Jim84 win32 application
Many thanks on help, that you sent me.
I tried the ping.exe and came up with command promt options.
But I wanted to know to resolve the problem that i have got. Would a factory default sort it out, or is that the last thing to do at this point.
  • 13,433 Answers
So the ping is working as its supposed to. ping.com shouldn't even be there.
the cmd file may be missing or corrupt replaceing the file would most likely fix the problem. I can send you a copy of my cmd.exe file from my windows xp professional
was that the problem or is there something else?
Posted on Jun 13, 2008
Print from command promt software in window 7 based laptop
You can always use PRINTUI.EXE in Windows 7 Command Prompt.
Type the command and see what are the options you can use.Here is a site explaining some of the commands.
I hope this helps!
Nov 27, 2011 | Epson LX-300 Matrix Printer
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
May 29, 2010 | Dell Studio XPS 16 Notebook
Worm.win32.autorun.blw virus appear in my system i already use kesper sky, but not solved. please advise a solution. thanx
When the executable is run on the victim's machine, the worm copies itself to the following locations:
  • %Application Data%\remove.exe (Copy of itself)
  • %Application Data%\autorun.inf
Where %Application Data% = c:\Documents and Settings\All Users\Application Data
Autorun.inf has following command
Exp: [autorun]
shellExecute=remove.exe
The worm adds a Run entry in registry so that it executes itself at every startup:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
    "(Default)" = "%Application Data%\remove.exe"
Symptoms -
  • Presence of above mentioned files.
  • Presence of registry entries mentioned above.
Method of Infection Method of Infection - This worm spreads by using autorun.inf on shared drives and removable devices.
Removal - A combination of the latest DATs and the Engine will be able to detect and remove this threat. AVERT recommends users not to trust seemingly familiar or safe file icons, particularly when received via P2P clients, IRC, email or other media where users can share files.
Thanks for using fixya..
Sep 14, 2009 | Computers & Internet
Win32 application not vaild
The application is not supported by the win32 system file of your windows XP
Aug 21, 2009 | Microsoft Windows XP Professional for PC
Whenever i try to run a exe command it throws an error Not a valid win32 application
click start go to run and enter : sfc /scannow see if that works
Dec 10, 2008 | Computers & Internet
Not valid win32 application
You posted this problem to me again
ping.com is not a program and therefore doesn't work!
use ping.exe and then put the address here
example
ping.exe www.google.com
Jun 13, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
