Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Black and gray boxs show up on my screen
I just replaced the lamp an my WD 52525 TV and when I turned it on all that shows up on my screen is a pattern of small black and gray boxes. The sound works find and I am able to change channels but nothing comes up on the screen but the box pattern. I have called around and no one seems to have an idea what is wrong. Any ideas would be helpful.
  • xx007xx Sep 01, 2008
    Wow! finally I have found someone with the same problem!, I have tried everything under the sun but still I get the little checkerboard pattern, I cannot even bring up menues or anything, any help would be greatly appreciated
  • HateMyMitsu Sep 03, 2008
    I have the same problem today on 9/2. Was fine when I turned it off, and today the screen is covered completely with a bright pattern of black and gray lines. No movement. Sound is fine. No difference between regular, Hi-Def or HDMI video.
  • 126 Answers
Try to hook up signal diffrent instead of rf go video, or s video
i would try video if you have original remote see what happens
Posted on Jun 21, 2008
WD-60638
This is a issue with the DMD board it is not using the colors properly. This part runs around $200 plus you might need to pay for installing.When a color wheel is bad you will have different symptoms.
I hope this helps :)
Jul 29, 2013 | Televison & Video
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Red light wont show picture
This is either a bad capacitor somewhere in the tv, or the very common power supply/high-voltage transformer.
Jan 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have mitsibishi projection tv. the screen black shows 1/2 black and sometimes all sreen black . can u help?
Could be something as simple as a defective lamp to a more complex problem related to video display or mirror/color wheel problems. Check other inputs (DVD, etc) first to be sure the problem is consistent across all input types. Have you tried "resetting' the tv or plugging it out. then wait. then plug back in and go thru setup again.
Jul 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Lamp replace twice.
Light engine replacement is next.Contact Mits tech in your area.
Sep 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Turn on the set and let it shut down. push in the Menu and Device (or input, I don't have a schematic in front of me) buttons on the front of the set at the same time and hold until the green light starts flashing. Then release. There will be two different sets of flashes, such as, 3 and 6. The code 12 means the set is opperating fine. The other codes will tell you what part of the set needs repaired. Also, remove the bulb and check the ballast connection to the bulb. I find the connection for the bulb bent over when a customer replaces the lamp sometimes. Let me know what you find and we can go from there.
Feb 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
