Question about Whirlpool Washing Machines
Whirlpool awm 5130. the filter is stuck! - Whirlpool Washing Machines
4 Suggested Answers
hemantraj
  • 638 Answers
SOURCE: Whirlpool AWM 6145/3 gets stuck
the problem is solved in this link
www.applianceaid.com
Posted on Aug 29, 2008
  • 119 Answers
SOURCE: How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Posted on Apr 26, 2010
Bruce Boogie
  • 242 Answers
SOURCE: scheme to replace the bearings whirlpool AWM 5130
Are you ready for a big job?
It means taking the machine right down - drum out and spider off.
If you think you have the skilss and can get the parts locally - check that you can get the bearing - you might need a complete assembly.
If you can get all the bits and still feel up to it - get back to us.
GOOD LUCK
Posted on Mar 10, 2011
I require an operation manual for a Whirlpool AWM302
The Whirlpool UK site has support for the AWM 302. The direct link to the manual is http://docs.whirlpool.eu/_doc/501910006566GB.pdf . If this isn't your model, start at http://www.whirlpool.co.uk/support/instructions-for-use/instructions-for-use.content.html and click on Search. Then search using the Commercial code box. (There are also washers with the commercial code AWM 302/3 and AWM 302/4.)
I hope this helps.
Jun 03, 2012 | Whirlpool Washing Machines
Scheme to replace the bearings whirlpool AWM 5130
GOOD LUCK
Mar 10, 2011 | Whirlpool AWM5125/1 Front Load Washer
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Machine does not wash just fill and drain
hI my name is joyce , you need to get a service tech to fix problem the machine has got a piece of trash in valve that controls the cut off of the water and its stuck. check the filter in the water line to make sure it is in good shape and has no trash in it, this usually happens when you are on well system with no filter on line.
Feb 06, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
Whirlpool AWM 8103/1 error FP
it looks like you have a clog filter or pump issue.
take a look at this forum
http://www.howtomendit.com/answers.php?id=53072
Feb 24, 2008 | Washing Machines
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
