Question about Panasonic PT-47WX49 47" Rear Projection Television
Setting Color on TV
I just bought the Panasonic PT 47wx49 used and I can't seem to get the color right. Is there a site that goes over how to the set the color correctly?
  • Anonymous Oct 18, 2008
    I have a blue or yellow shadow on right side of screen
    Scholar:
  • 78 Answers
Hi Amber3,
I would recommend reading the information available on Panasonic's website. There are links for Frequently Asked Questions (FAQ) which may be helpful.
The manufacturer's website lists in their FAQ the Panasonic plasma TVs include an enhancement feature for blue and green colors, and instructs how to turn the feature off if needed. Visit http://www2.panasonic.com/webapp/wcs/stores/servlet/vSupportFAQDetails?idval=UCM_PRD_CNT_001993&pagetitle=FAQs+for+Plasma+TVs&contentType=FAQ#tv17 to see what Panasonic recommends.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 13, 2008
The color goes out on my panasonic PT-47WX49E TV.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
May 11, 2012 | Panasonic PT-47WX49 47" Rear Projection...
PT-47WX49 picture quality
well its sounds like the conversion problem you can alin. if you have no experience would not try it call tv repair shop to get it fixed
Feb 17, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic T.V...
What is your tuner source? Cable,Satellite, antenna?...accordianman
Nov 13, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Colors are blurred, Please HELP
I think you may have changed the color control function slightly. It is commonm and you just need to go to the tv menu and correct the fault.
Sep 14, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47wx49 color distortion
you have convergence trouble and possible require ic's to repair the problem.
Aug 22, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47wx49 47in
One of the resistors in the circuit connected to one of the ic's has burned out or changed value due to heat caused by short in previous ic before it was changed.
Mar 06, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 Convergence IC
usjavelin. I have the pdf files for the tv. I own the same one. I can send them to you if you'd like.
Dec 16, 2006 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
209 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
