Not valid win32 application
Ive got an issue with my command promt. when ever i want to ping a IP address it comes up with C:\WINDOWS\system32\ is not a valid application error message.
Is there any think available to help me sort this mater out. or a factory default is the way to go
Many thanks to Ekse i tried your solutionl
  • 13,433 Answers
You posted this problem to me again is not a program and therefore doesn't work!
use ping.exe and then put the address here
Posted on Jun 13, 2008
  • Ekse Jun 13, 2008
    Here you can see that the is not there but ping.exe or ping works fine.
Unblock ip school address proxy
Perhaps you could try this address: -> This is (one of the) IP address of the facebook website. You can find your own IP addresses by opening a Command Promt in Windows, and typ: "ping"
Nov 22, 2013 | Facebook Social Network
How to ping an IP address in Windows Applies to Windows XP, Windows Vista and...
Applies to Windows XP, Windows Vista and Windows 7
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Next at the command prompt type "ping" then press the space bar and then enter the IP address that you would like to ping. After you have the command typed press the Enter key.
Example: ping
4. If the IP address is valid and not blocked by a firewall then you should get a responce that looks like this.
Note if you get a message like shown below this means that the ether you do not have a valid IP or ICMP Echo requests are being blocked.
In most cases it is being blocked by the device that you are trying to ping. However it can be block in the Windows firewall or other software firewalls. The links below will help you verify that you have ICMP Echo enabled on your computer.
How to allow ping (ICMP Echo) request through Windows 7 Firewall
How to allow ping request through Norton Internet Security 2010 Smart Firewall
on Sep 21, 2010 | Computers & Internet
first of all your system had network adapter check it once it's ok
2. go to run promt and type cmd command promt open
then type the ip config/all
3. you can get one ipv4 adress
use this word ping and type the ip address
Nov 17, 2010 | Computers & Internet
I tried to ping my wireless router. it says destination not reachable but shows 0% loss. When i entered the ip address of my router it show address not valid. please let me know what to do.
Open up command prompt on computer.
  • Start, run, cmd, ok - for windows xp
  • start, programs, accessories, right click command prompt, left click run as administrator, continue - vista/windows7
  • in the command prompt window type these commands
  • netsh winsock reset catalog
  • netsh int ip reset resetlog.txt
  • ipconfig/flushdns
  • press enter after each command to activate
  • restart your pc
Try and ping your router gateway again when it comes back on. if it still fails to open reply and ill post more steps to try.
Hope this helps
Apr 22, 2010 | Linksys Wireless-G Broadband Router
Why is my computer saying no connectivity when I try to connect to the internet?
I think we need some more information to help you.
How are you connecting to the internet? Do you have a ISP issued modem/router? Do you have a personally purchased router?
Go to a command prompt (click select-Run- type cmd and press enter). Once you are at a command prompt type ipconfig /all and post that information. If your IP address starts with 169.254.. and a subnet mask of then your IP address was assigned by APIPA and not your provider/router.
If you get another IP address then here are some things to check...
this is a loop back test. If you get results than you have TCP/IP protocols installed.
ping x.x.x.x (your actual IP)
if you get results back than you have a routing table or network driver issue.
ping x.x.x.x (your gateway IP address)
If you do not get a valid response then you may have issues with cabling, network adaptor, or the router or gateway device.
This should at least get you started. See ms kb 314067 for more details.
Jan 18, 2010 | Acer Computers & Internet
Lost connection
1. check ip address in command prompt
2. If unable to find valid ip address , reset ipaddress , in command prompt type ipconfig /release and then ipconfig /renew
3. Ping default gateway in command prompt
4. then ping in command
5. If u can ping in command prompt issue with Internet explorer or with Operating system.
6.Try using different browser.
Aug 17, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Cant access my belkin54g with
Open command prompt and do ipconfig and make sure that you are getting a valid IP address .
Default gateway should be if you are not getting valid ip address then check if your ip is assigned manually under TCP/IP properties .It should be obatin an ip address automatically .
Also make sure that modem is connected to modem port .
Also try to disable all firewall from your computer
If you are getting valid ip address and then try to ping in command prompt .check if your getting any replies .If your are getting replies then it could be issue with your Internet explorer settings
Let me know if it doesn't work .Feel free to send me a mail
Sep 11, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
GO to the controll pannal and printers and say add printer choose network printer if u know the ip just put your ip address and say next it should detect it if not try to go to command promt and ping the ip with the ping command
if it gets the repply frmtheip so its comunicating
Jun 15, 2008 | Muratec MFX-1200P All-In-One Led Printer
Jim84 win32 application
so the ping is working as its supposed to. shouldn't even be there.
the cmd file may be missing or corrupt replaceing the file would most likely fix the problem. I can send you a copy of my cmd.exe file from my windows xp professional
was that the problem or is there something else?
Jun 13, 2008 | Computers & Internet
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
