Question about Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLR5067 flashing green
The other night there was a thunderstorm, so I unplugged the TV. After I plugged it back in and turned it on, the screen was predominantly green and constantly flashing. There are also 5 vertical stripes running down the screen that are purple and green. It looks this way on all regular channels and on the DVD player. The HD channels have little green or purple squares flashing all across the screen, but the picture is otherwise normal. The menu and the TV Guide screens are not affected. Also, the TV will periodically freeze up and shut itself off and then turn back on again. I've tried unplugging it again, leaving it off for awhile, leaving it on for awhile, but nothing has made any impact. Any ideas?
  • 2 more comments
  • 30307 Jun 14, 2008
    We've also discovered that if you do PIP, the channel on the right looks perfectly normal, but the left screen still has the original problem.
  • raj9534 Jun 19, 2008
    Same issue with my TV happens with intermitent power failures, this comes on after i turn on the TV. It goes away after I unplug and reinsert the power plug a couple of times.
  • davejakers Sep 18, 2008
    Same problem here. What did you do to fix it?
  • lpmgr1020 Mar 17, 2009
    Having the identicle problem what did you do to fix it
    Problem Solver:
  • 7 Answers
If this doesn't fix your problem, it may be the lamp. I experienced the same sequence minus thunderstorm, but it got to where it went from green verticals to just cycling on and of 5-6 times. New lamp did the trick.
Posted on Dec 06, 2010
Thank you!!!! Our power was off due to new transformers being installed in the area and we had no clue how to fix this. I called around and no one seemed to know the answer (not even Samsung, who only wanted to tell me my TWO year old tv was out of warranty),so I tried this and it worked perfectly!!! You saved me a bundle! Thanks!
Posted on Nov 22, 2008
We had a thunderstorm last night, and the power went off and came back on a couple of times and now our Tv isn't working. The green power light stays on, but there is no picture on the screen. We...
The tv Tuner signal board it is shorted and dead.That the board where the tv incomming broadcasting signal cable plug into it.U have some basic mechanical skills like take things aparts and putting it back together.Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 12, 2011 | Norcent Technologies LT-3250/LT-3251 32...
My Samsung HLR5067 was working fine last night. I left the house open and it dipped in temp (only to 40 degrees or so though)...Woke up this morning and it wont turn on at all. Just beeps a few times,...
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
Dec 06, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
I have a Samsung plasma over 5 years old. power
The x-sus or y-sus panel wil be the fault.Check the fuses on these panels ,if one of the fuses is open then that panel must be replaced.Not verry cheap to replace.
Nov 02, 2009 | Samsung HPN4239 42 in. Plasma HDTV
Samsung DLP TV HL-R5067W green vertical bars on screen no picture
This is going to be a bad digital board. It is a very common issue with the HLR series.
Aug 30, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I WAS WATCHIN TV THE OTHER NIGHT AND ALL OF A SUDDEN THE TV TURNED ITSELF OFF AND THE LITTLE GREEN LIGHT IN FRONT STARTED FLASHING VERY FAST -SO I UNPLUGGED MY TV AND THEN PLUGGED IT BACK IN AND THE GREEN...
Some of these sets if you unplug them---The green power light will blink for about 70 seconds before it stops--this is normal as the receiver unit in this set is booting up. Wait for the light to stop blinking and then the set should turn on. Some of these sets develop a problem where the light never stops blinking--usually the receiver is now bad--very expensive to get fixed.
I do this here for free so if this helps you give me a vote here.
SD TECH (San Diego)
Aug 28, 2009 | Mitsubishi WS-48515 48" Rear Projection...
JVC i art 32" flat screen
your tv is under shutdown state, there is a protecting circuit that prevent the tv from turning on when there is a short
Sep 10, 2008 | Televison & Video
Tv broken?
Yes your set can be fixed ,it may have shorted your hori out put transistor and also caused FBT to blow. Flyback Transfomer cost 150.00 up, to 175.00
Jun 19, 2008 | Televison & Video
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
380 people viewed this question
Jerry Greenberg
Jerry Greenberg
