jam could also cause this symptom.
Jan 22, 2008 | Fellowes P70CM Shredder
Fellowes PS70-2CD Shredder Logo
1,652 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
