Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Crack on the bottom side of the detergent container
There is a crack on the bottom right next to the nozzle. Where do I get replacment parts or can you try and fix it? Thanks.
  • 1,673 Answers
You go to and order it online, or maybe have you local service shop order one for you.
Posted on Jun 17, 2008
My Hoover F7452900 uses up the detergent in about 30 seconds and doesn't use any water. What can I fix?
The water and the soap are supposed to mix as they are dispensed. Check for a leak or crack anywhere in the water line. Any crack would make the vacuum-operated delivery of water quit working!
Apr 23, 2017 | Hoover Vacuums
How do you remove the lower handle?
Check the clean water holding tank. I had this problem and found that was a crack near the outlet on the bottom of the tank. I replaced the tank and resolved the problem. I have taken this machine apart several times, if the tank is not the problem with yours, check the water tube.
Apr 26, 2015 | Hoover F7425-900 SteamVac V2 Widepath...
How do I get my carpet shampooer to spray wate
If your machine was designed to spray hot water, detergent cleaner or a combination of both, chances are the filter/strainer inside the reservoir may have become clogged, the feed tube may be twisted and pinched closed or the spray nozzle may be clogged from various contaminants. Try and get a look down inside the container where you fill it with fluids and see what you can determine, also check the spray tip or nozzle where the fluids are supposed to be expelled for a clog. If the small service pump is the culprit, servicing or replacing the pump will be a bit more involved and parts are available from most manufacturers websites these days. Hope this is helpful :)
Aug 27, 2014 | Dirt Devil 1700912044 Carpet & Rug...
The wand that connects to the power head at the powerhead connection broke(sheared off) fine crack
Unfortunatley the Wand for your Miele is sold as an entirely assembly only. Miele does not sell pieces of this wand separately. In order to fix your wand you'll need to purchase a new wand assembly complete.
The wand on your Miele is the Miele SET210 Wand. Here's a link if you need to purchase one;
I would probably guess that your wand broke off right at the bottom where it connects into the power nozzle. Unfortunately this is the weakest part of the wand as you can probably see. The wand narrows into a thinner plastic here, and I've seen a few wands crack off right on the bottom part.
Please feel free to request a repair clarification if you have any questions about how to repair your vacuum.
If you found this helpful, please be sure to rate it by clicking the thumbs up icon. I really appreciate that.
Chris J.
Mar 21, 2010 | Miele s558 Silver Moon Vacuum
On the bottom of the Fantom Fury where it states:"The United States and Canada utility patent....". Now go to the far right end of this statement (the end opposite the spring, well I have a...
Generic problem for all Vacuums
Posted by cminor5767 on Apr 25, 2008
On the bottom of the Fantom Fury where it states: & quote; The United States and Canada utility patent....& quote; Now go to the far right end of this statement (the end opposite the spring, well I have a crack in the plastic which, when toggled, moves the entire plastic underside of the vacuum to move. In other words, I think I need an entire bottom plastic plate. The cracked area also makes the foot lever (which lowers or locks the vacuum handle) not work as the crack makes it impossible to work. I know you probably do not know what I am talking about but if you could just tell me where I could purchase the entire plastic plate of the bottom of the vacuum I would be very grateful. As of now, my vacuum cannot be used and I need it to be operational.
Thank you, Charlene H. Minor, Royal Oak, Michigan
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If you call you local vacuum cleaner dealer in your area or in the yellow pages, or the Fantom Factory Manufacturer they can either send you the part or parts for the bottom plate or foot release or sometimes the entire base assm depending on what is cracked and broken, I am going to list a couple of places you can get these items, they need the Fantom Model # and color of vacuum and they can ship you the part(s). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Customer Service – 1-800-798-7395
For technical support, please call us toll-free at 1-800-798-7398. Hours are Monday through Saturday from 9:00 am to 6:00 pm Eastern Standard Time. 1-800-657-1874 If you cannot find a local dealer near you they can ship you the parts UPS.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 25, 2008 | Vacuums
Have a Hoover Steamvac Model #F7426-900 - Series AA12.0 On the bottom of the clean water tank and the detergent container, the gaskets leak and water constantly drips from the tank. How do you repair...
Inspect under the seals to see if the tank hasn't cracked, which is usually the problem. If it is a new seal that is needed, part #43513026. If a new tank is needed, part #42272104.
Apr 24, 2008 | Vacuums
I'm afraid that you will have to replace the base unit, part #62577, would sell for around $25. Once it cracks, then it is weak and will affect the brush roll and belt.
Dec 30, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Tank Dispensing
Is the detergent tank cracked at the bottom, under the black seal? If so the whole tank asm. needs to be replaced. But if this is new, then it has a one years warranty on it and you can take in for warranty repair.
Oct 13, 2007 | Hoover F7222-900 SteamVac Upright Vacuum
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
26 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
