Question about Alpine MRV-F407 Car Audio Amplifier
I have two red warning lights flashing on my Alpine MRV-F407, does this mean lack of power or that it wired up wrong. Other than this it sounds great.
4 Suggested Answers
trintek
  • 111 Answers
SOURCE: need a part for my alpine mrv-f407 amp
as far as i know, nobody stocks or sells replacement cases for this amplifier, your best bet would be to search for a good dead one on ebay or somewhere similar... failing that, you can take the case apart and use an aluminum or metal paint to repaint it after sanding it. the reason for using a metal paint is that most regular paints will have an unwanted insulating effect and not allow the case to perform its intended purpose, giant heatsink. you can also try to use metal polishes or an extremely fine grit sand paper (1000-2000 grit) to remove any scuffs and polish it at the same time, but this will remove any factory paint. i believe krylon or one of the other brands makes a metal tint paint that is translucent, i have used it to color match amps to cars and it seems to work well. it can be found at just about any napa or other automotive shop and i believe it is intended for wheels, bumpers, etc.
hope this helps,
trin
Posted on Nov 16, 2007
  • 631 Answers
SOURCE: ALPine mrv-1507 Need helppp!! powere light flashes red
According to the owner's manual, it means that the battery voltage is low. Page 13:
http://vault.alpine-usa.com/products/documents/OM_MRV-1507.PDF
Posted on Oct 27, 2008
  • 111 Answers
SOURCE: I need to know what the wattage the alpine
RMS Continuous Power (at 12.0V)
Per channel into 4 ohms...............40W, 0.08% THD
Per channel into 2 ohms ..............50W, 0.3% THD
Bridged into 4 ohms.....................100W, 0.3% THD
RMS Continuous Power (at 14.4V)
Per channel into 4 ohms...............60W, 0.08% THD
Per channel into 2 ohms...............80W, 0.3% THD
Bridged into 4 ohms.....................160W, 0.3% THD
Max. Power (at 14.4V)
Per channel into 4 Ohms..............120W
Bridged into 4 Ohms....................320W
This should help.
Posted on Apr 30, 2010
The protection light comes on when I turn it on.
Check your ground wire. It should be solidly connected to the vehicle chassis in a a paint-free location. Also make sure the speaker leads aren't touching each other at the input on the amp. Then make sure your live power wire has a good connection to the battery and the amp. Finally, check the speaker leads along their entire length, and make sure they are not touching the vehicle chassis.
Mar 09, 2011 | Alpine MRV-F407 Car Audio Amplifier
I need to know what the wattage the alpine mrv-f407 puts out when its bridged or only running 2 channels?
This should help.
Apr 30, 2010 | Alpine MRV-F407 Car Audio Amplifier
Alpine mrv-f345 cuts off when...
Yes sounds like your not getting enuff power from the battery could be your alternator you should have it tested. Also have you try'd a capacitor? I put one in my car and it stopped cutting out...
Feb 05, 2010 | Alpine MRV-F345 Car Audio Amplifier
I obtain recently a car amplifier model: mrv-f400 of alpine, i want information about the correct way to instal thanks
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=MRV-F407
THE ABOVE LINK WILL DOWNLOAD A MANUAL FOR THE SIMILAR MRV-F407 AMPLIFIER. IF YOU WANT TO PURCHASE THE EXACT MANUAL, YOU CAN OBTAIN IT FROM PACIFIC COAST PARTS AT 800-421-5080 PART NUMBER=68P50958W56. IT IS AROUND $5.00 PLUS SHIPPING. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 24, 2009 | Alpine MRV-F540 Car Audio Amplifier
Alpine mrv-1507
Your amp. got damaged the audio amplifiers IC's thats why it's going on protect mode.
Jun 05, 2008 | Alpine MRV-1507 Car Audio Amplifier
Blinking protection light on mrv-t757 amp
Could be the power supply or output stage electrolytic capacitors.
Possibly breaking down/drying out inside.
Mar 17, 2008 | Alpine MRV-T757 Car Audio Amplifier
Need a part for my alpine mrv-f407 amp
hope this helps,
trin
Nov 08, 2007 | Alpine MRV-F407 Car Audio Amplifier
Alpine mrv-t757
Hi Big Nick,
Sounds like you have got almost all the good out of those Subs. You can find the screws you need at almost any hardware store or Auto parts store. The light is becase you are dloading the amp with low OHMS.  You may need use one channel and Run the wiring like written blow to get the power problem to disappear.
S1+ = Kicker comp cvr sub coil 1 positive
A+ = Amplifier Positive output.
A+ to S1+
S1- to S2+
S2- to A-
Oct 18, 2007 | Alpine MRV-T757 Car Audio Amplifier
Car Audio & Video Logo
69 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
