Question about Fisher and Paykel Dishwashers
Fisher & Paykel dishwasher model no. DW60CSW1 not washing property; when cycle finished I find "powerball" slightly dissolved in bottom of dishwasher or soggy in powder container. Should I ditch the "powerball" and go back to plain old dishwasher powder??? Or is it more sinister? Many thanks
futureloginn
  • 734 Answers
SOURCE: Dishwasher
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Posted on Dec 02, 2008
  • 351 Answers
SOURCE: Problems with Fisher & Paykel Nemo model DW681.
is there somthing stuck in the wash motor,can you hear a humming noise ? if yes remove motor and see if you can turn it by hand.hopr this helps.
Posted on Mar 14, 2008
rpbuice
  • 161 Answers
SOURCE: powder not dissolving drain/inlet light sometimes flashes
I would guess the detergent door is open and the powder comes out so, If water is going in then the pump is not pumping.
Listen for the water to fill then after it stops open the door to make sure it's full of water. If no water or not enough then replace the water valve. If you have water then the pump is not pumping.
Posted on Dec 12, 2008
RescueTech
  • 145 Answers
SOURCE: tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
You should not use anything other than powered dishwasher detergent in these products. They are not designed for tablet-style detergents. The reason is because the dispenser does not "open" during the wash cycle like you would see on a conventional dishwaser. The incoming water pours over the detergent and releases the mixture out the bottom of the dispenser. If you need a user guide, you can get one here: http://fisherpaykelparts.net/index.php?blockitemid=29
Posted on Jan 23, 2009
SOURCE: Fisher & Paykel Nemo Dishwasher
try ensuring that the container is completely dry before putting in powder
Posted on May 18, 2009
I don't know where to put the new Finish tablet in the Fisher and Paykel dishwasher. Where or what is the Dry Dispenser ?
Hello Susanna Davies,
Generally a round cap immediately next to the
washing powder dispenser...
Known as "FINISH" or "Jet Dry"... as it really does
keep spot off of your dishes & especially glassware.
Amazon com ishwasher dry agent Tools Home Improvement
I tried to look up Fisher & Paykel...
but without a specific MODEL NUMBER
I could not pull an OWNERS MANUAL to demonstrate.
look here for FREE documentation
ManualsLib Makes it easy to find manuals online
SEARS is the last place I would recommend buying parts
(but that has more to do with integrity & respect)...
Their parts, guarantees & prices are suddenly competitie
Dishwasher Detergent Dispenser Part Number 526860 Sears PartsDirect
Hope this helps
Carnac the Magnificent
Sep 23, 2017 | Fisher and Paykel Dishwashers
I have a fairly new Fisher and Paykel double drawer dishwasher. A problem has developed all of a sudden whereby the Finish powerball tablet does not completely dissolve during the cycle (top drawer only),...
The water temperature is not coming up to the required level. The heater might be failing. Will need a technician to fix unless you are very savvy with technical repairs. Have you tried using the detergent powder in the dispenser to find if results are different.
Feb 05, 2014 | Fisher Dishwashers
I have a Fisher Paykel DD24 dishwasher and when using top drawer after wash cycle is complete there is always water in drawer. Top drawer is unable to drain water after wash cycle is complete...what can I...
If the cycle is complete and dishes are clean, then you need to worry. Try to pull the drain hose up a bit under the sink. Also buy a Finish dishwasher cleaning kit and run dishwasher as per instructions on the kit. That should clean any obsrtuctions in the drain side.
Nov 20, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
Customercare
Generally what type of detergent you use depends on what is recommended for the dishwasher. I am not sure which model of fisher and paykel dishwasher you have. But my opinion is that dish drawer type dishwashers work better with normal Finish powder detergent. It is not designed for tablets. The size of the wash space is small and it works on the principle of short and quick wash cycles. So the powerball is an overkill. Now about the streaking, this could be linked to the powerball but also you need to check if the rinse aid is present in the dispenser and also that you have selected the appropriate meter level for it being dispensed. 0 means no rinse aid and 5 is too much.;
May 01, 2013 | Fisher and Paykel Dishwashers
Dishwasher tablet not dissolving during wash cycle
I am not sure if you can use dishwashing tablets with this model of dishwasher. These are designed mainly for powder only - you should be able to shut the detergent compartment door before starting the dishwasher.
Make sure the compartment is not blocked preventing inlet water from circulating through.
Dec 30, 2012 | Fisher and Paykel Dishwashers
Fisher and Paykel Dishdrawer-DS605SS F4 fault code
No temperature increase has been recorded when the element is on.
The element is not connected.
The element has gone open circuit.
Temperature sensor or electronics ADC has failed.
Oct 04, 2012 | Fisher and Paykel DishDrawer DS605FDSM...
My dishwasher DW60CSX1 is approx 3-4 years old and is now not cleaning dishes. The tablet is often still in the bottom half dissolved and the dishes are dirty & wet. I've checked the filter, the arm...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 06, 2011 | Fisher and Paykel DD24DCFX6 Dishwasher
When we start our dishwasher it sounds fine you can hear the water ect, after it has finished cycle the soap block hasn t dissolved an dishers stil dirty
water not circulating through pump..... check arms for blockeges... manually put water into wash chamber then start..... if this worked.. replace solenoid
Feb 28, 2011 | Fisher and Paykel 24 in. DS603H SS...
Fisher and Paykel dishwasher noisy fan
Have you got your dishwasher on an extended drying cycle?
Normally it works for about 10 minutes after the wash cycle is complete - not hours.
Jan 21, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Tablet falls out & doesn't dissolve especially on fast cycle
Hi and wlecome...
Jan 22, 2009 | Fisher and Paykel 23 in. DS603H W Built-in...
Dishwashers Logo
280 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
