Question about Panasonic KX-T7636-B Corded Phone
Want to program more 1-button speed dial in flexible CO buttons
When I came to my job, many of the flexible CO buttons were programmed (and still are) with common phone numbers, but even with the quick reference guide I can't figure out how to add more numbers.
our phone says its a KX-T7636, without the "B", but it is a corded version that looks like the picture of KX-T7636-B.
SOURCE: need to program pf buttons on kx-t7730
Press Program Button
Press Button to be Programmed
Dial 1 - Plus extention number to be stored on button
Press button directly under 'ENTER'
Posted on Feb 18, 2008
  • 2460 Answers
I can give you the fast answer and the slow answer. Fast one is to go to the main phone, press PROG and dial **1234. The system should go into programming and you will be looking at system program 000. ENTER. From there, using a combination of the SEL, FWD and CONF keys, you should be able to navigate around the time change, using ENTER or STORE to save it.
The arder way is to grab the manual here and start reading it from page 12 then follow the instructions on page 16.
Keep in mind that TDA programming is usually done from the master phone, or any phone assigned programming status. It may be all or NONE.
Posted on Apr 15, 2009
SOURCE: Can't store a one-touch number
Finally worked it out! Add a zero before putting in your mobile number. e.g. 00416 xxx xxx
Posted on Jan 03, 2010
  • 113 Answers
SOURCE: How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
Posted on Mar 23, 2010
  • 113 Answers
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( usaully default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Posted on Mar 29, 2010
How do I program the Flexible Outside (CO) Line Buttons? The manual doesn't say!
if you want to save extension number
program + button + 1 + EXT + store
example : program + button + 1+ 103 + store
if you want to save co
program + button + 0 + co number + store
example : program + button + 0 + 1 (for co1) + store
if you want to save external number
program + button + 2 + 9 + external number + store
example : program +button+2+9+0097259970... + store
Jun 09, 2015 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 '
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    I wish to assign a flexible CO button to switch from day to night mode on a panasonic Kx-T7433 and can't find a resolution that works can anyone help?
    There isn't a magic program to do that. The codes 781 782 on the intercom can be programmed under TWO buttons for DAY and NIGHT, or you possibly could program one button to dial 78 and you manually dial 1 or 2, but only the DSS console can be programmed for single button D/N switching.
    Apr 28, 2011 | Panasonic KX-T7433B Corded Phone
    I have the KX-T7020. How do I reprogram the auto dial numbers?
    Here's a guess. Is the 7020 the one with 16 buttons? If so, they are marked CO 1-12 and F1-4. You program them by putting the phone in PROG from the switch on the back of the phone, then press the button and 1. If it's a F button, dial 9 + number and STORE. If it's a CO button dial 29 + number and STORE.
    If you're talking SYSTEM speed dial numbers, those are done from the display phone at jack 01 and putting the system in programming.
    Mar 24, 2011 | Panasonic KX-T7020 Corded Phone
    How can i use the buttons of panasonic kx-t7730 corded phone ?
    The 12 buttons on the right can be used for personal speed dial numbers and features like paging. They are programmed by pressing PROGRAM dialing codes and STORE. An outside call would use an "access code" usually "9" plus the number. Paging is 330.
    The 12 left side buttons are very valuable as they have lights. You can store lines, extensions, and features that require lighted buttons, such as CID Indication or VM functions. They are programmed by PROGRAM the button a code the feature and STORE. For example, lines are programmed with 0 + line Extensions with 1 + ext and CID Indication System with 96 or the 9x voice mail commands.
    Your OM or User's manual has a section on flexible button assignment with the codes and buttons required to do the programming. In my TA-824 200-OM it's in section 3.1.3.
    Feb 19, 2011 | Panasonic KX-T7730 Corded Phone
    I have a KX-T7456. Set 3 CO buttons for speed dial with new names and extensions. Busy light does not come on when those 3 lines are in use. Works on all the other numbers.
    It's not speed dial, it's DSS. Names come from the directory (sys prog 004). The button programs from personal programming PROG 99? button 1+ext+STORE.
    Jun 01, 2010 | Panasonic KX-T7456 Corded Phone
    So that we're on the same page, a 7730 has PF bottons on the right and "CO" buttons on the left. If you have a different phone, like a TA-308xx or a Euro phone that isn't offered in the U.S., then it may only have a single row of buttons.
    Programming is the same. If the button is a CO button (with a light), then your one touch requres a "2" in front of it to speed dial a nunber and a "9" or outside line access code to dial an outside number. So, to call 212-555-1212 you press PROGRAM the CO button, 292125551212 STORE. An inside number is stored under the CO button with a "1" plus the extension number.
    A PF button already has the assumed "2", so you would just dial 92125551212 in the example above.
    Dec 13, 2009 | Panasonic KX-T7730 Corded Phone
    How to store numbers for speed dialling on Panasonic KX-T7730 having only 12 CO buttons.
    Well let's see. You have 12 CO buttons and 12 PF buttons, and at least 100 system speed dial numbers available.
    Which ones are you looking for?
    Depending on what Panasonic system you're connected to, the PF buttons program by pressing PROGRAM and the button, and dialing the number with a "9" or trunk access code in front of it then STORE. If you're connected to a TD system it's PROGRAM 99.
    System speed dial numbers are entered from the main or manager's phone under system program 001.
    Jun 28, 2009 | Panasonic KX-T7730 Corded Phone
    KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing...
    Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
    To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
    The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
    Jun 17, 2009 | Panasonic KX-T7730 Corded Phone
    Panasonic KX-T7636-B Corded Phone Logo
    99 people viewed this question
    Top Panasonic Lands Phones Experts
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
