Question about Patton PUH680-U Utility Heater
Worked last night, just blowing cold air today on both settings (1000 and 1500)
    Genius:
  • 1,015 Answers
There are a couple of things I would check. Some units like this have a seperate fuse for heating and fan.They should be located on back or lower portion on sides.Most of these have a black screw on cap. Unscrew cap to access fuse. Always remember to be safe and have heater unplugged before doing any checks or repairs. Most of the older units of this type use old style automotive fuses which are round with a glass center section.You can look at them and see if the wire or metal strip inside is seperated. If it is then fuse is bad and needs replaced with new fuse of same amp rating and size. The other thing is that the heating element is burned out. You can check this by removing front cover or grille and visually inspecting heating coils.Don't mean to sound negative but if it's much more than a fuse you're probably better off to just get a new one. Hope thishelps . Thanks
Posted on Nov 04, 2010
Not blowing any air
Fuses would be the first thing to check. Then the switch and then the blower motor. If you have power to the motor and it isn't doing anything. You'll have to replace it.
Aug 18, 2013 | 2004 Volvo XC90 2.5
Whirlpool refrigerator was accidentally turned off last night and today morning when we turned it back on, it seems as if the fridge is not working while freezer seems to be working. What could possibly be...
I would wait 24 hrs from when you turned it back on , to tell if there is a problem . Also , set both controls mid-range , and feel at the back vent on the left side , to see if you feel and air blowing to the refrig section . May be slight air flow . Leave the settings there ( gets cold no quicker if turned up completely ) , and at the mid setting , you are not obstructing any air flow .
Aug 15, 2010 | Whirlpool Refrigerators
Blowing out hot air
check for the clogged evaporating coil
Jul 20, 2010 | Sharp CV-P10LC Portable Air Conditioner
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
98 accord ac not blowing at all
This is very vague. Is the blower motor working (can you hear blowing inside?), is it blowing but it's hot? Can you hear the compressor running (open your hood and listen if something is kicking on and off). AC is so complex. It could be as simple as a freon leak or as complex as a compressor, hose, accumulator etc.
Mar 13, 2009 | 1998 Honda Accord
Auxilliary heat just started blowing cold air
SOund like you heating element has a open limit or the sequencer is bad. Another thing that it may be is the element wire has broken. Either way it sounds like you need a technician to come out and repair.
Jan 27, 2009 | Honeywell TH4210D1005 Heater
Intertherm heater blows cold air.
do you have elec or gas heat? nat or propane?
Nov 16, 2008 | Intertherm P3RA-048K Air Conditioner
MY HAIER A/C IS NOT GETTING COLD
I have a fairly new Haier Air Condition that I bought last year, it has been working good up until last night. I keep this one in my bedroom and put it on every night since the summer. Last night I woke up very warm, the temp reading was 75 the AC did nothing but blow out just air. I threw away the booklet on it because I've had no problem up until now. Does anyone know how I can make it cold again. HELP!!!!
Jun 22, 2008 | Heating & Cooling
Patton PUH680-U Utility Heater Logo
136 people viewed this question
Top Patton Heating & Cooling Experts
Mack Baxter
Jay Finke
Jay Finke
jeff5may32
Are you a Patton Heating and Cooling Expert? Answer questions, earn points and help others
