The printer has a jam and it is stuck sending a cleaning page. If you cure the jam, then things will return to normal. (You may be able to get 1 sheet through the manual feed, too)
I suspect mechanical problems, started with cracked plastic items. We have assembled a Service Kit (8400-Z1) for our field technicians, which we call the Camshaft Pivot kit, containing an updated Pivot Plate (which pushes against the oil roller. The 2 camshafts also have similar functions, one in the same area, and one at the transfer point. They always fail together, so that's why you should change them all.
Look at this video and see if this is too involved for you to do-it-yourself. You may need a trained tecnician.
Whit
Item, Inc.
