Question about 2wire 2700HG-B Router (2700HGB)
WEP key for 2wire 2700
Where do I get the WEP key for my 2700. I am trying to get my new laptop to access from 2700. Laptop sees connection but asks for WEP key &ISP phone number
  • Anonymous Mar 15, 2009
    security settings to nitendo DS won't let us acess 2 wire
  • 4 Answers
The WEP number is in a wireless router near you, you must have a wireless router been setup in your home, then you have to program it. you choose your wep key code and only will have access to this wireless network.
contact your local IT or computer repair guy to help you with this process.
Posted on Jun 13, 2008
  • binpda00365 Aug 22, 2011
    ssid,Trendnet wedkey?...
The default wep key is at the bottom part of the 2WIRE 2700 the 10 digit number enclosed in a bracket in between the barcodes
Posted on Jun 18, 2008
I have my computers and laptop networked through my 2wire Home Portal 1000SW modem and am trying to connect my Coby Kyros MID8024 Tablet through wifi. The tablet finds my 2wire network but seems not to...
1st make sure that your using the proper WEP key (Wireless Password) 2nd make sure that their wirelessly compatible SW is a wireless b compatible to eliminate this issue you may also disable your WEP
majority of new technology uses wireless G and N
this wireless modem is a little bit outdated:
Data Link ProtocolEthernet , IEEE 802.11b , HomePNA 2.0 , HomePNA 1.0 , USB
see for your tablets protocol if this would match:
Aug 28, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
I have a 2wire 1000SW router/modem connected by an ethernet cable to a Hewlett Packard media center PC running Windows Vista. The internet Wifi connectivity problem arose after I visited a best Western...
If you check your router you will find a reset button or a little hole in back insert pin in hole and press for 10 seconds your Moden should have reset now you will have to put in your login and password to access modem
Feb 28, 2017 | 2wire Computers & Internet
I have a 2wire gateway with 4 routers i have a desktop on it with a dsl cable line and two laptops on wireless going to the router. So that is 3 computers on the 2wire. I am trying to connect my third...
it depends on what type of OS that you are using. But the key point to this is that your computer was able to see your network, usually your network name would be 2wireXXX (the X is the 3 digit of your serial number of your 2wire modem or router. if it is asking for password or wep key. the wep key for your 2wire is the number enclosed in a bracket, that is usually 10 numbers below the serial number
Jun 23, 2010 | 2wire (1000-400108-001) Router
Had to replace 2Wire gateway modem, set up the new one and network, now unable to set up wireless connection with new laptop we got. not sure what I am doing wrong, the laptop is picking up the secure...
This may be a silly question, but have you input the WEP key for this new router into your laptop? It will be printed on the router with the serial number and such. It is the middle set, if I remember correctly. View all available networks with the laptop and pick yours. It should ask for the key. Input your new key and such, and you should be good as gold.
Hope this helps!
Aug 16, 2009 | 2wire (1000-400108-001) Router
Ijust bought an laptop and when I try to connect to the wireless network,"2wire657" it ask me for a security key or passphrase where do I find this
You can find this on the two wire modem where it say WEP key right by the serial number on your 2wire modem thanks
Jun 14, 2009 | 2wire 2700HG-B Router (2700HGB)
How do I get the WEP key for my 2wire 2700hg-b router?
Take a look under your 2wire modem, wep key is located on the bar code.
Apr 09, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless connection to the 2 Wire modem
Hi
Most of the 2wire gateways have the WEP key or the encryption code on the bottom of it. It would a 10 digit Number of a Five Character one within square brackets.
Other wise you can go to the gateway page by accessing http://192.168.1.1 on another system which is already going online using the gateway or wired to it and in the gateway page under wireless you would find the WEP key incase the default key on the bottom of the 2wire does not work.
Do reply incase this has resolved your issue or you need more help.
Thank you
Rakesh
Expert in Dell Laptop.
Jan 05, 2009 | 2wire (1000-400108-001) Router
Finding WEP key
You can access the setup page of the 2wire ADSL gateway to check what is the WEP key or you can give the 10 digit code printed on the buttom of the hardware a shot if that will do the trick, now if the tech from geek squad change the security level to 128bit and configured a new 26 digit WEP key(yes WEP can be 10 or 26 digit depending on the configuration) then the only option is to access the setup pag.
Nov 13, 2008 | 2wire 2700HG-B Router (2700HGB)
Password issues with 2wire 2700
2 wire provide WEP phase key on the bank usually is sirese no ,try it. Otherwise please power on from default or factory
Jul 19, 2008 | 2wire 2700HG-B Router (2700HGB)
Not able to get ds or laptop online wireless
In most cases the default wireless settings are sufficient for normal home use.
The WEP or Network key is located on the bottom of the residential Gateway, within brackets [ ]
Nov 15, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
1,862 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
