Question about Lands Phones
Caller id How do I get my caller id working on my Nitsuko 92753 124i/384i 22 button Hf w /sk disp? I know the phone company part is working because we called on that, but we can't get the display to show the incoming numbers. Any suggestions?
  • 65 Answers
SOURCE: Caller Id does not always show up
call panasonic 1-800-211-7262
Posted on Feb 05, 2008
SOURCE: Uniden CXA15198 not showing caller id
Had a similar issue with a brand new DECT2035 uniden phone, displaying incoming call not caller ID.
Checked my old uniden phone, and it was receiving CID. So I connected my DECT2035 to that line and then lo and behold I got my CID.
After further investigation I found that CID on my dect phone wont work if its using a shared filter (ie. adsl/phone splitter). Had to find an unfiltered splitter and then just put a phone filter (that I got with my adsl modem) onto the line that is directly connecting the phone. and then WOOHOO I have caller ID.
Hope this helps you... I got my wife a little cranky over this one cos it took me over an hour and a half to try and sus this one out =)
Posted on Apr 30, 2009
SOURCE: CALLER ID ONLY SHOWS "INCOMING CALL"
I was using this site while trouble shooting this in the US...
If the customer has DSL with filters in the same system go back to the NID and Isolate the DSL,
test the caller id and call waiting caller id. If this works you have Data Bleed coming from the DSL.
Make sure there are not two sets of filters on the line. Tjis customer had a filter with the DSL modem.
Doing this we just fixed an on going problem for a field tech who was the second callout on a customer issue.
Posted on May 11, 2009
rylee_smith
  • 8619 Answers
SOURCE: UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 16, 2009
consultel1
  • 860 Answers
SOURCE: I need a user manual for an older phone and can't
http://www.wedophones.com/Manuals/NEC/i-series%20multibutton%20phone%20feature%
Posted on Dec 10, 2009
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
Caller id doesn't work on all four phones
Its one of two things.
1) the phone company needs to correct the caller id signal sent to your phone, or
2) the base unit is going bad and cannot proccess the caller ID signals.
Call the phone company and ask them to check your caller id coding first.
May 16, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
Caller i.d. doesn't work piece of junk
Please download this manual, and study e.g on page 21 About caller ID If you subscribe to caller ID service from your local telephone company, this feature displays the name and telephone number of the caller before answering a call (even when you are on another call). The caller ID features of this product will work only if you subscribe to caller ID service and both you and the caller are in areas offering caller ID service, and if both telephone companies use compatible equipment. Contact your local telephone company if: • you have both caller ID and call waiting, but as separate services (you may need combined service), • you have only caller ID service, or only call waiting service, • you do not subscribe to caller ID or call waiting services but wish to try them. There may be fees for these services, and they may not be available in all areas. This product can be used without subscribing to either caller ID or combined caller ID with call waiting service, although the caller ID features of this product will not function.
http://www.vtechphones.com/docMgt/public/art/52882/6041_manual.i4.pdf
Mar 12, 2010 | Vtech Cordless 6041 Phone
HAVING PROBLEM WITH CALLER ID WORKING
Go onto the menu of the handset and set caller id to on.
Mar 16, 2009 | ATS RA2180BB Cordless Expansion Handset
I have call waiting and caller ID through my phone company. I have two Uniden phones--EXA17980 and EX15160 cordless phones. Both phones should display the caller ID while I am on the phone with another...
You're right, at least one of them should. You should contact your telephone company and ensure you have Caller ID while on Call Waiting service (CIDCW) - it's not always the same as just Caller ID. Sometimes they'll want even more money. :)
Mar 09, 2009 | Uniden Cordless Phone
Can't display caller id info
Does CID work on ANY phone in the system? The reason I ask is because prior to issue 7, a Caller ID card had to be inserted into the trunk card. If yours is older, it may not have the card.
Carl
Aug 26, 2008 | Panasonic KX-T7453 Corded Phone
CALLER ID-CANNOT SET IT
there really shouldn't be anything to set up. if you have another caller id box or phone, try plugging that in to the phone jack first checking for dial tone, then the caller id. if neither are working, call your phone company. if only the caller id is still not working, ask your phone company if it is activated.
hope this helps.
wg
Feb 12, 2008 | Panasonic KX-TG1033S Cordless Phone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
Caller id
This is a feature from your phone company you may have to pay extra for. Caller ID information is normally transmitted just after the first ring. When you are using call waiting there is no ring.
Jun 19, 2007 | Uniden DCX640 Cordless Expansion Handset
Lands Phones Logo
95 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
