Question about Ricoh Aficio 450 Copier
Sc350 when i was make a copying on my copyer the sc 350 appear
  • 1 more comment
  • mahmoud shahat
    mahmoud shahat Jun 13, 2008
    I'm too angry i was trust in your system to solve my problem without money
  • mahmoud shahat
    mahmoud shahat Jun 16, 2008
    I thank you too much
    you sold my problem.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Stand by...
    I'll look it up.
  • Ricoh Master
  • 2,794 Answers
Image density sensor is dirty. Usually caused by toner being dumped on it.
You will have to call a tech to see if the sensor is broken, dirty. It requires removal of the drum and inspection of the sensor.
Posted on Jun 13, 2008
  • Tim Babcock
    Tim Babcock Jun 13, 2008
    This isn't a great picture of is because we couldn't turn the flash on so as not to damage the drum but the image sensor is the circuit board located above the drum.
    If you have a way of visually inspecting the condition of the sensor for obvious wear and tear, and you see cracks in the board, then it will have to be repaired.
What is service code sc350 and how do I fix it?
SC 350: The most common sensor ID dirty: Clean the ID sensor
Jun 21, 2011 | Gestetner DSm755 Black and White Copier
SC 350: The most common ID sensor dirty: Clean the ID sensor
Jun 21, 2011 | Gestetner DSm745 Black and White Copier
The copy of xerox is not dark and only half of the band paper and the copy is have a line and the error back to SC350-03
Clean the ID sensor !!
Possible Cause of SC code:
ID sensor dirty
ID sensor defective
IOB board defective
HVSB board defective
Defective drum
Feb 04, 2011 | Office Equipment & Supplies
Poslem poveke stranici kopiranje se pojavuva kljuch so functional problems SC350-01.Aparat Ricoh 450.
sc 350 is the ID sensor error. clean the ID sensor and it should be fine. the ID sensor is located above the drum unit.
Oct 27, 2010 | Ricoh Aficio 450 Copier
Error sc 350-1
ID sensor error
dirty id sensor-- pull out the drum unit and from the right door clean the id sensor (above the drum)with a dry cloth
Jan 07, 2010 | Ricoh Aficio 450 Copier
Solve Your ''aficio 350 functional problems sc350 03'' Problem Now!
sc 350 is toner density problem. many things cause this. bad developer, drum, id sensor, charge roller, blank lamps. you need a tech to look at it.
Dec 31, 2009 | Ricoh Office Equipment & Supplies
I have pagepro 1300W poor quality copies
please your copyer couver is open and out of you in rcartriese out of copyer and clean air compres and check the fuzer light and punch roller and dram roller is also is currentluy ok and aply paper and start copyer.
Sep 15, 2009 | Minolta PagePro 1300W Laser Printer
SC350-01 error code
Probably just a dirty "ID sensor". If you remove the drum (carefully) and set aside. Open the right cover, and towards the back of the machine above where the drum sits there is a small LED sensor mounted pointing down toward where the drum sits. Clean this with a tissue, put back drum and try.
If this fails, then the sensor is bad (or broken wire), or there is a circuit board problem (serious). Either IOB board or High voltage board.
Hope this helps.
Please rate solution
Apr 15, 2009 | Office Equipment & Supplies
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
220 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
