Question about Goldstar WG5200ER Air Conditioner
Goldstar BG5200ER Not cooling room anymore. Does give off some cool air , but not nearly as much as before
    Champion:
  • 254 Answers
This sounds like a filter problem or a dirty evaporator. Open the fron panel and see if the pre filter, filter, and or evaporator are dirty.
Posted on Jun 13, 2008
Not cooling very good anymore. its cool but not that good! all the settings work. one thing i did notice is that ice builds up on the cooling coil from compressor! ( ge room ac model # ast05lcs1...5500...
Your intuition is right, the ice buildup is why it's not cooling so well now: the evaporator isn't getting the correct air flow and surface area for heat exchange. The 1st thing you might want to check is to make sure that it's draining properly. The 2nd thing you might want to do is to check that the room is over 100 sqft. If you'r only cooling a tiny bedroom, the AC's basically oversized: your cooling already cooled air, so it freezes. The actual reason that is freezes is because the condition is just right for the immediate area near the evaporator to be at the saturation point. Think of it in terms of weather: warm and humid air collides with cool air and it begins to rain. The temperature drops further, and the rain turns into snow. One thing you could try to make it not freeze-up is to adjust the temperature setting a few degrees or change the fan speed.
Aug 04, 2011 | GE ASQ05LK 5,050 BTU Room Air Conditioner...
The air from my air conditioner doesn't seem to be coming out as cold as it was when i first bought it. It seems to take a lot longer to cool off my living room, i dont know if it needs freon to be...
Its going to take a hile to cool down a hot room . have you cehck the filter? while your at it wash it out . what is the temp of the room and the temp of the air coming out of the unit?
Jul 22, 2011 | Goldstar Heating & Cooling
New ac does not cool
mcdevito75 here, The cheapest way is with the warrantee card you mailed away went the unit was new. If no warrantee, then check out the A/C repair shops in your area, Sorry.
Jun 23, 2010 | Goldstar KG6000R Window Air Conditioner
Doesnt cool room as in prev years
yes the side vents need to be outside the window and if they aren't - the unit will not cool correctly.
Hope this helps.
Jun 08, 2010 | Goldstar WG5000 Air Conditioner
Room does not cool down
It may be low on freon or have a leak, I'm not sure if that particular unit has Service Ports on it to enable a recharge, consult your Owner's Manual for any Troubleshooting Tips. www.goldstar.com
Jun 05, 2010 | Goldstar KG6000R Window Air Conditioner
Does not cool room.
Goldstar WG5000 air conditioners use an R22 refrigerant. A charge kit containing the gauges needed to properly fill the unit, and the refrigerant tank/cartridge can be purchased to fill the air conditioner.
Jun 03, 2010 | Goldstar WG5000 Air Conditioner
Goldstar room ac GWHD6500R
I read that its just simply cool with low fan on energy saver...on another site.
Aug 22, 2008 | LG Goldstar GWHD5000 wall/window Air...
GOLDSTAR BG5200ER
Measure the temp of the air blowing out. It should be 20 degrees lower than the intake air at the filter. If not, we need to dig deeper.
Aug 14, 2007 | Goldstar WG5200ER Air Conditioner
Goldstar WG5200ER Air Conditioner Logo
167 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
