Question about HP Photosmart 8250 InkJet Printer
I had a paper jam which I was able to fix, but now the cartridge cable is stuck and it won't move.
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Often a carriage jam turns into a paper jam. Here's the solution for carriage jams.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00738923&cc=us&lc=en&dlc=en&product=443024&tmp_track_link=ot_search
Posted on Nov 04, 2010
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
Cartidges wont move
the cartridge as you call it is the carriage, which houses the inks and printheads, Its supposed to be 'Locked' at the service station until such time as the printer is ready to start printing,
what you should look for is a strip of what looks like clear plastic that runs the lengh of the print surface, give this a GENTLE clean with a cloth damped with WATER, ensure there is no paper blockage along the print path the cycle thhe power allowing the machine to come to ready or fault displayed
Mar 09, 2014 | HP OfficeJet Office Equipment & Supplies
Printer alarm light flashing
Sometimes the paper is squashed and stuck in an area that may not be obvious. You may have to remove the cartridges to look closer to see if paper is in fact stuck in the platen. In my experience, when it says there's a paper jam, there is usually paper jammed within the platen or roller.
Jan 20, 2014 | Canon PIXMA Office Equipment & Supplies
Ink cartridges stuck on left side of carriage. Won't move. Tried all of the suggestions and still says carriage jam.
it will be stuck in roller cleaner mode, that is mechanical. the only real way is to push it thether over to the left. with the power off the printer, then close the compartments and turn on the printer it can take 2 o3 goes as it will try to move it right. you have to get it off the clip that is holding it there. the cartridge is held in place to stop it moving while the roller is cleared.
Jul 03, 2017 | HP OfficeJet 7410 All-In-One InkJet...
Lexmark 2400 series: the ink cartridge doesnot move across. The power light blinks. computer says there is a paper jam but there is not paper jam.
Hi
Open the back and front door and see the properly a small piece of paper make a error of paper jam, after that move your cartridge panel by hand, and check the cartridge fix properly, if cartridge not fix properly fix the cartridge and try again to print.
Thanks
Sep 02, 2011 | Lexmark Office Equipment & Supplies
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    Paper jam cleared but wont start
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step five . Do not try to force it to move if it is hung up on something. NOTE: Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage moves freely, skip to Step five .
    3. Remove the print cartridges.
    4. Gently move the print cartridge to the far right of the printer.
    5. Remove the paper from the paper In tray, but do not remove the drawer.
    6. Remove the rear access door.
    7. With your fingers, rotate the rollers "up" three full rotations.
    8. Push the rear access door back into the printer until it snaps firmly into place.
    9. Replace the print cartridges.
    10. Plug the power cable into the HP All-in-One.
    11. Turn the power on.
    Step five: Reload and test the printer Once the jammed paper is removed, verify that the printer is still functioning properly.
    Step six: Service the printer Perform all the steps mentioned above. If problem persists, service the printer.
    Oct 31, 2010 | Epson Stylus Multifunction Inkjet Printer/...
    It starts printing, then stops, the printer cartrige is jammed
    Try emoving the duplex cartridge on the back (return printer to it's original configuration) and try printing. If the printer prints OK, then re-attach the duplexer checking for anything that could interfere with the print cartridge.
    If the printer doesn't print, then I suspect something has fell into the printer and is creating enough resistance for the printer to detect and report. Turn the printer off, Remove all the cables from it. Try inverting the printer and gently shake it to see if anything falls out that could be jamming the printer cartridge.
    Jun 02, 2009 | HP OfficeJet Pro K8600 Printer
    My printer deskjet f2100 is showing a paper jam (red light showing on control panel) how do i fix it?
    folow the steps below 1. Check for and remove any paper stuck in the paper in tray
    2. clear the paper jam from the back of the printer
    a. unplug the AIO
    b. Press in the tab on the left side of the rear door to release the door. remove the door by pulling it away from the AIO
    c. gently pull the paper out fo the rollers
    d. clean the rollers with a lint free cloth that is moist with distilled water
    3. Lift the front cover and slowly remove any jammed paper
    a. unplug the power cable
    b. if necessary pull the input tray down to open it. then lower the print cartridge door
    c. gently pull the paper out of the rollers
    d. close the print cartridge door
    e. plug the power cable
    4. Verify that the print cartridge carriage can move freely
    b. check to see if the print cartridge carriage can move freely from one side to the other.
    c. remove the print cartridges
    d. gently move the print cartridge to tyhe far right of the printer
    e. remove the paper from the paper in tray, but do not remove the drawer
    f. remove the rear acces door
    g. with your fingers rotate the rollers "up" three full rotations
    h. close the rear access door
    i. replace the print cartridges
    j. plug the power cable
    k. turn the power on
    5. reload and test the printer
    hope this helps
    Nov 14, 2008 | HP Office Equipment & Supplies
    Paper Jam in HP Deskjet F2100 All in One
    a. unplug the AIO
    Aug 06, 2008 | HP Office Equipment & Supplies
    HP Photosmart 8250 InkJet Printer Logo
    95 people viewed this question
    Clive
    Clive
