Question about Honeywell HZ519 Baseboard Heater
Honeywell HZ519 Baseboard Heater Manual - Honeywell HZ519 Baseboard Heater
SOURCE: Honeywell HZ517 Baseboard Heater
This troubleshooting approach may be sound, but you need a deep security star screwdriver to open the heater up. I have looked in specialty tool and electronics shops and no one has a screwdriver that gets in deep enough. You won't go anywhere without this screwdriver, so if anyone can suggest a source, that would be great.
Posted on Nov 30, 2005
Buffalo12980
  • 625 Answers
SOURCE: when i plug the heater in it does not work.
its difficult to make a homeowner an expert in troubleshooting his/her equipment if he/she has no technical background - but - I will try. First check the cord to plug connection. Is it tight? Does it look melted? Next, take the unit apart where the cord goes into the unit. Check the wiring path. Look at each connection. Look for burnt off wires at connections. Most connectors are the push on type and are mechanically fastened to the wires. if they are burned off you'll need replacement spade terminals and a crimping tool. (radio shack) has these. one wire will go through a thermostat and out to an element terminal. one wire may go through a thermodisc overload, then to the thermostat and then to the element. the other wire will definitely go straight to the element. there may be some extra connections for lights etc. if you have to take apart the heater make a diagram of which wires go where. use some masking tape with numbers written on it to make sure the wires go back to the same place you took them off.
Posted on Dec 07, 2007
  • 3 Answers
SOURCE: wont heat up
I have an HZ519 that stopped working as well. I found that the anti tip switch is in fact a mechanical weight type if switch and not a mercury switch. The problem I'm having is that the plastic stud that the anti tip switch mounts to is melting causing the switch to come loose and fall to the bottom of the heater and therefore stop working properly depending upon the position the switch is in when it lands.
Does anyone know if Honeywell has a retrofit for this problem?
Thank you,
Randy
Posted on Nov 14, 2008
sparktgo
  • 68 Answers
SOURCE: I need a manual for a farenheat F2345nwc baseboard
http://www.marleymep.com/Develop/prod_pdf/2500wiring.pdf
i think this is the same parent company
Posted on Oct 10, 2009
Testimonial: "EXACTLY what I was looking for!"
  • 128 Answers
SOURCE: DPDT thermostat for Singer baseboard heater.
as close as I've found
http://keithspecialty.com/k/67-411.htm
http://www.heater-store.com/specialty-thermostats_91_ctg.htm
Posted on Nov 02, 2009
My heater is not working at all only my power supply light is on
unplug the heater. remove the screws holding the control panel, pull the control out from the body of the heater enough to get the probes of an ohmmeter onto the connections that lead to the heating element. the ohmmeter should read less than 100 ohms. if the ohmmeter reads infinite ohms (open circuit), the heating element or the connections to it ate bad. if the heating element is bad, cheaper to buy a new heater. if the heating element is okay, repair connections or control.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Dec 31, 2013 | Honeywell HZ519 Baseboard Heater
How do I bleed the line of a baseboard heater?
there is ussualy a small thumb screw in the feed pipe to the unit in qestion, just loosen it and let air and some water out.
or on your boiler there will be a bleed vave sometimes there is evemn an auto vent valve
Oct 13, 2012 | Honeywell HZ519 Baseboard Heater
What is the use per KW Hr on the Honey well HZ 519-20
This unit uses 1500 Watts (1.5 kW) in one hour at its maximum setting. (12.5 A * 120V AC) The total cost will depend on how long the heater is on each day and the utility charges at the time of use (for example, if you have day/night rates).
The manual is available here: http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=fc5e11ee85619a5101b4c15f217911d6 .
I hope this helps.
Apr 04, 2011 | Honeywell HZ519 Baseboard Heater
Heater got tipped over now wont heat. It lights up when I power it on the display works, no HEAT. I have 5 small grandsons that live with me and this heater was quite expensive I need it to work and...
I do believe that there should be a tip switch under the feet and if it is broke off then you need to by pass the switch. You could use a small piece of dowel rod up inside to trip the switch and have heat.
Dec 13, 2010 | Honeywell HZ519 Baseboard Heater
Setting thermostat on Model HZ519
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Dec 08, 2009 | Honeywell (CT62B1015) Baseboard Heater
Heater wont heat
It sounds like the thermostat is loose and needs to be adjusted or replaced. Leave this to a professional if you don't know what you're doing. So many fires are caused by baseboard heaters.
Oct 01, 2009 | Honeywell HZ519 Baseboard Heater
Heater
Just fixed one, you will need a T-15tr driver, which is a security torx screw remover. Open back cover behind controls, check for
any lose wires. Heating element wire had become disconnected on the one I repaired. P.S. you will need an extension for the bit if it is just the bit, and not a screw driver.
Feb 17, 2008 | Honeywell HZ519 Baseboard Heater
Instructions
The manual isn't very helpful.
There are three modes to the heater. Hit the mode button once, and it will display the temperature of the room with a small flashing thermometer. Set it to whatever temperature you want - BUT don't hit the mode button again! If you hit it again, it will move through the timer mode, then continuous run mode (which displays a little circle in the upper left). Same goes for the timer. If you want it to shut itself down in up to 10 hours, press the mode button until you get to the timer, set the timer for however many hours you want, and then don't hit the mode button again.
It stays in whatever mode you set it to.
Stopped working?
Check for lint inside and on the edges, it may have blown and you need somebody to repair this, is it smoking at all?
Nov 29, 2007 | Honeywell HZ519 Baseboard Heater
Wont heat up
Thank you,
Randy
Nov 28, 2007 | Honeywell HZ519 Baseboard Heater
Honeywell HZ519 Baseboard Heater Logo
175 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
