Question about Roper RES7646KQ Electric Dryer
Cord Connection need diagram of connecting cord to the back of dryer there are no color codes they all look alike.
  • Anonymous Sep 28, 2008
    need diagram for power cord
  • 413 Answers
If your dryer cord is flat and gray, then simply attach the two outside wires from the cord to the left and right screws on the terminal block. Connect the center wire of the cord to the center screw of the terminal block. The only important wire is the center wire of the cord goes to the center screw of the terminal. The two outside wires don't matter.
Posted on Jun 13, 2008
Hi! whats the color codes of power supply
Posted on Jun 25, 2008
  • allan salipada
    allan salipada Jun 25, 2008
    do u think all d color codes are the same function?
Replacing electrical cord
if you buy a color coded cord and plug then red and black go on thee 2 outer terminals of the power terminal and the white wire goes between these as this is the neutral connection and if it has a green ground wire connect this anywhere to the metal case of the unit, if its a gray cord with no colors then the 2 outer wire on the cord go to the outer terminals on the units power terminal block and the center wire on this cord goes to the center terminal on the unit
Jul 28, 2012 | Roper REX4634KQ Electric Dryer
Need wire diagram for 4 wire cord [color code[
Here is a tip that will help you with that problem...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
May 17, 2010 | Dryers
How to replace 3 wire cord with 4 wire cord
On the back of the dryer where the cord connects, there are 3 terminals for the connection. The two outside terminals are for the power wires, the two colored wires at the edges of the cord. The center terminal is for the insulated center wire of the cord, the neutral, white in color usually. There is also a strap that may be connected to this center terminal, that should be removed and bent to the side, The bare or green wire in the cord connects to where that strap is connected to the metal back of the dryer.
Mar 28, 2010 | GE DVLR223 Dryers
Maytag electrical dryer model # PAV2300AWW power supply layout
The following link explains how to properly connect the power cord to your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Pay particular attention to WHICH configuration you have. Your power cord will either be a 3-wire or 4-wire configuration. NOTE: If the wires are not color coded, the outer two wires (left and right) will be the HOT leads. The center conductor is the neutral.
If you're new home is equipped with a 4-wire outlet, you are required to update the dryer to a 4-prong power cord to be in compliance with the National Electic Code.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 27, 2010 | Maytag PYE2300AY Electric Dryer
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
Replacing eletrical cord to a four prong cord. there are only three connections. there are no color codes to make it easier. How do I replace the cord
Dryers are 220 Volts AC and the outer connections inside the dryer are "hot" or live legs (black or black and red wires) of the circuit, while the center one is typically the neutral (white) wire.
The difference between a 3 prong plug and receptacle and a 4 pronged one is simply that the 4 prong plug and receptacle has a dedicated ground integrated into it, whereas the 3 prong plug is what's commonly referred to as an ungrounded circuit. There is no dedicated ground in a 3 prong plug and receptacle that makes a separate, grounded connection from the dryer to the receptacle to the electrical panel of the house.
Also, please look at either the back of the dryer for a basic wiring diagram, or look inside the access panel where the dryer cord is connected. There should be indications as to what each terminal is for, as I stated, typically the outer connections are the "hot" while the center one is typically the neutral. If you notice a strap running from one of the dryer's connection terminals to the cabinet/frame of the dryer, that is the neutral. The others are the hot terminals, which are the outside ones.
Look for a green grounding screw inside the dryer's electrical connection section. That is where the green wire on the cordset would be connected/terminated.
If you wish, you can get a free Installation Guide for your dryer at the following link to download and/or print out at:
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0520950.pdf
It will show you the connections for both a 3 and 4 wire cordset.
Hope you find this Very Helpful and best regards!
Nov 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
We bought an electric dryer from sears outlet
220 Cords are usually color coded - BLACK, WHITE, RED, GREEN for Ground. Inside the dryer where you connect the wires should be the same colors. Just put the Black with the Black and so on. Make sure the plug is for a dryer and not a stove.
Mar 26, 2009 | Kenmore Dryers
Power cord connection on back of maytag dryer model LDE8416ACE is not color identified in order to install a 4 cord power line.
center is always neutral ..white on cord or center wire on 3 wire cord other 2 are hot but doesn't matter red or black on cord will work
Jun 30, 2008 | Maytag Dryers
Roper RES7646KQ Electric Dryer Logo
155 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
