Question about Compaq Presario 5BW284 (202493-003) PC Desktop
Front cover i need to remove the front cover to install a dvd writer and cannot figure out how to get the cover off
I have a Compaq Presario-Desktop 5000 Model 5BW284 and have the same problem, I cannot figure out how to get the tower open.
Posted on Oct 05, 2008
  • 24 Answers
Ca you please tell me what type of PC you have? Compaq, HP, Dell?
Thanks
Jack
Posted on Jun 13, 2008
I have LG GP40NB40 Slim Dvd write, i installed LG writer with it own CD to my HP Pavillion. But wont play DVDs...WHY?
did you remove all of the original software as this can cause a software problem. you will need to remove the new software and the old software.then shut down the computer then. let it start up. turn back off again install the dvd writer then turn back on now should load the proper driver for the dvd rom. then install the software.
Sep 28, 2013 | Computers & Internet
I kept a disk in a dvd writer and after sometime it has broken in the writer i have removed the disk tray and removed the broken disk pieces now the tray is not going inside
You need to open the cover of you DVD driver to check if there is some particle left inside the DVD. As there is a possibility that there is something left inside the DVD. If you have idea you can open it and remove everything left inside the DVD.
Apr 26, 2011 | Samsung (SH-S162L/BEBN) DVD RW Burner
How to replace the timing chain of nissan cefiro v6 2000? its 97 model.
Engine - Timing Chain/Front Cover Revised Procedure
Classification:
EM98-009
Reference:
NTB98-107
Date:
January 15, 1999
GA16DE TIMING CHAIN/FRONT COVER
REVISED SERVICE PROCEDURE
APPLIED ENGINE:
GA16DE
APPLIED MODELS:
1991-94 Sentra (B13) w/GA16DE
1991-93 NX1600 (B13)
1995-99 Sentra (B14) w/GA16DE
1995-98 200SX (B14) w/GA16DE
SERVICE INFORMATION
A revised service procedure for the engine front cover/timing chain has been adopted for the GA16DE. It is no longer recommended to remove the
cylinder head when removing the timing chain/front cover(s). Utilize the following steps when servicing the front cover, timing chain, guides or
tensioner(s)
PARTS INFORMATION
CLAIMS INFORMATION
Please reference the "Revision C" pages of the Nissan "1992-1999 Warranty Flat Rate Information Manual", Section "AG", Op Codes AG12AA,
AG14AA, AG142A, AG143A, AG144A and AG24AA. Also reference Section "CA", Op Codes CA20AA and CA22AA. You will note that the
descriptions and flat rate times applicable to the B13 and B14 vehicles (with GA16DE engines) for these Op Codes have been revised to reflect this
new procedure.
Caution
^ After removing the timing chain, do not turn the crankshaft and camshaft separately or the valves will strike the piston heads.
^ When installing chain tensioners or other sliding parts, lubricate contacting surfaces with new engine oil.
^ Apply new engine oil to bolt threads and seat surfaces when installing the camshaft sprockets and the crankshaft pulley.
^ Do not spill engine coolant on the drive belts.
^ Please refer to the Service Manual for the correct tightening torque.
Removal
1. Set # 1 piston at TDC on its compression stroke.
2. Remove the spark plug wires.
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 2
3. Remove the rocker cover (see Figure 1).
4. Remove the coolant reservoir tank with bracket and reposition it for clearance.
5. Support the engine with a suitable jack.
6. Remove cylinder head front mounting bracket.
7. Remove engine front mounting, then the engine front mounting bracket.
8. Remove cylinder head front cover.
9. Remove the upper chain tensioner (see Figure 2).
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 3
10. Wipe off the links of the upper timing chain next to the timing marks on the sprockets. Put paint marks on the timing chain, matching them with
the timing marks on the cam sprockets and idler sprocket (see Figure 3)
11. Remove the four (4) front cover to cylinder head bolts.
12. Remove side and lower engine compartment splash covers.
13. Remove the accessory drive belts.
14. Remove the crankshaft pulley.
15. Drain coolant by removing the cylinder block drain plug and opening the radiator drain **** (Refer to MA section of the Service Manual).
16. Drain engine oil.
17. Remove intake manifold support of engine front side.
18. Remove power steering pump, pump bracket and tension rod. Position pump aside for clearance.
19. Remove the thermostat housing (See Figure 4).
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 4
20. Remove the lower chain tensioner (see Figure 5).
21. Remove the front exhaust tube. Refer to the "FE" section (Exhaust System) of the Service Manual.
22. Remove the front and rear engine gussets (if equipped) on either side of the oil pan.
NOTE:
On A/T models, remove the rear plate cover.
23. Remove the oil pan (see Figure 6).
a. Insert the Tool between the cylinder block and oil pan.
CAUTION:
Be careful not to damage the aluminum mating face. Do not insert a screwdriver, or the oil pan flange will become damaged.
b. Slide the Tool by tapping it on the side of the Tool with a hammer.
24. Remove the A/C compressor and position it aside for clearance.
25. Remove the A/C and alternator bracket with the alternator.
26. Remove the oil pump drive spacer.
CAUTION:
Be careful not to scratch the drive spacer when removing it.
27. Remove the front cover bolts and front cover.
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 5
CAUTION:
One bolt is located on the water pump (see Figure 7).
*1: Located on engine front mounting bracket.
*2: Located on the water pump.
*3: Located on the power steering oil pump adjusting bar.
CAUTION:
Be careful not to tear or damage the cylinder head gasket.
28. Remove the cylinder block to front cover alignment dowels.
CAUTION:
Do not hit the dowels or the cylinder block will crack.
29. Wipe off the links of the lower timing chain next to the timing marks on the sprockets. Put paint marks on the timing chain, matching them with
the timing marks on the idler sprocket and crankshaft sprocket (see Figure 8).
Installation
1. Install the crankshaft sprocket, making sure the mating marks face the front of the engine.
2. Install the idler sprocket and lower timing chain using the mating marks and the paint marks made during the removal process.
CAUTION:
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 6
3. Install the lower chain guides.
4. Front cover installation:
a. Using a scraper or other suitable tool remove all traces of liquid gasket from the cylinder block and front cover mating surfaces.
b. Install new crankshaft seal in front cover.
c. Install new oil passage O-rings and apply a continuous bead of RTV sealant to the front cover (see Figure 1).
NOTE:
Use Genuine Nissan RTV silicone sealant P/N 999MP-A7007, Three Bond P/N TB1207D or equivalent.
d. Install the front cover to the engine.
CAUTION:
Be careful not to tear or damage the cylinder head gasket or oil seal.
5. Align oil pump drive spacer with the oil pump, and install.
6. Install the oil strainer.
7. Install oil pan, referring to "Installation" in the "OIL PAN" section of the Service Manual.
8. Install upper timing chain and sprockets, using the painted reference marks made during removal.
9. Install upper chain tensioner.
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 7
a. Before installing the chain tensioner, insert a suitable pin into the pin hole of the chain tensioner (see Figure 2) to hold the tensioner in.
b. Once the tensioner is installed, remove the pin.
10. Install the lower chain tensioner (See Figure 3).
NOTE:
Make sure the gasket is facing the proper direction before installing the tensioner.
CAUTION:
Now rotate the crankshaft by hand. Check that no binding or interference problems occur when the engine is rotated.
11. Install the thermostat housing.
a. Use a scraper to remove all traces of liquid gasket from the mating surfaces of the engine front cover and the thermostat housing.
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 8
b. Apply a continuous bead of RTV sealant to the housing as shown in Figure 4.
NOTE:
12. Install camshaft sprocket cover:
a. Use a scraper to remove all traces of liquid gasket from the mating surfaces of the cylinder head and camshaft sprocket cover.
b. Apply a continuous bead of RTV sealant to the cover as shown in Figure 5.
NOTE:
d. Install camshaft sprocket cover.
1995 Nissan-Datsun 200SX L4-1597cc 1.6L DOHC MFI (GA16DE) Page 9
13. Apply RTV sealant to rocker cover gasket (see Figure 6a) and install rocker cover, tightening the bolts as shown in Figure 6b.
14. Install the following parts:
a. Crankshaft pulley.
b. A/C compressor and alternator bracket with alternator.
c. A/C compressor.
d. Power steering oil pump and tension rod.
15. Install front and rear engine gussets (if equipped), and rear cover plate (A/T models).
16. Install front exhaust tube.
17. Install upper right engine bracket and mount.
18. Install coolant reservoir tank.
19. Install alternator, power steering and A/C compressor drive belts.
20. Install engine compartment splash guards.
21. Install vacuum hoses, electrical harnesses and connectors.
22. Install spark plug wires.
23. Refill with coolant. Refer to the "MA" section ("Changing engine coolant, Engine Maintenance") of the Service Manual.
24. Refill with engine oil. Refer to the "MA" section ("Changing engine oil, Engine Maintenance") of the Service Manual.
Jan 15, 2011 | 1997 Nissan 200SX
How remove DVD From desktop Compaq Presario
have to be a little more clear with the question depends on where you want them removed if the computer oh intalar system for a non-dvd if the system goes to control panel and look for oction says oh add remove program
if you want to put a DVD without need only to plug the computer and remove the cable and put the other one wants to
Oct 17, 2010 | HP Compaq Presario Media Center SR1750NX...
Recently I purchased a HP dvd 1270i DVD writer through your company. I need an installation diagram on how to install. There is a steel plate covering the buttom dvd bay that must be removed. Also, I...
There is a tutorial here
http://www.youtube.com/watch?v=lIG7P7r2jGk&feature=related
The ddifference is thet your DVD is a SATA one but the process is the same. (no jumper pins)
If you have the same power leads as shown in the vid you will need get a a covertor cable.
Aug 12, 2010 | HP DVD±RW Burner
When trying to upload application programme for external dvd writer once nero 7 has been installed, message pops up saying disc is not formatted so we cannot install programme to set up dvd writer
go into add/remove programs and look for a previous version of nero. delete / remove it including incd...incd is used for cdrw and dvdrw discs. this is why you are getting format the disc. you will need to reinstall nero again, incl. incd.... also install power dvd it should be on the same disc..
Nov 23, 2009 | Computers & Internet
Installing a DVD Writer in open slot/replace the current drive
this plate is a cabinet safety plate just as a slot of our PCIE ...just twist that plate from one side so it will brake at two end tips and then install your dvd rw...
Aug 19, 2009 | Dell Inspiron 530 Desktop Computer...
Install dvd rom and remove one of the cd rom's
hi! replacing cd room,open your cpu cover by two quick lock bolt at back side of your pc right side,show on figure w/ arrow where the quick lock bolt.c1c13bc.gifthen pull out cover and you'll cd rack inside your cpu as shown on figureba392e9.jpg release 2 lock screw,and pull out i.d.e cable on cd room terminal also the audio cable next to leftside if have one,next the front cover of cpu thats locking your cd room theres a cliff lock on side opposit of the fron cover lift it by flat screw driver slowly and careful it might broke,after cover was detouched,don't remove any wire connection on front cover,pull out your cd room replace by dvd rom and connect all what has been disconnect on cd room put back front cover,and connect pwer,audio and ide cable again then try to switch on your dvd rom is a plug and play you can install your dvd installer and follow wizard instruction and click finish...regards
Mar 27, 2009 | Dell Dimension 2350 PC Desktop
LG GSA-H62N WILL NOT INSTALL ON MY COMPUTER WITH VISTA HOME EDITION
Please check and let me know the exact model of your computer. If you have a door in front or on top you should see the exact model number. I want to make sure your system can handel a DVD writer. Are you replacing a cd with a DVD writer or adding a 2nd drive? On all compaqs the the new DVD drive needs to be set to CL(Cable Select ) on the back of the new DVD drive. Also make sure you have the right IDE cable and power.
Jan 05, 2008 | Computers & Internet
Compaq Presario 5BW284 (202493-003) PC Desktop Logo
243 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
