Question about KDS Avitron 195TF Monitor
THERE IS A BOX THAT POPS UP IN THE MIDDLE OF MY SCREEN WHEN I AM ON A SITE. DEEP BRIGHT COLORS. AND HAS THINGS TYPED ON IT LIKE- CONTRASTE, H 68.6 KHZ AND V H4.9 HZ. I PUSH EXIT BUTTON ON MONITOR, BUT IT KEEPS COMING BACK ON OVER AND OVER. HOW DO I GET RID OF IT? LINDA
SOURCE:
SOURCE: Dell Ultrasharp 21' monitor
I had the same issue. I pressed and hold the + button and the monitor did an auto adjust and the pop up stopped.
Posted on Jan 16, 2009
SOURCE: Dell 15 inch monitor, brightness/contrast window
Press and hold the + button, You will get a message that the monitor is going into auto adjust. After that problem solved.
Posted on Jan 19, 2009
  • 11 Answers
SOURCE: always seen brightness and contrast not exit
try turning it on and off, wait a few hours then turn it back on. it that dont work, turn it off then leave it till the next day then try. it should work.
Posted on Jul 28, 2009
  • 55 Answers
SOURCE: I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Posted on Jan 05, 2010
romeetb
  • 66 Answers
SOURCE: The brightness/contrast menu keeps popping up and
seems to be a problem with the buttons on the screen for changing the resolution etc panel...you will need to get it checked by a repair shop
Posted on Feb 04, 2010
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Contrast is way too bright, not screen brightness, contrast. is there a contrast adjust button?
Right click on your main screen. Go to properties, or graphic properties, then you will find there is a contrast adjustment within. Usually under color correction.
Mar 24, 2011 | Toshiba Portege 4000 Notebook
Hi! I am experiencing difficulty with the brightness on the screen of my GameBoy Color. Is there a way to adjust the screen brightness, so that it would be brighter? -Stine
Unfortunately, the Game Boy color has no backlight, so there's no way to make the screen any brighter. You can change the contrast, but that will only affect how dark things appear on the screen. Sorry.
Mar 16, 2011 | Nintendo Game Boy Color Console
Contrast/Brightness Menu repeatedly pops on screen/won't go away
What kind of system do you have there? Regular PC + monitor or All-in-one/Laptop?
Dec 30, 2017 | Dell E172FP 17" LCD Flat Panel Monitor
Picture djust
Put it in the custom mode.Put the contrast to the max.Put every things in middles may be colors for less.Now u have the desire ajustment u want?
Aug 19, 2009 | JVC AV-27530 27" TV
Brightness/contrast window pops up and scrolls through fast
The up/down button on your flat panel is stuck. Please contact Dell Technical Support to have the monitor replaced if its still within warranty.
May 28, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Help with settings - blurry SD picture
contrast full, brightness, tint, color, in the middle, then adjust sharpness for what suits your eyes, you may turn brightness and color below middle.
Mar 17, 2008 | Sony BRAVIA KDL-40V3000 Television
Dell E173FP 17-inch Flat Panel Color LCD Monitor
The dell monitors are bad with capacitors going out, check caps in power supply and video board. You can use a can of freeze, it would be easier that way. Just be careful not to touch anything, because these monitors can shock easy.
Sep 06, 2006 | Dell E173FP 17" Flat Panel LCD Monitor
KDS Avitron 195TF Monitor Logo
43 people viewed this question
Top KDS Computers & Internet Experts
Thomas F. Schneider
Siul Oyaratgam
Steve Allison
Steve Allison
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
