Old compact PC386 with ST3243A 214meg HD. CMOS died, and trying to get the right type selected. Can you help with type #? thanks kevin
  • kvetter Jun 17, 2008
    Already replaced battery. The problem is the BIOS wants to know what type of HD I have so it can access it correctly. The old BIOS did not always have a way to determine the # of heads and cylinders and size of the HD and had to be told by selecting from a list of types. EX type 35 is a 170meg 8 head HD. Type 4 is a 70 meg 2 head HD. My problem is the HD I have is 214meg (210 formatted) and does not have a type selection on the list.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
It may just need a battery replacement. Did you try reflashing the bios?
Posted on Jun 14, 2008
  •  J. Fernandez
    J. Fernandez Jun 19, 2008
    Get the specifications for the HDD and put it in manualy. That's if the bios doesn't give you the auto option.
    Problem Solver:
  • 30 Answers
Replace dead battery. It will work
Posted on Jun 17, 2008
At start up the comp indicates Plug & play Config Error then prompt F1 OR F2. F2 being setup while F1 says continue. (XP system). Downloads files then indicates it is starting Microsoft but nothing...
F2 Enter Setup (CMOS settings) Use arrow keys to navigate ALL menus. CHANGE NOTHING just look. After you have seen all go back thru and write down any settings you think might apply.
things like: Plug and Play operating System (yes or no); Assign IRQ ( use automatic for all ); Reset Config Data (YES).
Then go back thru again and change settings ONE AT A TIME be sure to make note on paper what you change and old setting and new setting you are testing.
EACH time you change a setting save settings and resume boot.
Is it fixed ?
reboot and enter setup if and change that setting back, Test the settings you think may apply one at a time noting any additional errors or improvements or simply no effect.
Use your intuition, TAKE MOST EXCELLENT NOTES, change only one thing at a time at first being prepared to change it right back if a problem arises.
If you can not get it solved with a CMOS setting you could try setting it up from the beginning. Swap in a new HD, take small watch type battery out of socket on mainboard to power off CMOS chip and thereby clear it's memory. The default CMOS settings will be used. Boot from install CD and install windows all over again on new HD. Once you have a bootable machine in stall old HD as second HD so you can access it to transfer over files you wish to save, then you can erase the old HD by formatting it and have more storage space if you want it or simply remove it.
Sep 16, 2013 | Dell Dimension 8200 PC Desktop
Working on a Dell 530 Desktop, installed a new WD 500gb Sata Hd and after setting up Boot in cmos cant get by following Boot to CD Boot Device not installed enter ready to continue. Need Help OS CD in in...
Go back into the Dell CMOS and try reseting all settings back to default. Restart and when it starts to boot, start tapping F12 to get to the boot menu. Try booting to the CD drive now.
***Please rate if this helps you or ask more detailed questions for more help. Thanks
Dec 15, 2010 | Dell Computers & Internet
Importing Pics from SDHC or Compact Flash Card Hangs on Vista PC
you could try updating the drivers.
1. got to hp's website (http://www.hp.com)
2. Click on support and drivers
3. click download drivers and software (and firmware)
4. enter you model number (Pavilion Elite m9400t)
5. select your os (vista 64 bit)
6. download the Fall 2008 Original Intel Matrix Storage Manager Driver
7. install the driver.
Jan 18, 2010 | HP Pavilion Elite m9400t Desktop PC
Dell dimension 3000 + maxtor hard drive. comp wont start
Try the following to see if it's helpful:
1) Turn the computer on
2) Press F2 to enter the BIOS ( a grey screen should come up)
3) Turn on caps lock,scroll lock and num lock on your keybord
4) Press Alt +E then Alt +F then Alt +B
If that doesn't work you can pull the CMOS battery to clear the BIOS. It is on the board and resembles a watch battery. You have to pull it for no less than 15 minutes to clear the BIOS.
May 25, 2009 | Dell Dimension 3000 PC Desktop
Dell Optiplex GX280 Probem with DVDRW
Hey,
Please look into the computer bios / cmos setup and see if the dvd drive is detected there, if its not detected then its not either connected properly or this type of drive will not work with this computer. in that case try the drive on another computer or try another drive on your computer.
to enter bios, please look at the monitor right when you turn the power on, you should have a message to press button to enter system setup or bios or cmos setup. etc.
Possibly F1 or F2, DEL, it depends and the computer will tell you what button is the right one.
Thanks and good luck.
Ekse
May 03, 2009 | Dell OptiPlex GX280 PC Desktop
Hard Drive Install gone bad!
Unplug the slaved hard drive.
Restart the computer. If you get the same results.
Pull out the cmos battery on the motherboard. Most look like shiny nickles, be carefull not to damage the board. Make sure you unplug the computer first and let it sit a minute or two afterwards before putting it back.
That will set the bios back to defaults and you should be able to get the computer up and running from there.
As far as slaving that drive to be used as extra storage, you might want to consider an external enclousure instead.
Best of luck.
Feb 24, 2009 | eMachines T3406 PC Desktop
No icon only wallpaper
Right click on the desktop and go to arrange icon by > show desktop icon.
Hope this will fix your issue.
Thanks
Kevin
Oct 14, 2008 | Computers & Internet
Computer that reset always
Replace the cmos battery and flash the jumpers.
Hope this will help
Thanks
Kevin
Sep 16, 2008 | Computers & Internet
Need to replace hard drive on T2778 Emachine.
You need memory modules with maximum 1Gb DDR 333Mhz.
For HD you can select whatever you like.
Just replace memory modules, install your new hard drive (if it is IDE set as master).
After that get in to the BIOS (normally press DEL when boot the computer) and from boot order select as first the CD-DVD ROM and as second the Hard Disk.
Put at the CD Device the CDROM with the windowsXP and restart the computer.
The guide to install windows XP is very clear but if you have more questions post again.
Jan 11, 2008 | Computers & Internet
Computers & Internet Logo
85 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
