Computer running XP says scanner not connected yet it shows up as a USB connection which I select before asking it to aquire. Converter lights up.
  • jimrixr Nov 05, 2010
    I removed and reinstalled the software. I also got a different unit from the supplier.
    It is a Centrios from " The Source ". It came with Arcsoft media impression Software.
    My processor runs at 1.2Ghz there was a suggestion somewhere that they wanted 1.6Ghz.
  • jimrixr Nov 22, 2010
    I was unable to resolve my problem and have returned the unit, to the supplier.
  • 3,530 Answers
Uninstall and reinstall the scanner software. By the way, what is the brand and make?
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on Nov 04, 2010
Error message
Incorrect or incompatible driver. See if there is an updated driver.
Mar 08, 2014 | VuPoint Solutions Digital Film Converter...
My notebook computer only has USB plug and it does not has serial port plug (RS232). I bought a USB converter cable for the RS232 plug. The notebook computer reconciles the USB converter cable and not...
Tthe Capshare only works with XP or Windows 7 Ultimate which has a virtual XP inside it ( a retrofit for outdated software).. I will not work with VIsta.
Feb 13, 2011 | HP CapShare 920 Handheld Scanner
250 error on documate 510 xerox
Symptom: When scanning you receive an error 250. Cause: This problem can be caused by several different things but is often a driver or communication problem. Solution: Here are several solutions that can resolve this problem:
Solution 1 - Check for communication problems
Using any of the following can cause communication errors:
  • USB hubs
  • Docking stations
  • USB extension cables
  • USB cables longer than 6'
  • Connecting the scanner to one of the computers front USB ports (desktop computer only)
Connect the scanner directly to a USB port on the back of the computer (or side for notebook computers) using a 6 foot or shorter cable.
If you still receive the same error message, try a different USB cable.
Solution 2 - Redetect the scanner with Hidden Devices
Windows Vista, XP and 2000 users
  1. Disconnect the power and USB cable from the scanner.
  2. Click here and select "Run" or "Open".
  3. The Windows Device Manager will open.
    • Click on the "View" menu then select "Show hidden devices".
  4. Click the "+" next to "Imaging Devices". This will show all Imaging Devices previously and currently connected to the computer.
  5. Right-click on the Visioneer or Xerox scanner name and left click on "Uninstall".
  6. If the scanner is listed more than one time, uninstall ALL occurrences of the scanner.
  7. IF you see "?Other Devices" in the device manager list, click on the "+" to view the list of Other Devices.
  8. Right click then left click on "Uninstall" for each occurrence of the scanner. The scanner may be listed as any of the following:
    • USB Scanner
    • USB Device
    • Unknown Device
    • 1200 DPI Scanner
    • (Your Scanner Model)
    • (any other scanners or cameras listed here that you no longer use)
  9. Click the "+" next to "Universal Serial Bus Controllers".
  10. Right-click every listing of "Unknown Device" and select uninstall.
  11. Once all instances have been removed from device manager, reconnect the power and USB.
Windows Me and 98 users
  1. Right-click on the "My Computer" icon on your Windows Desktop
  2. Select "Properties" from the list
  3. Click on the "Device Manager" tab
  4. Find "Imaging Devices" and click on the plus (+) next to it to expand the list
  5. Select your scanner, then click on the "Remove" button
  6. IF you see "?Other Devices", click on the plus (+) next to it to expand the list
  7. Select your scanner then click on the "Remove"; button – your scanner may be listed as any of the following:
    • USB Scanner
    • USB Device
    • Unknown Device
    • 1200dpi Scanner
    • (your scanner model)
  8. Close the Device Manager
  9. Unplug the scanner from the computer and from the power
  10. Plug the scanner back in to the computer and power
Solution 3 - Check for power problems
If the power for the scanner is plugged into a surge protector, battery backup (UPS), or extension cord, plug the scanner directly to the wall.
Solution 4 - Check for conflict with other devices
This error can also be caused by a conflict with another USB device.
  1. Disconnect all USB device from the computer (including the scanner), except for you keyboard and/or mouse
  2. Turn the scanner off
  3. Restart the computer
  4. Once the computer has fully restarted, reconnect and power on the scanner
  5. If the scanner works properly at this time, it means there is a conflict with another device on the computer
  6. It may help to isolate the two items by connecting one of them to a USB add-in card
Solution 5 - Test the scanner on a different computer
If possible, you should try the scanner on a different computer. If the scanner works correctly on a different computer, then the problem is environmental and may be related to your chipset. See solution 6 below.
Solution 6 - Check the computer's chipset
This problem can also be caused by the computer's chipset. To check the chipset:
  1. Vista, XP and 2000 users: Click here and select "Run" or "Open".
    ME and 98 users: Right click on 'My Computer', select 'Properties' then click the 'Device Manager' tab.
  2. The Windows Device Manager will open.
  3. Click on the plus (+) next to 'Universal Serial Bus Controllers'.
  4. This list will include your computer's chipset.
  5. The follow chipsets are known to have communication problems:
    • SiS 7001
    • VIA Rev. 5 or later
    • Open HCD
    • ALi
  6. If your chipset is one of those listed above or it is only listed as 'Standard', you can try updating the chipset drivers.
    • Contact your computer's manufacturer for more information.
  7. If the problem persists, you may need to use a USB add-in card.
    • This is a PCI card that will add more USB ports to your computer.
  8. For more information about USB chipset issues, see www.usbman.com.
Jul 12, 2010 | Xerox DOCUMATE 510 Flatbed Scanner
LS2208 displays no light
If the scanner is on a USB extension, they can be underpowered and will show up in the device manager but not work. This device like to be connected to a USB cord no longer then 4 ft or so.
Feb 23, 2010 | Zebra LS2208 Handheld Barcode Scanner
Need XP driver
You don't need an XP driver...the system uses either a USB connection, Keyboard Wedge connection or Serial connection. There are some other versions available. The 3070 memory scanner is an older version, but, doesn't use "drivers" as such. The best thing to do is contact the Symbol/Motorola Help Desk at 1-800-653-5350.
Cheers.
Billy Barcode
Apr 22, 2009 | Motorola Computers & Internet
Visioneer 9220 wont work
Dirty USB port. Try another Port. One of the 4 contacts is not making connection.
Mar 16, 2009 | Visioneer OneTouch 9220 USB Color Scanner
Dell laptop wont recognize ls2000 scanner
The LS-2000 is a "legacy" device to XP and the Nikon software. It needs to be connected to a true SCSI bus adapter, and it's actually pretty finicky about which ones will work in XP. Sorry, you won't be able to use this with your laptop.
Feb 28, 2009 | Nikon LS 2000 Film Scanner
Connecting Epson TM U220D printer with Laptop (having Windows XP)
Please verify if you properly install the port converter, its drivers.
Aug 31, 2008 | Epson TM-U220 Matrix Printer
All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code 2019
Step 1 - Verify the scanner's power and connection
  1. Verify that the scanner is turnned on
  2. If the Check or Ready light on the scanner is flashing, click VIS1023 - Check Light Blinking on ADF Scanner for more information
  3. Check that the USB cable is connected to both the scanner and the computer
    • It is recommended that the scanner be connected directly to the back of your computer with a 6 foot or shorter USB cable
Step 2 - Redetect the scanner in device manager
  1. Turn the scanner off
  2. Click Here and select "Run" or "Open"
  4. Go to "View" and choose "Show Hidden Devices"
  5. Click the "+" next to "Imaging Devices". This will show all Imaging Devices previously and currently connected to the computer.
  6. If listed, right-click on the DocuMate 510 then left click on "Uninstall"
  7. If asked to confirm the uninstall, click "OK"
  8. If the scanner is listed more than one time, uninstall ALL occurrences of the scanner
  9. IF you see "?Other Devices" in the device manager list, click on the "+" to view the list of Other Devices
  10. Right click on any instince of the scanner in this list then left click on "Uninstall"
    • USB Scanner
    • USB Device
    • Unknown Device
    • DocuMate 510
  11. Once the scanner has been completely removed from Device Manager, turn the scanner back on
If there is no Found New Hardware message when the scanner is turned back on and the scanner is not listed in Device Manager under Imaging Devices or Other Devices, this typically means the scanner is not communicating correctly with the computer. Try plugging the scanner into a different USB port or using a different USB cable.
Jan 08, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Open Questions:
Computers & Internet Logo
Alun Cox
k24674
