Question about Symbol MC 9090 (sym-mc9090gk0hbega2r) Wireless Portable Terminal
I'm using DataWedge 3.x on an MC9090. The receiving app is accessed through an rdp session. When I scan a barcode that is all numeric, the scan works pe3rfectly. However, an alpha bar code causes the scan to be giberish Scanning D305946 comes through as 3059$^ D. Scanning into Mobile Office Word on the scanner works properly. I have the same setup on 2 servers and it has the same problem on both. The receiving program on the servers isn't the problem, the results are the same regardless (I have tried is in MS Access and Notepad with identical results). I also changed the version of DataWedge (started with 3.1x and then upgraded to 3.2.4) and get the exact same results. I'm sure there is a configuration setting I am missing but don't know where to start. Any help would be greatly appreciated. Thanks
5 Suggested Answers
thesuperdude
  • 97 Answers
SOURCE: Types of Barcode that can be scanned using Symbol MC9090
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
SOURCE: we use Remote Desktop on our MC9090 to access an
Yes thats correct.
The latest version available is v3.2.4.
You can download it from:-
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12743&sliceId=&dialogID=22526211&stateId=0%200%2022522575
If that doesn't work as its session controlled just go to teh main search page
http://support.symbol.com/support/product/softwaredownloads.do
and search for datawedge and then select "Most Recent" to get the latest version.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Posted on Jun 08, 2010
SOURCE: I need to turn off the beep on the Symbol MC9090 w...
Create a registry setting, putting volume to 0 will (almost) get of the sound ....
[HKEY_CURRENT_USER\Software\Symbol\SymbolPB]
"DecodeVolume"=2
"DecodeFrequency"=00FF
"InvalidDecodeFrequency"=0FFF
"DecodeDuration"=850
Posted on Jun 22, 2010
SOURCE: i scan barcode into notepad ....computer goes haywire
heare are the manual but i search a manual whear i can enable the code 93, has any a idea?http://www.barcodemuseum.com/Datalogic/Manuals/dlc6000_820000512.pdf
Posted on Jan 21, 2011
MC9190 will not scan a certain barcode, but the MC9090 will, what could be the problem?
Firstly you need to know exactly what 'symbology' or type of barcode you are trying to scan. E.G. 128CODE, ect.
Once you know this make sure 'DataWedge' is installed and go to the settings section of the software.ensure that the type of barcode you are printing is selected in the settings. After this is should work.
regards
Dave (Pen Mobile) Germain
Jan 28, 2013 | Zebra Symbol Technologies MC909X-G Series...
When the DataWedge 2.0 is launched, an Error "cannot set scan parameters 00000000" appears and scanner does not function. Was running just fine. MC7094. Scanning is working fine in another...
If the scanner is not working, you can try to go to this site to check the information on how to reset the device. Here is the link that you can try.
Thank you for sing Fixya.
Aug 09, 2011 | Symbol MC9090 Barcode Scanner
Symbol MC9090 Barcode Scanner cannot enable scanner error code "A0000008"
The scanner engine/output can be used only by one application. If a second application is trying to access the scanner, while in use. The error message will come.
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software. Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Oct 21, 2010 | Symbol MC9090 Barcode Scanner
We use Remote Desktop on our MC9090 to access an application. The scanner does not work. Do I need to install datawedge?
Yes thats correct.
Hope this helps.
Jun 07, 2010 | Zebra Symbol Technologies MC909X-G Series...
Getting a MC9090 and 1500 preprinted labels to stick on pieces of pipe. Just need an excel file with the cross ref in it. Want to scan a barcode later and have description come up. Can I do all of this in...
To get scanner to work on MC9090 WM5 and scan into excel, I had to install DataWedge From Here You will need to install this through your ActiveSync That will make it so you can scan directly into excel The setup your data, the you can do a find, to find the cross ref
Dec 10, 2009 | Symbol MC9090-G RFID Handheld Barcode...
Could not active it the scanner on the MC9090
The link works for me DataWedge provides a convenient mechanism for non-scanning aware applications to receive data from embedded or connected data capture devices. It allows the user to capture data into any application that accepts keyboard input. It supports four types of Data Feeds: Barcode Scanners, RFID Tag Readers, MSR Readers and Serial Data Input. It provides user with text/hex data formatting and prefix/suffix facilities. Description
  1. New Test and Log Display.
  2. Improved DataWedge Startup Time for MSR and RFID
  3. Gen2 RFID Support
  4. Device enable/disable persistence over cold boot
  5. Virtual Key Support in Prefix/Suffix
  6. Performance improvements for MSR
  7. Enable Serial Interface on startup
  8. Support added for Event based Serial reading.
  9. Delays regarding RFID are fixed.
  10. Several Barcode character mapping issues fixed.
make sure some security software is not blocking your access
Jun 22, 2009 | Symbol MC9090 Barcode Scanner
Im using DataWedge v1.0 for scanning the barcode in Motorola MC55.How can i get scanned data from DataWedge to my application.i.e where DataWedge will store the scanned information.Thanks.
You need to be in an application first. For example, launch mobile Excel and make sure your cursor is in a cell. When you scan, it will enter into that cell. Just make sure the cursor is in the cell you are trying to get the info into before you scan (If it's not working, the app you're running may not be compatible with the scanning function, but I've never seen this).
Oddly enough, from what I've seen, if you just scan something without having an app launch, I've seen the MC70 default to the phone function and try to dial the number scanned.
Feb 18, 2009 | Symbol MC70
SYMBOL MC9090 - LASER READER NOT WORKING
You may need to replace the scan engine - I can help you out with this (or any other issues you may be having).
Contact me if you need anything:
Ian
DC Solutions
ianv@dcsolutionsonline.com
Aug 11, 2008 | Symbol MC9090 Barcode Scanner
Symbol MC 9090 (sym-mc9090gk0hbega2r) Wireless Portable Terminal Logo
313 people viewed this question
Top Symbol Computers & Internet Experts
Vish Iyer
Vish Iyer
George Etukudo
George Etukudo
Norman Al-Anbar
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
