Question about Thermwell Water Heater Blanket
I have a 50 gal State water heater. I need a blanket that will fit it with measurements of 57in tall and 66in wide. Any suggestions since most blankets are 48in
Unfortunately, virtually all mass-market water heater blankets are 48" wide. One option is to buy a 32 sf roll of R13 ComfortTherm wall insulation (15" wide) and install in four segments. Unlike regular wall insulation, this product is sandwiched in plastic, making it much easier to handle and install (and neater) than kraft-faced insulation. It's made by Johns Manville and available at Lowes for about $9 (JM product number B011, Lowes item #44026). You'll need a suitable tape for the seams.
By the way, when calculating blanket width, you must add insulation thickness (times 2) to the tank diameter. My heater is 20.5" in diameter, so for 3.5" wall insulation, the effective diameter is 27.5", so the circumference is about 86".
Mass market blankets are 75" wide, and come in 1.5", 2" and 3" thicknesses. These can handle tank diameters up to 21, 20 and 18 inches, respectively.
Posted on Nov 09, 2010
Rheem RHEEM 50 GAL ELEC TALL Water Heater 1.5 yrs old, power at the elements, new elements installed new thermostat installed, still no hot water.
Hello Check the red overtemp reset button at the temp control.Check for contintuity at the elements with a volt meter (pull one wire off first) they should have a reading otherwise they are open & shot.Last is overdrawing (busted pipe) shut off the cold water supply for a 1/2 hour and open it back up and feel the hot water supply pipe.Is it hot?The tank can't keep up with the demand.
Sep 16, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Installed a new 50 gal electric Rheem water heater. Within about an hour the tank began making a strange bell like ringing. When you shut the power off the noise stops. What the heck?
Sounds like pressure building up in your line to much. Did you make sure to get all of the air out of the system by opening up your relief valve?
Jun 03, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL NUMBER 81V52D C SERIAL NUMBER RH 1297B30669 50 GAL US TANK ELECTRIC WHAT IS THE UPDATED VERSION?
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
May 25, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
RHEEM 50 GAL ELEC TALL Water Heater 6YR SC 83VR522: I just purchased a home with this water heater and...
The two most common problems Ive seen that fit this description are, incorrect voltage going to the water heater or the fill tube on the inlet side of the unit has broken off in the tank. The voltage problem can be checked with a tester. Ive seen breakers go bad and cause this. The fill tube can be checked by removing the cold water connection at the tank and feeling to see if the tube is still hanging there. Hope this helps.
May 17, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Apr 19, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a Rheem 81v52dt 50 Gal Elec heater. I can not get enough hot water to fill a tub.I have turned both thermostats all the way up. I have checked both elements with an ohm meter. I got a 220 reading on...
There should be a flip flop circuit in your heater that switches between the two heaters. I don't think they both heat at the same time. Check the rating on the indivitual heat element then compare that with the data printed on the heater RE: maximum WATT rating.
Now then, what did you miss - I'm thinking you missed the ohm reading. You measured 220 Volts but you did not check to see if the element is burned out or not. Move your meter to OHM and take a measurement with the power turned off. If the reading is "open" the element is buned out. If you get some reading beside 'open' the element is probably able to carry current.
Have you drained the sediment from your heater recently?
All the way up is a dangerous setting by the way. I suspect you know this.
Thanks for your interest in FixYa.com
Feb 19, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 gal keeps tripping breaker. What is the problem?
Do not touch water heater that is tripping breaker.
Open following link for troubleshooting steps:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 05, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Thermwell Water Heater Blanket Logo
245 people viewed this question
Top Thermwell Water Heaters Experts
Donni Steen
Paul Carew
Are you a Thermwell Water Heater Expert? Answer questions, earn points and help others
