Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Water Leakage We have a Bissell Proheat (Pro Tech). I don't think it is the 2X model. When releasing the water with the knob on the handle, water comes out the side of the housing at the lower part of the unit. Is their a seal that my be worn out or broken. Can you give us some ideas before we take it to an expensive repair man to fix
Check the water bottle. Ours has been doing the same but putting a bit of j cloth between what they call the o ring and the cap fixed it. Really you need a new bottle assembly
Posted on Jun 22, 2008
Can't get the water to spray and the red star is not turning
DIY - Fix your bissell if it doesn't spray solution any longer ...
? 5:33
https://www.youtube.com/watch?v=SLyDeM10k9k
Feb 6, 2010 - Uploaded by kronomarine
Common problem with most Bissell Carpet Cleaners is that it stops ... to no one repeats my mistake, this is NOT the Bissel Proheat 2x Turbo Model .... water go back to use 8 months later and now it only sprays water ... I can't understand ANYTHING said to me by the Bissell reps in India or .... Get video URL.
All comments on DIY - Fix your bissell if it doesn't spray ...
Nov 28, 2015 | Bissell 7920 ProHeat Pro-Tech Upright...
I can't turn the soap/water selection knob...
Hi Vicki. I understand how frustrating it must be not being able to turn the knob. You may want to have a tech at one of our Authorized Service Centers inspect your machine.
Here's a quick link to help you locate one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Jun 22, 2013 | Bissell 2X Proheat 9200 rug cleaner
Bissell proheat 2X did not **** back up the dirty water
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 12, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell pro 2x the cleaner solution & water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
shg
Jul 11, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell pro heat 2x not releasing water or cleaner
heatman101
bxnbx
Oct 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell won't release soapy water solution
heatman101
hjf
Nov 14, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont release liquid or shampoo.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=601973
Won’t release liquid or shampoo.
Posted by lilmrsmcd on May 16, 2008
I have a Bissell Pro Head 2X Steam Cleaner Model # 9300-C
The little plug at the bottom of the bad for clean water came apart and would not let water out now won’t hold it in.
Inside is a little propeller a spring a washer and a little black plug. Flat on one side and beveled on the other. We have tried to put it back in various selection and cant fix it please help ASAP liquid bladder will not release water.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. On the little black plug – they do wear out and need to replace it but use a genuine Bissell part when replacing the part other wise a replacement may not work. Q. #2 the little propeller spring usually is part of the solution tank and it is wise to replace the part with a new or a good used tank from Bissell, so check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 16, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissel Proheat 2x "catches" when it is pushed forward-- Help Please!!!!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=499675
Bissell ProHeat 2x "catches" when it is pushed...
Posted by Marlene101 on Apr 08, 2008
My ProHeat 2x bucks and catches when I try to push it forward-help!
The Bissell is not designed to be like a vacuum – it is designed to clean on the pull back, you dispense the Bissell cleaning fluid, the brushes scrub the carpet and the suction will vacuum up the excess water, the push forward will do the reverse action. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
No water
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=467200
No water
Posted by Emma Ann on Mar 25, 2008
My Bissell ProHeat 2x and it's not spraying any water out.
This could be that you have a defective water valve assm below the water tank or the trigger assm is not working properly or not connected. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owners manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Don – The Vac Man
Go Ahead. Use Us.
Mar 25, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
Top Bissell Vacuums Experts
JDFFEMT
Level 1 Expert
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
