Question about B&K AV 125.7 7-Channel Amplifier
B&W PV1 Subwoofer
Hi
I have suddenly had a problem with my B&W subwoofer. The last time i used it everything was okey. When i started up my home theather system today it only comes a clikking sound from my subwoofer.
I have tried to remove the signal cabel but that doesnt help. When it take the AC cable out and in again its quite for a few seconds but then the sound starts again.
  • Anonymous Dec 26, 2008
    the same here. which component make the problem?
    Genius:
  • 1,673 Answers
Make sure that your amp is putting out proper signal to the sub woofer.
If the feed from the amp is okay, the power amp and our the power supply in the sub woofer may have become defective. This will require to be serviced.
Jerry G.
Posted on Jun 14, 2008
    New Friend:
Encountered same problem. The internal switched power supply consists of 3 parts : +12V(4W), -12V(4W) and +80V (500W). The + 12V circuit supllies the internal amplifier as well as an extra protection circuit (totaling about 4W). This circuit extracts a powerpeak when turned on. This powerpeak is somethimes to high for the +12 V power supply. Rather than soldering on the power supply board, I introduced an extra swithed power supply of 12V, 7W (from a Braun-beard trimmer !). The on board +12V enables the extra supply by means of an optocoupler and a Triac.
Posted on Jun 18, 2013
  • Vanster
    Vanster Nov 15, 2013
    Could you please explain this in greater detail? I have the same dreaded clicking PV1 and doesn't hold much hope for its resurrection with the local distributor as I brought mine over from overseas when I relocated. Any help would be much appreciated!!
The sound bar suddenly stopped pairing with the subwoofer. The only sound is coming from the bar
I suggest turning off and unplugging everything from the power, then disconnect everything from each other. See if you can get it to pair again. Otherwise, please give more details on which model sound bar and subwoofer.
Thank you.
Feb 28, 2016 | Audio Players & Recorders
My model is RX-V665...not sure what the BL stands for... anyway...no sound from the subwoofer. Pull the RCA wire from the back of the receiver and touch it with my finder and you hear a buzz from the...
HI,
first of all select ur sub woofers auto mute (auto power off ) switch to off position.
then connect the mic and calibrate ur system one more time. after calibration select it to on position. u will surely get it work. if need any further assistance feel free to contact through fixya.
ok
Dec 31, 2010 | Yamaha RXV665BL Receiver
Subwoofer JVC TH-M606 suddenly stopped functioning
Hiya, sorry that will have to go in for repair as it sounds like it may be protecting. Could be something loose but that would be lucky. Suggest finding a electronics shop in area that can assist. Best of luck
Jul 14, 2009 | JVC TH-M606 System
Subwoofer makes a sound at computer startup
1.yes the electric shock can damage the subwoofer  2.some times a sudden switch off or power cut can result in for such issue . 3.for this issue just make sure that you switch on the speaker 1st before starting the PC, then switch on the PC, & while closing time also make sure you 1st switch off or shut down the PC 1st & then the speaker in last   & more ???...! do keep on writing untill then have happy computing sir...till then See you soon...!
May 24, 2009 | Altec Lansing VS2221 Computer Speakers
Subwoofer clip/distort problem
It's probably the amp in the subwoofer. Bad cable don't cause clipping. Nor, is an amp output likely to overdrive the subwoofer.
On second thought, why are you using an amp with it turned off? Have you tried turning on the amp whcih provides the signal to the subwoofer? That could well be your problem.
May 05, 2009 | Audio Players & Recorders
Infinity Interlude IL120s Powered Subwoofer (home) will not power
Some of these Infinity Amps have an Internal Glass Fuse. Open the Case and Check for this Fuse. Please Rate My Response! Thanks!
Feb 03, 2009 | Infinity 7540A Car Audio Amplifier
The Subwoofer will not work but all other speakers do!
Hi look for a sub level control in the set up and turn it up,this may give it a kick start,also is ther a volume control on the sub? if so turn it up half way.
HOPE THIS HELPS.
CABLE GUY.
Aug 05, 2008 | Panasonic SC-PT1050 System
Power issues: will not turn off or function
Unplug all of the speakers and power on.Its possible that one of the speakers is causing the protection circuit to activate.If powered on and subwoofer works start reconnecting one speaker at a time( after powered off) and retest each time.One Speaker may be bad.Its also possible the output ic is failing under a speaker load.There are no fuses related to this issue.If its not a speaker problem then the subwoofer will need to be serviced.
Feb 24, 2008 | Panasonic SC-HT730 System
B&K AV 125.7 7-Channel Amplifier Logo
2,078 people viewed this question
Top B&K Audio Players & Recorders Experts
shaun taylor
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a B&K Audio Player and Recorder Expert? Answer questions, earn points and help others
