Question about Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer - Blue
Samsung Electric Dryer
I bought this Samsung Electric Dryer in February. It was working great. However, now, even after the clothes are dried, the dryer won't stop until I manually turn it off. It would just continue to add at least 50 minutes of drying time back onto the current drying time. What's wrong?
  • 4 more comments
  • Anonymous Sep 28, 2008
    I just noticed that my dryer is doing the same thing. Currently, I can only use it on "manual" settings or else it will run indefinitely. My Samsung is only 2 months old.
  • Anonymous Nov 19, 2008
    Same problem, they tried 3 times to repair, finally replaced it and the new dryer does the same thing
  • Anonymous Nov 30, 2008
    Mine is doing the same thing. Unit works in manual/timed mode but with moisture sensor settings the unit counts down until it is almost dry, then adds another 50+ minutes to dry time. Clothes are steaming hot. This could be a fire hazard!
  • ybnormal28 Nov 30, 2008
    My Samsung dryer is doing the same thing. The unit works fine during manual/timed settings. Using the automatic settings with the moisture sensor cause the unit to count down until almost dry, then it adds 50+ minutes. When you open the dryer, the clothes are steaming hot and over-dryed. A repairman changed the moisture guard/sensor and it still does it. I'm worried this will cause a fire so I only use the manual settings.
  • Anonymous Dec 16, 2008
    Mine does the same thing! Samsung should fix this
  • lflamenc Jan 11, 2009
    We are having the same problem too. We have only had our dryer for a few months. Has anyone asked Samsung if they will replace the dryer if the repairs do not fix the problem? I am curious since I am getting ready to make the call to see if someone can come out and fix it.
    thanks
  • 35 Answers
This may be a problem with your moisture sensor or the control that read the sensor. If it is under warranty have Samsung fix it for free. Make sure the cycle settings are correct before tinkering. First make sure the electronics are not too dusty. You could blow them off or vacuum them. Dirt particles can conduct electricity and make it read wrong. Next check the electrical connection for the moisture sensor. See if its location is in the manual. If it doesn't work after some tinkering asked the service for the dryer about possibly replacing the sensor but first try hard to get it to work.
Posted on Sep 21, 2010
Wrinkle prevent feature adds about that time to the end of cycle, but the heater should go off...
Posted on Jan 20, 2010
I have had the same problem with mine, they (being the repairman) came out and have replaced the sensor and the board and it still does this, they said that there is nothing else that they can do. Don't know what I am going to do from here
Posted on Sep 26, 2008
WON'T DRY CLOTHS..NO HOT AIR
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'';';
Jun 27, 2011 | GE Dryers
We were turning our drum and heard a loud pop sound; plus the clothes hadn't gotten dry.. the lights and everthing shows up but the dryer won't start up now
heatman101'';
Jun 13, 2011 | Samsung Dryers
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
The timer keeps readjusting while drying clothes, will say there is 45 minutes left and clothes are perfectly dry, this could be a fire hazard if left unattended.
you will need to clean the vent tube/internal duct work:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature then the thermostat tells the timer to begin advancing. The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
if the vent/duct work is clogged then the
I hope this helps here is a website on how to remove cabinet:
http://www.partselect.com/dryer+amana-open-cabinet+repair.htm
Oct 24, 2010 | Amana NED7200TW Electric Dryer
Dryer not drying clothing.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 24, 2010 | GE Profile Harmony DPGT750EC Electric...
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Kenmore 11070702990 Gas Dryer - Timer does not work
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Takes too long to dry or keeps running when clothes are dry
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer - Blue Logo
784 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
