Question about RCA E13309 13-Inch Diagonal XL-100¿ Color Television Television
My TV after being ON for about 10 minutes will shut off by it self. You can turn it back ON but it turns off rught away?
    Top Expert:
  • RCA Master
  • 76,030 Answers
Hello
From your brief explanation I thinks that there is some loose solderings inside your TV. To make sure about it, you just give a small hit with your palm on the top or side or your TV, when it shuts down. Never use any hard material. Use ony your palm. If it comes on atleast for a short period of time, you can determine that there is some loose soldering inside it. As it is a 13" TV, and a small one, you can do it by yourself. Open the back cover, and pull out the printed circuit board inside, anc check for any component for loose contact. If it seems to be, resolder the point by applying a little more solder. Usually, some components of all TVs will heat up while working. Repeated heating and cooling can cause loose soldering contacts.
Do this first, and wants any more explanations, ask me through Fixya. Ok.
Posted on Nov 04, 2010
TAKES 45 MINUTES TO COME ON
Evidently there is an internal power supply problem.
Nov 12, 2013 | Televison & Video
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
My mitsubishi 60 in turns off by its self some times 5 min after you turn it on sometimes 5 hours and sometimes 5 days. you can tell when its about to turn off by line that flash on the screen. then they...
Well if your tv is older like the one in the pic it sounds like the bulb is overheating, you may want to vacuum the dust out of the back and make sure it isn't got block of air flow in the back and also make sure it isn't up against a heat source
Feb 19, 2018 | Mitsubishi VS-60607 TV
I turn on my TV and 10 minutes later it turns off by itself. What is the problem
generally this model shut it self down if anything major. possible reason for a delayed shutdown is bad capacitors. or loose connections. does the picture display any abnormalites before shutdown. does it come right back on when you push power button. any sounds or smells? how long has this been doing this?
Oct 13, 2010 | RCA HD52W56 52" Rear Projection HDTV
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
TV turnes its self off
Sounds like you have a bad solder connection. Since you had the back off can you slide the chassis out not forcing anything and may have to unplug a couple of plugs to get it out and turn the chassis upside down carefully and with a magnifying glass look for bad connections in the solder If you see obvious bad connections they can be soldered with rosin core solder and soldering iron used in electronics. Put the hot iron on the bad connection first to heat it up and then apply solder letting it flow over the connection. let cool and solidify. Hope this helps
Dec 29, 2007 | Panasonic CT-36D32 36" TV
Turn off
this happens to my tv as well it simply will just shut off and turn itself back on and then shut itself off every 2 - 3 minutes...can someone help??
May 24, 2007 | Polaroid FLM-2011 Television
Televison & Video Logo
103 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
