Question about Bosch Dishwashers
Bosch hydrosensor dishwasher won't start
Had an engineer in a few weeks ago and he just pressed the reset buttons. Do you have the machine on when you do this? How long do you hold the 2 buttons in for?
  • 1314 Answers
SOURCE: Bosch classixx check water light
ok sounds like a drain promblem love your do it your selfness but one thing you must keep in mind its under warrenty and if you mess with it you could void your warrenty if you have a cancel drain option try that if it still doesnt drain call for service
Posted on Mar 18, 2008
SOURCE: Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Posted on Apr 17, 2008
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
SOURCE: Bosch HydroSensor Dishwasher (SGS5342GB/17) -
Hi Julie,
The sprayer arms may need replacing.
Posted on Aug 21, 2008
VtToolMan
  • 704 Answers
SOURCE: Can't start the dishwasher, lock button is lit up.
Hello Albert, On the Jenn-Air dishwasher you have, you have to hold down the "Heated Dry" button for 3-5 seconds to unlock the control panel.
This should unlock the controls so you can again use the dishwasher normally.
Since you''re likely going to have this dishwasher for some time, I've included a link where you can download a free owner's manual for it.
I would print out a copy for your future use and reference. I also have a file on my computer that I title "Home Appliances and Equipment" which is where I download and save an electronic copy so I always have a backup copy saved, since manuals aren't always readily available on the web, as the appliances get older.
http://www.jennair.com/assets/product/6_920374_A.PDF
The info on locking and unlocking the dishwasher can be found on page 13 of the manual.
I hope you find this Very Helpful and best regards!
Posted on Nov 23, 2009
Testimonial: "Thanks for the detailed info about my question, VtToolMan, I greatly appreciate it. However, I tried to unlock it that way, but it didn't work. "
Bosch SHU9915UC won't start. all lights come on but unit doesnt start. is there a reset button somewhere in this unit?
Reset the dishwasher by pressing and holding the "Start" button for at least three seconds. Depending upon the Bosch dishwasher model you have, you also can push the "Cancel-Reset" button to reset the dishwasher. Select a new cycle and press "Start."
Jan 03, 2018 | Bosch Dishwashers
How can I restart my dishwasher
Press and hold the start button for a few seconds. The dishwasher will drain and reset
Aug 30, 2016 | Bosch Dishwashers
Cannot push the start button of my wirlpool dishwasher (WDT710PAYM3)
If you can get to the motor, unfortunately, you may have to pull the dishwasher out to get to it unless you can access it from the adjoining cabinet. The motor may have a red button on the back of it which is the "Reset" button. Press it in and if it clicks, you have reset the motor. I hope this helps, good luck.
Oct 22, 2014 | Dishwashers
Bosch silenceplus 50dBA won't start
After 3 seconds of reset (start), turn the dishwasher off, wait a few secconds, turn it on, and use the arrows to select the washing mode (try Auto, perhaps) and see if this solves your problem.
Apr 12, 2012 | Dishwashers
Model not sure 10yrs? HydroSensor,(only title On
Try and drain water out completely and restart cycle. Note if water comes in and if so, once in is there a hum (audible) when in effect the motor should run. If so, the motor is jambed and needs to be cleared. Check the door limit has not malfunctioned as well. It can be bridged temporary to confirm.
May 27, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
Bosch Dishwasher Maxx classixx Model S9H1B Lights stuck on end and last program.... will not reset nor start Think it just needs resetting ...but how?? Was working fine up to now Regards M
look carefully at operating buttons they will have 2 marked with a line with dots at either end, open door press and hold these 2 buttons usually 2 and 4 as from left too right, turn on keeping fingers on these buttons after a few seconds end light will come on turn off at main switch then back on again should work after that.
Nov 10, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch dishwasher will not drain
how do you disconnect the waste pipe from the back of a Bosch hydrosensor dishwasher
Aug 09, 2008 | Dishwashers
Bosch hydrosensor dishwasher works Ok except the water is cold! Suspect heater or thermostat failed but is there a known common problem with these?
I have a Bosch hydro sensor dishwasher but no matter what I do it will not wash the dishes/cups,glasses properly. It leaves a scum on every thing
Jul 06, 2008 | Dishwashers
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
143 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
