If y varies directly as the square of x,and y=24 when x=4,find the constant of variation
    President:
  • 1,188 Answers
Y varies directly as the square of x means:
y = kx^2
Where,
k is the constant of variation. You can use any letter except y or x for constant
Put values of y and x: (24) = k * (4)^2
k = 24/(4*4) = 24/16 = 3/2 = 1.5
Answer: The constant of variation is 1.5 if y varies directly as - moz-screenshot.png
Posted on Nov 04, 2010
The constant variation is 6
I got a new Brother 1634D Serger and would like to make a quilt on it. How do you get a 1/4 inch seam? please help me
Don't expect a quilt to be as accurate from a serger as from a sewing machine. First, you probably want to focus a strip quilt where rows of strips are stitched together. If you do strips, you won't have to worry so much about maintaining an exact 1/4" seam. You can also vary the widths of strips in order to camouflage any seam variations. Avoid a pattern that requires points being aligned! Any seam width variances will not as obvious as an error (it is intensive getting an accurate 1/4" on a sewing machine--so-o-o-o much more difficult on a serger). There are usually seam width marks on a serger that you can follow as a guide, but straight line serging is very difficult to accomplish. You can always try marking a line on your serger using painter's tape.
FWIW, making a strip quilt on a serger is a fast way of finishing a quilt. I divide my quilt into 3 or 4 sections, like making it in thirds or fourths. That way, when the quilt begins to grow, you are not constantly grappling with flipping or turning the heavy and bulky fabric. Instead, do each section separately, then stitch the sections together to make the whole quilt.
Also, be sure to press all the seams of a strip quilt in the same direction.
Strip Quilt Patterns
4 Free Strip Quilt Patterns That Standout from the Crowd Fons Porter
How To Sew An Easy Strip Quilt
https://www.quiltinaday.com/community/topic.asp?forum=2&topic=5481
Make FAST Serger Strip Quilt with 1 4 square Triangles
Feb 27, 2017 | Brother Sewing Machines
What is the average rate of change for 5x+4
The rate of change for the function y=5x+4 is the coefficient 5 that multiplies the independent variable x. For a unit variation of x (x varies by 1) y varies by 5 units.
Between x1=2 to x2=3, y varies from y1=5*2+4=14 to y2=5*3+4=19.
The rate of change is defined as
(variation in y)/(variation in x)=(19-14)/(3-2)=5
Sep 28, 2014 | SoftMath Algebrator - Algebra Homework...
How many feet is 350 linear feet?
Linear feet are a measure of length (no different from feet); square feet measure area. You cannot simply convert between measures of different kinds of quantities;the connection between them will be specific to a particular problem.A practical example in which this question can arise is in buying countertops for a kitchen. Some materials are sold by the square foot; others (basically those that are extruded, so they come in standard widths) are sold by the linear foot. In order to compare the two, you need to compute the area and wall length for the countertop you want.You can't convert between the two. All you have to do is to make the appropriate measurements so you can calculate the price of each item.The terms used in the lumber industry are a bit confusing.There are two terms that I think you might be mixing up.A LINEAR FOOT is simply the length of a board. If you want to know the area or volume of the board,you need additional information. For instance, 6 linear feet of 1-by-12 has an area of 6 square feet (12 inches = 1 foot, times 6 feet), and it's 1 inch thick, so the volume is 1/2 cubic foot (6 square feet times 1/12 foot). But 6 linear feet of a 1-by-6 board would have half the area and half the volume.A BOARD FOOT is equivalent to one square foot of a 1-inch-thick board. In other words, it is a square-foot-inch (ft^2-in), or 1/12 cubic foot.Linear feet are used for the pricing of a single size such as two-by-fours. Board feet are used for larger lumber that you are more likely to want to compare directly with different size boards .To sum up, neither a linear foot nor a board foot can be converted directly to square feet. A linear foot is a linear (length) measure, and a board foot is a volume measure. You need to know your particular board to do anything more, such as find the area.an example with an" L" shaped countertop will betwo rectangles are 24 by 80 inches and 24 by 36 inches. Thus the area is: 24 * 80 + 24 * 36 = 24 * (80 + 36) = 24 * 116= 2784 sq. in.To get it in square feet, divide by 144:
2784 / 144 = 19.33 sq. ft.The linear measure of this countertop would be 60 + 80 = 140 inches = 140/12 feet = 11.67 feet
Apr 08, 2014 | Cars & Trucks
Need help with rate of change and direct variation
No need for a claculator to understand these concepts.
A linear function is a function of the form y=ax+b. It contains an independent variable,x, a dependent variable, y, and two constants, a and b,
The value of the constant a is the measure of the rate of change of the function, The value of the constant b is the ordinate (value along the y-axis) where the straight line cuts the y-axis. It is called the y-intercept, or the initial value.
If the value of b=0, the straight line passes through the origin O(0,0). The purists call this type of variation, a direct variation. If b is not equal to 0, it is called a partial variation or some other name.
If you have the graph drawn, b is read off the y-axis: You look at the graph and try to estimate the ordinate of the point where the line cuts (intersects) the y-axis.
To get the rate of change a, you select two points on the line. Let 1st point have coordinates (x1,y1) and the 2nd point have coordinates (x2,y2).
The rate of change is given by the ratio (y2-y1)/(x2-x1). You can also use a= (y1-y2)/(x1-x2). Respect the order in the two expression or you will get the negative value of the rate of change.
May 10, 2011 | Texas Instruments TI-83 Plus Calculator
Valsi 7.5kw gen. The output voltage varies about 30 % with or without a load. the generator seems to be running at a constant speed. the speed of variation is a pproximately 1/2 hz. It would appear a...
Sometimes the voltage will be higher with absolutely NO load. Try a small load and see if it comes down. If not, then need a replacement AVR.
Jan 01, 2011 | Electrical Supplies
The stopping distance d of a car after the brakes are applied varies directly as the square of the speed r. If a car traveling 40 mph car stop in 90ft, how many feet will it take the same car to stop when...
The stopping distance is proportional to square of speed.
that is 90ft proportional to 40^2 mph.
We can write as 90 = X * 40^2. ( X is a constant of proportionality) .
Which implies X = 90 / 1600 = .05625.
Assume S be the distance at which car stops when the speed is 90 mph.
S = X * 90^2. ( since X does not vary as same car is used)
=> S =.05625 * 8100 = 455.625 ft.
Thank you.
Jun 12, 2010 | Bagatrix College Algebra Solved Full...
Whats rms on legacy la1490
http://en.wikipedia.org/wiki/Root_mean_square
In mathematics, the root mean square (abbreviated RMS or rms), also known as the quadratic mean, is a statistical measure of the magnitude of a varying quantity. It is especially useful when variates are positive and negative, e.g., sinusoids.
However, the term "RMS power" is sometimes used in the audio industry as a synonym for "mean power" or "average power". For a discussion of audio power measurements and their shortcomings, see Audio power.
http://en.wikipedia.org/wiki/Audio_power
Oct 13, 2009 | Legend LA1490 - American Legacy Series 2 -...
Huge temperature variation in Chateau by Moen shower only faucet
You bet....Pressure at the building varys with large use...8-10am or 4-6 pm....What floor you on...Higher the more pressure you need...maybe a pump...or plugged press.balance system....Not a novice handyman job...
Aug 13, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Computers & Internet Logo
210 people viewed this question
David Payne
David Payne
