Question about Angelo Brothers Westinghouse (r) Savona ES Ceiling Fan (72087)
Removing ceiling fan blades
I want to remove the blades of my ceiling fan but i can't seem to do it. looks like there's a cap or sort of cover that can turn. done that; but i can't seem to pull it out or take it out. it's a 5-blade ceiling fan made by angelo brothers. hope you could help me here.
    Problem Solver:
  • 7 Answers
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Posted on Jul 12, 2009
This fan isn't even worth fixing! When you're buying a fan,look for blade pitch or CFM's. Don't buy anything under a 12 degree blade pitch. 14 degree pitch would be better. Remember, you get what you pay for!
May 26, 2013 | Westinghouse Contempra Trio 42" Ceiling...
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Sep 28, 2011 | Dryers
My bathroom Broan exhast w/light makes a constant clicking / tick tock sort of noise when the fan is not running. as soon as I turn the fan on the noise stops and then stops after I turn the fan off, only...
remove the cover and clean anything in the vent , check the fan for anything that could be touching it, as the back draft comes through the vent, something could just be touching the fan blade as this draft makes the blade turn slowly, which would create a ticking noise
Jul 10, 2011 | Broan-NuTone (8663RP) Ceiling Fan
My fan shakes and wobbles even on low and it also seems to by loose where it mounts to the ceiling. What do I need to do.
I imagine you have a ceiling fan hanging from the roof?? These fans are mounted on a hook which is loose from the roof. This is to prevent any vibration being transfered to the ceiling itself. Generally, there is a domed cover to hide the hook and associated wiring to the fan at the point of attachment to the ceiling. This dome should have a gap of a couple of millimeters away from the roof. If the fan is vibrating, it can also occur because one of the blades may be loose or dislodged. Try tightening up any screws holding the blades to the motor body or refitting the blades. If this doesnt help, you may need to remove all the blased and weight them seperately. 1 may have "thrown" a balance weight and is now unbalanced. Much like an unbalanced car wheel vibrates. All the blades should weigh the same. I used to fix these by supergluing metal washers to the top side of the lightest blades to make it up the weight of the heaviest. It works but someone may have a better idea...
Jun 15, 2011 | Heating & Cooling
Remove ceiling cover plate of Hampton Bay Antigua. This is the model that does NOT have srews on the outside of the coverplate that you loosen before turning. We've tried everything. Left, right.... You...
first you will need a ladder and a screwdriver/phillips a couple wire nuts or electrical the "top" of the fan you will see a bowl shaped cover it will have usually no more than two screws in it..loosen or remove those screws to access the fan hanger inside.once you get that far inside you will see several wires .undo each wire seperatly and cover with a wire nut or electrical tape(please make sure your power is off to that circuit) once you have unhooked all the wires from the fan and secured them out of the way. lift the fan out of the hanger itself (sometimes it is easier to remove each blade from the motor housing before removing the fan from its hanger ) those screws can be found at the base of each blade on the motor housing..If you are moving or adding a cieling light be sure to remove both parts of the fan hanger..the second part will still be attached to the cieling..usually two screws holding it into place..if just replaacing the fan,,you can sometimes leave the second part there and hang the new fan with it..
look carefully there are screws somtimes with a grommet or paint as these were built in factorys all over the world and are very inconsistent if you rrally cant find screws and it will twist it is always left
left is loose right is tight
lefty loosy righty tighty lol
my grandad taught me that one i always remember
Feb 26, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
52 inch ceiling fan hampton bay--Humming..... Tightened blades,adjusted fan blades, changed to a new wall switch, blade to ceiling height O.K.... still humms, what can I do??? thank you
Sounds like you have covered all the bases already, but there is the small possibility that it is the housing vibrating. You can remove it and buffer the adjoining parts with electrical tape on the inside (so as to be hidden). Otherwise, you have a fan that hums (many just do). May need to exchange for a known quiet model like a Hunter or Panasonic.
Farmerbear at
Oct 01, 2010 | Hampton Bay 24002 Ceiling Fan
In general, the steps are:
1. Turn off power at the breaker -- not just the light switch.
(There are still "hot" wires in the junction box when "Off".)
2. Take out any light bulbs.
3. Remove any light globes. Some screw in, but most are held by springs so just pull gently with a bit of force.
4. Remove fan blades. Most have a spring at the inside edge of the blade -- press down on the spring and push the blade toward the fan motor.
5. Remove the ceiling mount cover. There is usually a circular ring up next to the ceiling; just twist it off with your hands ("lefty - loosy, righty-tighty").
6. Unscrew the ceiling mount screws. Usually there is one or two in a "simple" hole, and two one "sliding" slots. Take out the "simple" screws, and loosen (but don't remove) the "sliding" screws. Be careful not to drop screws or washers into the fan motor.
7. Twist off the ceiling mount cover to expose the wiring.
8. Disconnect all wires. For safety, put a wire nut on the wires from the ceiling.
9. Tip the fan and remove it from the ceiling mount. Keep in mind that the fan is pretty heavy, and you're on a ladder!
NOTE: Be careful not to put any pressure on any of the blade holders, especially if you intend to re-use the fan. If you do, the blades will wobble.
10. If you're installing a new fan, you can probably re-use the mount. If you want to put up a simple light fixture, remove the mount by unscrewing the two long screws holding it to the junction box.
Jul 17, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
How to replace a water pump on a 1995 bmw 318is
  1. Disconnect the negative battery cable. Drain the cooling system.
  2. Remove the distributor cap and rotor. Remove the rotor adapter, the dust shield and the distributor housing.
  3. Remove the fan. The fan must be held stationary with tool 11 5 030 or some sort of flat blade cut to fit over the hub and drilled to fit over 2 of the studs on the front of the pulley. Remove the fan coupling nut; left hand thread-turn clockwise to remove.
  4. Remove the belt and pulley.
  5. Remove the rubber guard and distributor and or upper timing belt cover.
  6. Compress the timing tensioner spring and clamp pin with the proper tool.
Observe the installed position of the tensioner spring pin on the water pump housing for reinstallation purposes.
  1. Remove the water hoses, remove the 3 water pump bolts and remove the pump.
To install:
  1. Clean the gasket surfaces and use a new gasket.
  2. Install the water pump in position. Note the position of the tensioner spring pin. Torque M8 bolts to 16-17 ft. lbs. (20-24 Nm) and M6 bolts to 6-7 ft. lbs. (8-10 Nm). Connect the hoses.
  3. Release the tensioner from the holding pin. Install the upper timing cover. Install the pulley and tighten the bolts to 6-7 ft. lbs. (8-10 Nm). Install the belt and tighten.
  4. Install the fan, distributor housing and dust shield. Tighten the rotor adapter to 39-47 ft. lbs. (55-65 Nm). Install the rotor, O-ring and cap.
  5. Add coolant and bleed
Dec 30, 2009 | BMW 318 Cars & Trucks
I have removed the light fixture on my hunter vista iron model 20538. It looks like there should be some sort of a cap that goes on the bottom of the switch fixture. do you know how I might locate one?
There is usually a blank cover that comes with tyhe fan when new, but when installing a light kit they usually get trashed ,, Try any bnuilding supply store that stocks the Hunter fans ,, bring the part for the light fixture so you can get the exact size and mounting screw araingement as the old kit .
Aug 15, 2009 | Hunter 20537 / 20538 The Vista Iron...
Angelo Brothers Westinghouse (r) Savona ES Ceiling Fan (72087) Logo
495 people viewed this question
Top Angelo Brothers Dryers Experts
Are you an Angelo Brothers Dryer Expert? Answer questions, earn points and help others
