Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Just hums but don't start - Reddy Heater-170,000 BTU Kerosene Deluxe
  • 232 Answers
I assume you have removed the top cover and eliminated an obstruction against the fan blade. If so the problem is either a broken rotor (air pump) or a locked up motor, which is not serviceable. These are simple tasks and no special tools are required except a low pressure gauge.
Posted on Nov 05, 2010
Humming on pfl
50hz hum. Turn off most of your home equipment , turn only your table on, if it still hums it\'s your transformer and that\'s too bad for your wallet. And you also don\'t have those led lights which
is a fashion statement at the moment on your table, they are not quite good for causing distortion. And in your home are saving-lights. especially with dimmers and lcd plasma tv\'s a major cause of distortion. But a steady , low freq hum is your transformer and i have a stethoscope, not for that purpose:). Then you don\'t have to search. But they ain\'t cheap, the upgraded in 2009 ones.
gr richard
Jan 02, 2014 | Technics SL-1200 Turntable
Rear tires humming on 2009 Honda Pilot
It is just the brand of tires some hum some don't the more you pay the leless noise you get.
Aug 08, 2012 | 2009 Honda Pilot
Unplugged computer plugged back up loud humming
The humming could be coming from one of the fans or the disk drive. Sometimes if you just tap the case the humming will quit. If there is a CD in the cd drive sometimes it will hum.
Don't worry about the humming, if it starts clicking, that's when you worry.
May 03, 2012 | Acer Computers & Internet
Kenmore dryer Tub will not turn freely. Feels as if it's hung up. When you you press the start button it will just make a humming noise.
A guess, sounds like you are hearing the motor running but no tub belt as it is probably broke. If you are asking then you probably don't know how to fix it so you should call a repairman. Or the tub guides are wore out either way a repairman can help.
Nov 22, 2011 | Kenmore Dryers
Turns over but dont start
more info? out of gas? bad fuel pump? if you turn the key partially but dont start it, you should here a quiet electronic hum for a second or 2, if you don't, it's your fuel pump
Oct 21, 2011 | 2001 Hyundai Accent
My 2002 Grand Prix sounds fine upon starting. When I get to 45 mph, it starts to sound as if it's working harder. It's like a loud hum starts and gets louder as it goes up to 60 mph. As I decrease...
Front Wheel Bearing Hub
You will have to remove the brake calipers,hang it,&
remove the rotor,then you can turn the hub & feel the
roughness.
ROCK AUTO.com for parts & look at that hub, so you
match it up the same. Don't get in love with one brand
you like, if the hub looks different at the back where the
speed sensor goes in
You also may find your self buying a torx socket or metric
socket driver to get the speed sensor out. Maybe not
If tools are needed,do yourself a favor & step inside a Snap-On
Truck & just buy one item or so. If you don't ,you won't find those
items anywhere
Sep 21, 2011 | 2005 Pontiac Grand Prix
Fan stopped working on our Bosch rangehood (Type D-FX41-8 or E-Nr. DKE935AAU). Lights working but the fan only inhibits a humming sound.
hi ;
the fan motor needs repair , the cause of humming is the vibration of induction on AC current in the motor.
if the motor stopped means it has faulty shafting and bushing, or maybe the starting capacitor needs a replacement, don't turn it on or use it to prevent burning of induction wire,
also it needs a qualified technician to repair ,
Sep 03, 2011 | Kitchen Ranges
My 2004 Suzuki Verona will not start is making humming , clicking noise where fuse box under hood is thout was ignition fuse but not that battery is good don't know what else to do
Clicking noise is normal for relays but humming sounds like one of the relays is not engaging properly.Try swapping relays of the same type and see if it solves the problem.
Aug 03, 2011 | 2004 Suzuki Verona
I have a Mercedes 2003 C230. Checked my Fuel line, Fire to Ignition, and Change Camshaft Position Sensors. Car Cranks but still does not start. What else should I look at?
Turn the key and listen for a hum (keep doors closed but a window down and radio off). Don't turn the key all the way to try to crank it, just the turn to get all the lights in the dash on. If you hear a slight hum or buzz that last a second or two that is your fuel pump. If you don't hear it, check your fuse for the fuel pump, if that is not blown, your fuel pump may have gone out.
May 04, 2011 | Mercedes-Benz C230 Cars & Trucks
Motar just hums wont do anything but hum
If the motor just hums and there is nothing stopping the motor from spinning then it is smoked and will need to be replaced. Wish I had a more happier answer for you but I don't.
Regards, Tony
Apr 19, 2011 | Dishwashers
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
Top Reddy Heating & Cooling Experts
Paul Carew
T bone 1963
cavs1
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
