Question about Dishwashers
I have model LI 640 I-B-S-W and for the past 6 months there is a constant odor coming from the bottum of my dishwasher. I have cleaned the door panel and taken out and cleaned all the filters and I made sure that the drain hose is higher than the disposal. Is there a check valve that could be faulty or stuck?
  • Dishwashers Master
  • 3,247 Answers
I am assuming it is an Ariston dishwasher. I would suggest buying the Finish dishwasher cleaning kit from super market. Run the dishwasher empty on hot cycle per instructions on the bottle. This should get rid of the ouders.
If check valve is faulty then I would not expect the dishes to come out clean as the dirty water would be circulating through wash arms. It might be accumulation of food particles on seals in pumps etc. The cleaning kit should fix some of it.
good luck.
Posted on Nov 04, 2010
I had a Bosch dishwasher installed 6mos ago. Awful odor coming from it. Any ideas re: odor source?
this is decade food. you need to put a cleaner in the tray like calgol in the system this will clean the system use it regularly, there are other branded of dishwasher cleaners make sure its on the hottest wash first time don't put items in the washer and when done leave to dry. do this every month and it will not smell. will keep the washer clean and fresh.
Jun 29, 2017 | Bosch Dishwashers
WHAT COULD THE SOURCE OF THE ODOR IN MY 2007 LEXUS RX 350?
Air con could probably do with a re gas and you can buy air con deodarizer
Oct 11, 2014 | 2007 Lexus RX 350
I have a BOSCH model 53L06UC dishwasher and was
every bosch dishwasher unit is different. you can get odor from different source. #1 solution to fight odor is the proper maintenance. every month run the cycle with just a cup of vinegar on a hot wash. i am a old bosch tech and alot of people dont add the jet dry properly. this is for drying,spots and-cleaning you must add the jet dry or rinse agent (same thing)into the compartment. close compartment,then lower and raise door 3 times,then fill again repeat until you cant add anymore then it is filled.if this help please send me a 4 thumbs up post. thanks
Feb 28, 2010 | Dishwashers
How do I clean off calcium deposit from dishwasher coils? I have calcium build-up on the bottum coils of my dishwasher and my dishes come out filmy.
I suggest you descale your machine with a cleaner such as C.L.R. Any cleaner with Phosphoric Acid will do a good job. The best way to clean your dishwasher is to pour a litre of this cleaner into your machine, and run a complete cycle. (without dishes in the machine) You may need to repeat this process every month depending on the hardness of your water.
Regards
Jan 18, 2010 | Frigidaire Dishwashers
A smell is coming from the ice dispenser. I need to open it.
Unlikely area for the smell to come from since with the unit off, there is no action in this area. Most likely cause of your smell: Residue in drain pan of freezer evap area. Remove panel in back of freezer section while unit is unplugged and clean drain and surrounding areas. Use a high concentration of bleach water and let unit air out completely after this. At some point in time, meat or related substance in your ref/freezer leaked and odor is caused by this as the unit was thawed. Use the product ICE AIDE, available at sears or by an A&E tech to continue to freshen your unit for 6 months. IF meat or some sort of undesirable juice dripped into the ice or door water dispenser, you can take this apart and clean as needed following your parts breakdown at www.searspartsdirect.com after you enter your model number off of the appliance. Make sure you work with an unpowered appliance.
Jun 14, 2009 | GE GSS20IEP Side by Side Refrigerator
Need to clearn front bottom of refrigerator
That cover does come off it is held on by two clips one at each end. Take a flash light and you will have to lay on the floor to see the clips after you take it off and on a few times you can just fell the clips give way when you pull it off. And if you have a bottle brush about 18" long would be very helpful also. You will see a bunch of dust around the coils and when you clean them your frig will get much colder. Good thing to do every 6 months or so. ken
Jan 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our dishwasher, GE model # GSD4800, installed in Oct.'03,is emitting a bad odor. We do have a GE disposer, but there are no odors or problems with that appliance. I am not sure if the DW drains thru the...
There is nothing within the construction of a dishwasher that can cause bad odours.
If your dishwasher smells it can only be the result of food debris left within the appliance because of a poor or faulty house drainage system, incorrect installation of the dishwasher drain hose or some sort of blockage in the drain pump (see Dishwasher Will Not Drain). Less likely is a problem with the water supply.
It is a good idea to run a dishwasher cleaner through the appliance every three months or so. You can find these in most supermarkets, usually in the same area that other dishwasher products are displayed. Make sure that you also clean and wipe the edges of the door and the door seal, especially at the bottom of the door.
Jul 01, 2008 | GE Dishwashers
Dishwasher odor
MY dishwasher had the same smell coming from it. I discovered that under the bottom of the door against the seal was a build up of dirty rotten stuff. When I cleaned that all out the smell went away
May 13, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
Stars cycle thin stops lights reg and eco start blinking
Clean out the filter really well, then replace it. This should reset the dishwasher. If it does it again when you try to run the dishwasher. Take the filter out and re-seat it. Some times it's not sitting exactly right. Good luck and I hope that helps.
Mar 04, 2008 | Ariston Technologies LI640S Dishwasher
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
