Question about HP Pavilion dv6000z Notebook
Receptacle where battery charger plugs in is loose. Computer loses power when the batteries are removed.
  • 707 Answers
Yeah I have a 7000 (well built, still hummin' along), they're pretty sturdy machines. Mines taken a real beating (it actually bent the adapter plug!) so in my view definitely worth fixing. They just don't make them like that anymore. Anyway, it (the connector), probably has come loose from the motherboard and needs re-soldered, or maybe a loose mosfet. A good tech could fix it in a snap so ask around about fair pricing repair shops. Not much of a surprise to you I'm sure but I hope I convinced you to keep the machine. You should see it burn rubber with a Linux Mint OS on it...BLAZING FAST!!! Boots in 22 seconds. Faster than my quad core desktop. Sorry...I get all mushy...lol Good luck!
Posted on Nov 04, 2010
My device will not come on
Things to check:
1. Make sure that your car receptacle has +12VDC. Try another device to confirm.
2. Make sure that the car charger is working properly. Most have a fuse in the tip. It could be blown. It may not be converting +12VDC to +5VDC which is required to power the GPS. Try another charger with the GPS.
3. Common problem with the 25xx series are loose/broken USB charger ports. This will prevent the unit from powering up with an external power source and will prevent the battery from being charged. Eventually the battery will lose its charge and since the USB charging port is loose, the battery will not charge and the unit will appear dead. More info here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 03, 2016 | Garmin nuvi 2597LMT 5" GPS Navigator -...
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
8.5 kohler generator battery dies often
Check the battery charger whether an external one is installed or the optional one ion the transfer switch. Measure the voltage on the battery it should be at least 13.8V if it is only 12V then the charger is suspect. Also if it is an external charger plugged into a receptacle make sure that the 120V receptacle is hot (GFI's) tend to trip in a storm
Sep 18, 2013 | Kohler 12 kW Emergency Power System -...
Low battery warning
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Fix a Broken Laptop Charger
If your laptop charger seems broken, it's most likely because the battery will not charge.
You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly.
When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop.
It should fit firmly in the DC jack without wiggling.
If it is loose, use electrical tape to hold it in place so the charger can receive power.
This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury.
A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible.
Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open.
The battery should pop out; give it a tug if it doesn't.
Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors.
Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery.
Slide the latch to secure it and plug in the power cord to test it.
See if the laptop powers on with the charger only and battery removed.
If it does, the battery is the likely culprit and should be replaced.
If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number.
Call the laptop manufacturer for a replacement charger or search for the part number on eBay.
If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems.
Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Acer laptops allow you to take your work and entertainment on the go.
You can work on a presentation during a long flight or watch a DVD in the middle of a park.
Acer laptops can do this because they are powered by batteries, allowing the laptop to run without having to be plugged into a power source.
Normally, the battery can be recharged by plugging the laptop back into a power socket.
But certain problems can keep the battery from charging.Electrical Connection
For laptops to charge, they need to be connected to a power source.
Although it may look like you have the cable plugged in correctly on the Acer, make sure that the cord is firmly plugged into the power socket.
There should be a light on the Acer keyboard as well as a power symbol on the taskbar for your operating system that tells you whether the laptop is running off electrical or battery power.
If it is plugged in, make sure that this icon shows that it is on electrical power.
Also check the socket where the Acer is plugged in and make sure that it isn't turned off at the main circuit breaker.
Battery
Turn the Acer over and make sure that the battery is properly placed in the battery compartment. Most laptops will have locks that keep the battery securely in place.
These locks can sometimes come loose.
Use a piece of strong tape as a temporary measure to keep a loose battery in place.
Clean the terminals on the battery to ensure that there is a good connection.
Remove the battery from the battery compartment.
Apply rubbing alcohol to a lint-free cloth. Rub this cloth over the shiny metal terminals on the battery.
Over time, batteries lose their ability to be recharged.
If neither of the aforementioned steps works, you may just have a bad battery.
Check with Acer or other vendors to find a replacement for your model.
BIOS Update The BIOS (Basic Input Output System) controls a number of basic functions for a computer, such as assigning the hard drives and other system functions.
The BIOS also controls the battery charging function.
Certain Acer models have a bad BIOS that operates the computer normally but doesn't charge the battery.
To solve this problem, you need to perform an operation called "Flashing the BIOS" where you download a new version of the BIOS and upload it to your Acer.
Check on the Acer support site to see whether your computer model could possibly be affected by this.
Adapter
The power adapter, the part that plugs into the Acer from the power socket, can go bad.
Check for a power light on the adapter.
If the light is not lit, you probably have a bad adapter.
Replacement adapters can be purchased from Acer or other online vendors.
http://support.acer.com/us/en/default.aspx
http://www.solarum.com/2010/01/03/acer-aspire-battery-not-charging/
Jul 14, 2013 | Acer Computers & Internet
My e525 emachine doesnot charge i plug the charger it work when i remove it it turns off
If the charger or power brick is able to power up the computer and you can use your computer but it does not charge the battery, then the battery is most likely faulty. They only last a few years, slowly loosing their ability to power your computer until they die.
Remove the battery and plug in the power connector into your laptop computer. Power on your laptop, if it powers on and you can use it, then you need a new battery.
Contact a computer store for a replacement battery.
Take care!
damnor01
Jun 30, 2011 | Acer eMachines 520-2890 Notebook
I have a Gateway T-6330u notebook. I have had problems with the battery cord before where it plugs into the computer. A piece broke off from the battery cord and was stuck in the computer. I talked with...
Seems more like a problem with the power receptacle where you plug the power cord into the laptop.In order to fix this problem, you will need to disassemble the unit to get access to the motherboard & replace the power receptacle with a good one.
Dec 29, 2010 | Gateway T-6330U Notebook
I HAVE A JET 3 ULTRA CHAIR, WE LOSS THE 24V PRIDE JET 3 Ultra Power Chair Smart Battery Charger, CAN WE USE A COMPUTER CABLE INSTEAD IF NOT WHAT CAN WE DO.
You can use the AC charger cord from a computer as a replacement for the AC cord of the charger. If the AC cord plugs into the wall and plugs into the charger or charger receptacle on the back of the power chair, you can use it.
If I remember correctly, This chair has a 4 Amp on-board charger which has an AC receptacle on the back of the chair to plug in an AC cord. The off-board chargers take a universal AC cord which will work with a universal computer AC cord. If the AC cord plugs in, use it.
Nov 25, 2010 | Pride Mobility Products New Pride Mobility...
Battary not charging
I have experience this problem myself however replacing battery and charger does not fix the problem. it seems to be something related the power receptacle (where you plug the charger in the laptop) the solution is to replace the part, but that can be expensive
what i did, as a workaround, is to plug firstly the end of the charger that goes into the computer and then connect the charger to the outlet this for some reason makes the battery charge.
hope it can help you
Oct 29, 2010 | Dell Inspiron 1525 Notebook
How can i charge my onboard battery offboard? ineed to take the batter off and charge it indoors
Keith You have to remove the seat from the scooter and then lift the battery pack out of the frame. On the front of the battery pack there should be a charger port where you can plug in the charger into the battery pack when you are inside. Plug your charger into the battery pack first then plug it into the receptacle. When fully charged unplug from the receptacle first then unplug it from the battery pack. In other words always have the charger unplugged from the power when plugging and unplugging it from the battery pack. Velcro is holding the pack down so you might have to give it a good yank to get it off the frame. Hope this helps
Oct 20, 2010 | Pride Mobility Products Go-Go Elite...
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
HP Pavilion dv6000z Notebook Logo
153 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
