Question about GE Profile PDW8400J Built-in Dishwasher
Dishwasher is making a loud noice and the water is not draining...
  • jimfuzko Feb 05, 2009
    water will not drain. and it's stuck on dry cycle and just makes a loud noise. won't reset.
  • steve705 May 11, 2010
    Where/how do you clean the pump? is there a filter?
  • 487 Answers
Clean out the pump as it cant drain and there will be something stuck in the pump
Posted on Jun 13, 2008
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 | Dishwashers
Ariston li 700
follow the steps and fix it. God bless you
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
Jul 06, 2013 | Dishwashers
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
DW makes a lot of noice when it's washing....squealy, whiney noice...very loud.
Hello Summer Summer - Often if the dishwasher is making a loud, squealing noise then it is recommended for the wash motor to be replaced. If this problem persists, you can locate a certified technician directly through the manufacturer website or in your local directly to determine what may be causing the issue at hand.
Mar 12, 2013 | Frigidaire FDB1100RHM Builtin Dishwasher
Dish water is not working. Water fills but no noice after that.
it's obviously sounds like your pump has gone, but considering the age of the machine, it would probably be best to get a new machine, that way you would have a 5 year warranty with it aswell so it's win/win really!
Jan 05, 2013 | Dishwashers
GE Dishwasher - loud rumbling/growling noice!
If I am not mistaken this dishwasher has a Clean out at the bottom of the machine that can open .This is here to catch stuff like broken glass and things like that. It has a little fan like blades that act to chop up food that is to big to go down the outlet hose. also look under the machine if you can ,but in most cases you must remove 4 screws to get the bottom kick plate off, Also check all the spinning arms to make sure they are turning correctly. hope this helps
May 02, 2012 | GE Dishwashers
Water doesn't drain out of bottom.
Broken glass is caught in the pump. a take apart cleaning of the pump and drain hose is in order.
Mar 13, 2010 | Maytag MDB9600A Jetclean II Built-in...
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Oct 19, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher loud in beginning cycle and drains early
sounds like you have 2 problems however generally speaking (most makes) of dishwashers go into drain mode when there is a fault elsewhere, however is this set up properly, is the waste pipe end high enough to allow the water to actually fill up (only about 30cms of water aprox)so it doesn't flow straight though to the waste. the noise could just be an empty pump, it runs dry after a while, and makes a screeching noise eventually? check installation pictures to see if its set up right, you may have also a leak somewhere check all other connections and pipes
Sep 21, 2007 | Maytag MDB7100AWB Dishwasher
GE Profile PDW8400J Built-in Dishwasher Logo
139 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
