Question about Compaq Evo N610C Notebook
Power up A few days ago the laptop started cutting off when using battery even though it still had power, now it won't turn on from battery power when you try the lights will come on and then it will shut off even with battery showing a good charge.Works fine using power cord and it shows battery is charging when plugged in.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 65 Answers
I think urs battery get damaged....
but before replacing it first remove it safely n again fix it on laptop....
then restart ur laptop if same problem is coming...than it is sure dat ur battery get damaged or its efficiency get lower....
send me feed back if ur facin more problems wid ur laptop at shriii2@rediffmail.com
Posted on Jun 15, 2008
Stall after start in humid days
Could be the ( warm up 02 sensor)
Oct 15, 2017 | 2002 Toyota Sienna
My Samsung WB100 turns off after switch on. Got new batteries and same problem plus 'old' batteries are still good even though camera said they needed replacing after a few days minimal use.
Make sure you are using name brand high quality batteries and not some generic from China. Camera require a great deal of power to boot up.
Jan 25, 2013 | Samsung Wb1000 Digital Camera
Car won't start
Did you try starting in neutral? Some vehicles have electronic transmission lockouts that will go bad and prevent ignition cycling even when it is not in gear.
Dec 14, 2012 | Cars & Trucks
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
I have an Acer Aspire 5517 laptop. No problems at all until a few days ago when it stopped charging. Replaced the charger and battery, and still won't charge. Even flashed BIOS, Help!
Check the pronges inside the battery compartment. They will be like copper plated if they are not loose or broken then it may be a motherboard issue.
Aug 23, 2011 | Computers & Internet
Hi, I have an inspiron 1545. A few days ago I noticed that my battery stopped charging even though it was only 70% full. Then this morning my pc would not turn on at all unless it was plugged in. the...
That error code is indicative of a primary battery permanent failure. There may be a connector problem but not likely. Your best bet is to replace the battery.
If you are uncertain, try finding someone in your vicinity with the same type of laptop as yours and ask if you could test their battery on your computer.
Jan 27, 2011 | Dell Inspiron 1545 Notebook
A few months ago my Dell Vostro 1500 laptop started saying that my battery could not be detected. I bought this laptop new in October 2007 and did not extend my warranty. I bought a new battery and...
Normally the message means that the battery is bad and needs to be replaced. There is a chance the new battery you got was defective and went bad before its time.
The motherboard can be the problem, although it is not common for this to be the case.
I would try one more battery before thinking about a new motherboard, a new battery is under a $100 where a new mobo is several hundred, and usually this is a sign of a bad battery. If you disconnect the ac adapter and it stays on then it is using the battery, although it is reporting that it cannot see a charge. I would guess the battery malfunctioned and is not being able to be read by the laptop.
Sep 12, 2009 | Dell Vostro 1500 Notebook
Laptop won't power on
A few things to try:
First remove the battery from the laptop plug in the power adapter and see if it powers up without the battery in. If this works there is a problem with the battery or the battery driver. If it works login go to device manager and disable the Microsoft ACPI-Compliant Control Method Battery. If battery works then it was the driver if still fails its a dead battery.
Try with just the battery it is probably dead though as its had no power to charge it.
Check if the power adapter has a light on it some have lights that indicate its receiving power. Also check if the lights on the laptop to say the battery is charging even though you indicated it isnt.
Let me know how you go or if you need further help.
Mar 23, 2009 | Lenovo ThinkPad T500
Power
It sounds like a mother board problem since you upgraded the bios and got different results. Try plugging in the adapter and warming it up. Will the computer run without the battery? that will also let you know if it's the battery.
My initial thought was that your AC adapter may have a heat problem or failing after a while. Wrap it in plastic and put it in ice and see if it lasts longer. If you have the same problem there are other issues going on in the computer power system.
Sep 11, 2008 | Compaq Computers & Internet
Compaq Evo N610C Notebook Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
